Luminus SBT-90 gen2 5700K tested (SBT-90-WDS-F72-SA600 SA-H4, from Neal)
115 posts / 0 new
JaredM
JaredM's picture
Last seen: 4 months 1 week ago
Yes, the cell contributes a whole lot, but here I’m starting with the voltage under load of a 30T based on HKJs data and reported Vf values from djozz and other’s. It’s seems safe to me to estimate a 300mV drop is occurring at 20A elsewhere in the circuit. The FET doesn’t seem like a meaningful contributor according to the spec sheet.
Djozz and MRsDNF conducted switch resistance tests years ago and found between 1 and 10 mOhm values across different models and current levels. https://budgetlightforum.com/node/32724
If you can, check output of mechanical switch lights with your bypass and compare with tailcap installed. These could show a large difference at times. Those that do though don’t usually last that long.
https://fundrazr.com/osturaband
No affiliation, just a fan.
Tom E
Tom E's picture
Last seen: 3 weeks 6 days ago
Ok - looks like I didn't recall the tests I did correctly.
SBT90.2 mods from notes:
  Brinyte B158: 25 amps on a 25S
  UF 1504: 24.5 amps on a GOLISI 26650
Just measured:
  K1: 24 amps on a T50
  K1: 23.6 amps on a 40T @4.21V
The new Vapcell T50 5000 mAh 21700 is for real, at or close to a 40T.
JaredM
JaredM's picture
T50 sounds great. VTC6 of the 21700 world.
And those amp draws look more in line with what I’d expect. 5-10 milliohm is typical for a good FET light.
I really think it might be a Samsung 50T, which I don’t know if it actually exists, but we historically were slow to learn of these new cells. One thing I’m hoping for is the ‘s’ line of Samsung 18650s (or even an ‘r’) to make it to the 30 series. I think by now there is room to improve power density and maintain 3Ah
Tom E
Tom E's picture
Hhmm, 50T sure bout fits it's performance.
Funtastic
Funtastic's picture
Last seen: 4 days 16 hours ago
Tom E wrote:
Ok – looks like I didn’t recall the tests I did correctly.
Just measured:
But how fast does the T50 drop off compared to a 40T
Piercing The Darkness YouTube channel – https://www.youtube.com/c/PiercingTheDarkness
Tom E
Tom E's picture
I'm not really set up for doing long term testing. I did get in another pair though of the T50's smile
vietnamreviews
Last seen: 2 days 8 hours ago
I don’t understand how to read the chart. For example, to achieve 4000 Lumens the lamp will consume 59.4W of power, right
ArtieT59
ArtieT59's picture
Last seen: 9 hours 28 min ago
KawiBoy1428 wrote:
djozz wrote:
Ehm, not really, my “science” is still on a ration for the next 12 years (wife,child) and I have plans for this led Smile
So what is the impression of removing the window?
It could just be the best performing SBT-90.2 I have tried so far….I don’t know? But here is what I got….
a. Warmed up the tint a bit…
b. Went from 358kcd to 408kcd (Original FT03 SST-40 GB Light)
c. Went from 5000lm to 5780lm at T/O (after I checked the throw so it was still pretty warm and battery drained a bit)
I know this ^ was a while ago, but I want to put one in a light that came with an xhp50, what did or do you use for “centering ring”, or more specifically so the reflector doesn’t short out in the mcpcb? I have been thinking about cutting a thin piece of plastic just so the reflector has something to sit on, would that work?
[FLF] Five Light Friday https://budgetlightforum.com/node/78749
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
My Sft40 beamshots / comparison thread: https://budgetlightforum.com/node/78100
The BLF GT with SFT40 (2300lm, 2700m+ @ 30 seconds!)
https://budgetlightforum.com/node/79561
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 day 4 min ago
In what light? I had a few lights that had the Gen1’s 90/70’s in them that I salvaged from older lights/builds… In the FT03 I didn’t use a centering ring.. I used Kapton Tape to cover the mcpcb from shorts..I was using the MTG2 26mm boards until Hank came out with the 32mm….
KB1428 “Live Life WOT
JasonWW
JasonWW's picture
His tests were not done in a lamp/flashlight. They were done in a sphere measuring the raw led with a power supply.
