Sofirn C01R deep red [sold out, discontinued]
947 posts / 0 new
Henk4U2
Henk4U2's picture
Last seen: 7 min 37 sec ago
My little red beauty finally arrived. Apart from the pre-sale time, it went like this.
July 04th: picked up by shipper
July 05th: processed by shipper
July 06th: on plane
July 10th: arrival Luxemburg
July 20th: departure from Luxemburg
July 21st: arrival The Hague
July 22nd: arrival Amsterdam
August 06th: my place, 32miles from A’dam.
I guess the last 15 days were spend on back of an Über slug.
More than 2 months since ordering, from which actually 8 days on the move.
But all’s well that end’s well. And I like it, at lot.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
jon_slider
jon_slider's picture
Last seen: 8 hours 32 min ago
anybody with a light meter, what are the lumen outputs?
mortuus
mortuus's picture
Last seen: 2 hours 53 min ago
got my lights today. works great but im having a very hard time to attach the mettalic keychain to the light Sad wish they did this from the factory…. so far no luck….. maybe imstupid….
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
mortuus
mortuus's picture
ah i got it too work after a bit of patience Big Smile time to retire my astrolux a01 light now… so will have the sofirn and the olight uv keylight fun combo. Really great sofirn looks good on turbo.
              つ ◕_◕ ༽つ
Lux-Perpetua
Lux-Perpetua's picture
News Flash:
C01R stock is slowly running out. I'm not sure if that means including or excluding the stock they want to sell via Amazon DE/US. However, there might be a chance for a second batch of C01R. Now, Barry and I have been thinking whether Sofirn should use XP-E2 photo red again or move on to SST20-DR. I said it's probably worth trying the latter one as the optic seems to fit really nice to the die/dome size of SST20 emitters, see the beam quality of C01S using SST20 4.000K 95CRI. Eventually, chances look not too bad that we may see less artifacts in the hotspot by using the slightly bigger LED. Moreover, they could try to push C01R even a bit more to its very limits - in both directions. That means more power (and heat for sure Big Smile ) on high mode but also less power and less brightness in the low mode for even better preservation of your night vision. We could name it C01R reloaded or C01R V2...whatever.
Sofirn is also looking for alternative TIR lenses (as an accessory for instance) to enable each customer choosing his/her favorite beam profile. As many of you stated, a floody wide angle beam lens would be the icing of the cake.
TimMc
TimMc's picture
Last seen: 5 hours 44 min ago
10440? Cool
contactcr
Last seen: 13 hours 11 min ago
They need to tool up for some other metals!
extremesquared
Last seen: 1 year 1 month ago
extremesquared wrote:
Looking at the weegee’s last pictures posted, this is almost certainly prohibitively bright when used close up or in groups. If that’s a 10 degree optic, then a 45 degree should help a lot. Inverse tan^2 math puts center intensity of a 45 degree optic around 3% of the 10 degree optic, if that math is right. Dim AND focused lights are nice though for not shining in other peoples’ dark-adjusted eyes.
Got them. They are perfectly acceptable on low. Still going to put a 45 degree optic on it to make it dimmer. It really is hard to judge monochromatic lights based on pictures or numbers.
Slim Pickens
Slim Pickens's picture
Last seen: 1 day 14 hours ago
If we have a chance for a lower low and a higher high…any chance we could get far red (720 nm)? Innocent
lightdecay
A far red LED would not be able to make a useful amount of light. Probably 1 lumen or less.
SST-10-FR is 730nm. Human eye is about 117x less sensitive to 730nm compared to 660nm. Not sure what LEDs are available at 720nm, but eye sensitivity isn’t much better at 720nm compared to 730nm.
Lux-Perpetua
I‘m just checking with Sofirn if it’s feasible, reasonable and cost-effective to revive C01 using a 5mm EPIGAP EOLD-670-524 LED with 670nm.
https://www.epigap-optronic.de/tl_files/frontend/epigap/Datenblaetter/LE...
However, costs could be insane for a small batch of these lights. Maybe I should contact them to get a quotation. Big Smile
Lux-Perpetua
TimMc wrote:
10440? 8^)
No way, sorry.