In a battery powered flashlight with it’s added losses (let’s use a conservative 20% loss) you would need 5000 total lumen to get 4000 out the front of the lamp. That would be about 18 amps. Then you need to consider the voltage sag. A decent 21700 might sag to about 3.8 or so. 3.8 × 18 = 68.4. So I would estimate about 70 watt is what a flashlight would consume.
If your talking about a raw led powered from a power supply, you can see that 4000 lumen draws 12 amps at 3.15 volt. Thats only about 38 watts. These not very practical numbers for real world use.
Personally I’d estimate a 30% loss and say you need to push it to 20 amps and you might be lucky to get 4000 lumen out of a flashlight.
These are all my own estimates based on djozz’s test results, as I haven’t ever used or measured this led. Maybe someone who has tested it in a flashlight can give some more detail.
vietnamreviews
Information is wonderful. Thank you my friend.
ArtieT59
ArtieT59's picture
In what light? I had a few lights that had the Gen1’s 90/70’s in them that I salvaged from older lights/builds… In the FT03 I didn’t use a centering ring.. I used Kapton Tape to cover the mcpcb from shorts..I was using the MTG2 26mm boards until Hank came out with the 32mm….!{width:100%}https://i.postimg.cc/fbGTZbzR/IMG-2158.jpg!
Awesome thank you. The 32mm baord fits in the ft03? I was going to order that from hank but thought ft03 had a 28mm mcpcb/
KawiBoy1428
No..You will have to run the 26 mm MTG2 board in the FT03.. unless you bore the shelf out wider..
dave1010
dave1010's picture
Last seen: 1 day 35 min ago
djozz wrote:
*my power supply goes up to 20A, so higher currents were not tested. As you can see in the chart, the max was not reached at 20A, but it seems also not far from max. It would be nice if someone with a PS that goes higher than 20A could test the behaviour at higher currents.
Has anyone been able to test this on a power supply that goes over 20A?
JaredM
JaredM's picture
I have a 30A supply. Just don’t have a 90.2
icpart
Last seen: 1 day 14 min ago
I find over AE stores very cheap SBT90 LEDs like this
https://www.aliexpress.com/item/32845013580.html?spm=a2g0o.search0304.0....
Are they genuine or fake?
djozz
djozz's picture
Last seen: 1 day 4 hours ago
They look genuine, and I have seen that store before, so it is not an extremely obscure source. But do not blame me if they are fake after all.
Tom E
Tom E's picture
djozz wrote:
icpart wrote:
I find over AE stores very cheap SBT90 LEDs like this https://www.aliexpress.com/item/32845013580.html?spm=a2g0o.search0304.0.... Are they genuine or fake?
Listing just says SBT-90, not SBT-90.2. Even the datasheet specs included are for the old SBT-90, looks like to me. I sure wouldn't trust a listing like that if it's a SBT-90.2 you are looking for. Can't imagine anyone interested in the old gen of this LED.
JasonWW
JasonWW's picture
Tom E wrote:
Listing just says SBT-90, not SBT-90.2. Even the datasheet specs included are for the old SBT-90, looks like to me. I sure wouldn’t trust a listing like that if it’s a SBT-90.2 you are looking for. Can’t imagine anyone interested in the old gen of this LED.
What does the 2nd generation sell for, $20 or $40?
That ad shows $17 which seems more like the older led.
Price alone seems to point to it being the older unit.
djozz
djozz's picture
Yes, I missed that it may not be the .2 version, in that case you get a way less performing led not capable of 20A.
Tom E
Tom E's picture
JasonWW wrote:
What does the 2nd generation sell for, $20 or $40? That ad shows $17 which seems more like the older led. Price alone seems to point to it being the older unit.
Hank sells the SBT90.2 mounted for like $45. Think you can get it for ~$35 somewhere else. Here on Ali for $39.
Ohh, Simon for $35 here.
JasonWW
JasonWW's picture
Yeah, so anytime you see such a super low price, it’s the old model.
There’s no guarantee that some shop may not sell the old model for $35, they might, but at least you know a $20 model is surely not the 2nd gen.
(That sounds complicated, but I hope it makes sense)
VrestoTaylor
VrestoTaylor's picture
Last seen: 2 days 21 hours ago
Hallo.Is there this led also in neutral or warm version?
EDC-Mezzol X8R-L xhp70 nw, Astrolux ST01 xhp50,WildTrail WT3M
Headlamp-Thrunite TH30 nw
pho
Last seen: 28 min 30 sec ago
No, only 5700k and 6500k.