I could imagine they have a plan like this in the drawer but materials like copper, titanium or brass are rather expensive and require different tools for machining. I wouldn‘t mind to see a nice C01S in mokume gane for $ 80.00 Big Smile
Slim Pickens wrote:
If we have a chance for a lower low and a higher high...any chance we could get far red (720 nm)? O:)
I made some suggestions to Sofirn to lower the low mode for better preservation of the night vision and to reduce brightness on medium mode as Djozz mentioned before as it is too close to high mode. I also suggested trying to raise the current on high mode a bit more as SST20-DR can sustain higher currents than XP-E2 photo red. Not too much of course for a small light like C01R but maybe it’s worth trying. Wink
Far Red is probably not worth it as most people will barely see any light coming out of the front. I suppose the reasonable limit is 690nm (for medical/scientific purposes like here http://budgetlightforum.com/node/73349).
Unheard
Unheard's picture
Last seen: 32 min 59 sec ago
I’m in for longer wavelengths if price is right. Else I would say a different optics and a lower low would be a huge step forward. But bear in mind that the floody option significantly reduces brightness already. We’re not talking about low reduced by a magnitude.
Smile, you cannot kill them all.
Lux-Perpetua
Unheard wrote:
I'm in for longer wavelengths if price is right. Else I would say a different optics and a lower low would be a huge step forward. But bear in mind that the floody option significantly reduces brightness already. We're not talking about low reduced by a magnitude.
Concerning longer wavelengths:
IMHO, it's quite a risk for a manufacturer to start a series production of these exotic flashlights, even if their MPQ is 250 pcs only. The smaller the MPQ is, the higher costs per unit eventually get, which again leads to less margin in selling for a reasonable price to the customer. If we now pursue to get a C01R with 730nm, chances are big that many customers will feel screwed after buying and using the light as there's barely any light to see even on high mode. A light like this could be useful for medical or scientific purposes for sure but that's a whole different category. I have no reliable, scientifically proven source right now but word of mouth is that high radiation not only of short wavelengths (x-ray, UV-C, UV-B, UV-A and even blue light) but also of long wavelengths (far red - infrared) can be harmful to the human eye.
Concerning some tweaks in C01R:
I didn't want Sofirn to reduce brightness settings by a magnitude but some gentle reductions to improve mode spacing. A lower low might end up in a great firefly mode using the "honeycomb" optic or anything more frosty/hazy/milky...whatever. Smile
extremesquared
Marginally scientific low runtime test:
Freshly charged ~10 year old Eneloop AAA: 55h 10m
Shutoff voltage: unmeasured
Freshly charged ~2 year old Amazon “750mAh” rechargeable AAA: 57h 0m
Shutoff voltage: 0.835V
bigtrav261
bigtrav261's picture
Last seen: 9 hours 47 min ago
Anybody else in the US still waiting for their light to emerge from the e-commerce black hole that is Newgistics?
Helios azimuth
Last seen: 12 hours 11 min ago
Gave up on receiving mine. The post office does not deliver to homes up here in the mountains, only to PO Boxes. So I always put both addresses since UPS and FedEx bring to houses. But companies change things. First they did not include the PO Box and Lin contacted me. I gave her the PO Box and they tried again, but that was undeliverable too for some reason. So no go. Other things were delivered to me from them and other companies. Life in the country is so good I do not mind an occasional glitch.
gravelmonkey
Last seen: 54 min 44 sec ago
I’ve been abroad with work and only just got my hands on my C01R.
Light output is great, the wavelength is noticibly deeper than other red leds I’ve got, when ceiling bounced on high, the colour reminds me of film scenes in submarines or photo dark rooms.
Re. Brightness, yes the low could be tad lower but it’s not a deal breaker for me.
I ordered the hard plastic AAA diffuser at the same time as the C01R, on medium or high this will make a great 360 degree light to clip onto a backpack when cycling.
id30209
id30209's picture
Last seen: 18 hours 59 min ago
Just got mine. Love it but hotspot is kinda anoying so i took a piece of Scotchbrite and “polished” lens a bit. Result is amazing, beam is uniform without hotspot and artifacts.
WTB Titanium 4sevens 2xAA tube
bigtrav261
The holdup for mine has definitely been Newgistics. My light was finally handed off to the post office yesterday, and is out for delivery today. It only took a week or so for it to get to the US. Newgistics and their “shipping partner” had it for over a month! I’m hoping that yours is just in the same situation, and will get to you soon.
ggf31416
Last seen: 17 hours 45 min ago
12000 km in 60 days, 200 km per day, still faster than walking or swimming from China Silly
hank
hank's picture
Last seen: 1 day 18 hours ago
So set on medium, held at elbow length so it illuminates both eyes, viewed for three minutes through closed eyes.
I think that’s roughly the prescription. Time wll tell if my vision improves.
OldSkol
Last seen: 20 hours 7 min ago
With all the talk about 670nm deep red led helps eyesight @ http://budgetlightforum.com/node/73349
Using a 670nm would lead me to get another one or two
Maybe add some blue anodizing for health
Cheers
OS
contactcr
OldSkol wrote:
With all the talk about 670nm deep red led helps eyesight @ http://budgetlightforum.com/node/73349 Using a 670nm would lead me to get another one or two Maybe add some blue anodizing for health Cheers OS
This is already the light you seek. This LED is 650-670 according to data sheet. The next “deeper” red (called Far Red) is 720-740 and barely visible. I doubt it would sell very well.
iamlucky13
Last seen: 11 hours 9 min ago
We already brought up alternative emitters in the C01 thread, but Barry said they are planning to just do one emitter to keep the cost low.
http://budgetlightforum.com/comment/1688135#comment-1688135
He did not confirm if a host version will be made, but djozz was previously under the impression this would happen if a new C01 batch is made. A host would be very easy to solder your own 5mm LED into.
Even if there is no host, it will be unpotted.
hank wrote:
So set on medium, held at elbow length so it illuminates both eyes, viewed for three minutes through closed eyes. I think that’s roughly the prescription. Time wll tell if my vision improves.
There is no prescription. Some initial research with small numbers of participants indicates there is probably an effect. Confirming this as known beneficial treatment without significant side effects to FDA standards will requirement significantly more testing. The risk does seem very low, so I’m hardly going to discourage it, but be careful about overstating what is known at this time.
Lux-Perpetua
EPIGAP charges considerable prices plus shipping fees for their 670nm 5mm LED. Consequently, this idea is not viable for a small batch of C01 lights. Sad Still, you may feel free to manually swap the emitter in an existing C01 light.
lightdecay
EPIGAP 670nm leds can have a peak wavelength between 660nm and 680nm. Data sheet does not show what the spectrum looks like, it could be more narrow or more wide than XP-E2 Photo Red 660nm.
Until someone tests some of these leds and compares them to Sofirn’s XP-E2 Photo Red 660nm, I don’t think there is enough evidence to suggest they are that much different.
nightwalker
nightwalker's picture
I received my Sofirn order yesterday, including 2x C01R and diffusers. I wanted to look up some information on the Sofirn website product page and noticed that they are now out of stock! Same with the eBay Store. And the Aliexpress Store #2933049 doesn’t have it, either (although this store claims to be the official store, is it really?).
Anyway this is quite a neat light. Way more powerful than I expected. Hope everyone that wanted one was able to get it!
Back to the main question I was trying to answer, does the C01R have thermal throttling or timer-based step-down? I left it on the highest mode w/ diffuser on my nightstand last night while preparing to sleep. Can the LED be damaged by doing this? It probably ran 10-15 minutes total and was hot when I turned it off. Sorry if this was answered in thread, I did some searching but didn’t find a definitive answer.
Attempting to build a Convoy of Convoys.
contactcr
No step down at all, time or temp. The electronics can handle quite a bit of heat (more than your fingers) so it’s hard to say. My guess is it would probably survive if ambient temp isnt too bad and air flow not blocked significantly but I wouldn’t leave it on high regardless.
MoreHiCRILumens
MoreHiCRILumens's picture
Last seen: 13 hours 29 min ago
I glued my first tritium on this yesterday. Now its much easier to find at nightstand.
Still waiting that more floody optic on this.
