Wurkkos TS21 tear down
133 posts / 0 new
Tom E
Tom E's picture
Last seen: 1 month 1 day ago
Please Note
This light has a big parasitic drain, moderately high with the switch LED OFF (116 uA) or on low (180 uA), not visible in room light, and excessively, exceedingly high at 13.5 mA with the switch LED on High.
Tear Down
A brief quick tear down of the TS21, a new model from Wurkkos.
Tools used to open the TS21 - gloves to get the SS bezel unscrewed, solder pick and hammer to "gently nudge" out the driver:
I needed the gloves because the bezel felt very tight, and it was. There's no glue but found a lot of resistance to unscrew it. As you can see, the SS bezel is surprisingly big with extra long threading:
This sheet they have hides the surface of the MCPCB, not sure why, maybe effects the beam artifacts perhaps?
Used the solder pick with light taps of the hammer, actually not that light, to break the glue seal of the driver. Not many will have the fortitude to do it this way but I have an excellent track record of not damaging anything, or if I do (rarely), I've been able to repair it. The important thing is tilt the pick as far to the outer edge of the driver as can go - less chance of damaging components This driver has plenty of open space at the edges. Also important for this driver: you must remove the LED wires first, they are as short as possible, no extra wire that is coiled. For this light, the solder pick slipped off the driver and damaged the threads, as shown here on the left side. It had no effect on threading on the battery tube though. The glue shown here is not hard, it's soft and sticky - weird, not sure if I ever saw a glue like this, but was easily removable, cleaned up well.
I'm guessing the shelf is about 2 mm thick, rather thin. The head by itself is very light weight, thermally there's not much here. Notice the de-burring of the wire center hole? Nice touch by manufacturing - don't see that often enough, I usually have to do it myself. The object to the right of the hole is the clear plastic tube in the center of the switch. Not sure if it's a true "light pipe" but acts as one for sure. The LED light has to bend and travel a ways in this setup, probably not the best way to do it.
The driver - pretty much a standard FET+1 with the switch LED, same configuration as a Q8 or SP36. I'm sure they used the SP36 configuration of Anduril 2.
Showing how the red stuff partially covered one of the switch dual LED's:
Stock setup of the MCPCB:
After sanding to 2000 GRIT, mirror finish:
Re-Installed with MX-4:
Re-using the stock wires, I'd say 20 AWG:
After assembly, no need to re-glue the driver - the screwed in battery tube will hold it in place. Now it's much easier to access for future mods or firmware updates. The MCU is easily accessible with a flashing clip.
SMD Info
Will be adding more info...
Important Note
It's difficult to recommend this light with the parasitic drain so exceptionally high with the switch LED set to High. It appears all TS21's being shipped with the amber switch LED and power bank feature have it this high drain. Of course the easy work-around is not use the high setting for the switch LED, but the low setting has very low brightness.
Edited by: Tom E on 12/07/2021 - 07:24
thefreeman
thefreeman's picture
Last seen: 5 hours 56 min ago
You’re on fire with all these tear downs lately, this is very nice.
Fescron
Last seen: 5 hours 8 min ago
Nice, thank you!
pennzy
pennzy's picture
Last seen: 10 hours 20 min ago
Thumbs Up Thanks.
Haukkeli
Last seen: 1 hour 7 min ago
Interesting. I’m waiting mine to arrive. I mainly thought to use it as a host for modding.
LuxWad
LuxWad's picture
Last seen: 1 day 5 hours ago
Awesome teardown, thanks for doing this!
BTW the drain in your light is much higher than mine, which is 3 mA on High, 80 µA on low, and 30 µA while off. Maybe the Anduril 2 version has something to do with it?
Also I found that removing the sheet under the optic doesn’t seem to affect the beam really, but it does allow the switch light to shine through the front which looks pretty cool.
Tom E
Tom E's picture
They changed the USB-C controller I assume, because the new rev has new features - power bank, more power, etc.
Again, I am very suspicious of the USB-C controllers these guys use, and total lack of testing of the parasitic drain these things cause. Could be the designed usage of the part or the part itself, dunno.
3 mA is still bad though, very bad. Should be no more than 300 uA total with the switch LED on high.
Fescron
Tom E wrote:
They changed the USB-C controller I assume, because the new rev has new features – power bank, more power, etc.
Huh well you make a very interesting point there! The powerbank functionality seems a great function to me for a light that I always carry in my backpack, but if it’s empty before I can use it (even though I regularly check it) well what’s the use in that!
Tom E
Tom E's picture
The TS21 uses the same controller chip the new EC06 uses, and the EC06 has high drain, and it has a flickering blue LED issue.... Facepalm
The Injoinic IP5310 is the USB-C controller, datasheet PDF found here.
EC06:
TS21:
Fescron
Side note, I suppose it would be quite easy (with the right hardware: hot air gun) to swap the two combi-LED’s right? I would prefer to have the orange LED on the button instead of the green one… I have a black TS21 on it’s way and the hardware is slightly different there I think in the case of the LED colors compared to the colored flashlights (those seem to have the LED colors already differently)
Fescron
Tom E wrote:
The TS21 uses the same controller chip the new EC06 uses, and the EC06 has high drain, and it has a flickering blue LED issue…. Facepalm
EC06:
TS21:
Pretty sure the Q8 Pro also uses the same chip then? Because mine’s blue LED also sometimes randomly turns on…
Tom E
Tom E's picture
Hhmm, I guess should be fairly easy - I don't have any double LED's, got lots of singles in different colors. Wondering if the poor low output or high drain is the LED or the color amber, some how related to the drain.
Tom E
Tom E's picture
Fescron wrote:
Pretty sure the Q8 Pro also uses the same chip then? Because mine's blue LED also sometimes randomly turns on...
Yikes! Wonder how the parasitic drain is - I don't have a Q8 Pro, got lots of Q8's though...
Fescron
Tom E wrote:
Hhmm, I guess should be fairly easy – I don’t have any double LED’s, got lots of singles in different colors.
Neither do I, but I’m thinking to just swap the LED’s they used on the board, but I’m not entirely sure if the different voltages of the red/green/orange/blue LED are interchangeable with maybe different on-board current-limiting resistors…
Tom E
Tom E's picture
Well the stock current limiting resistors are both 100 ohms, very low, should work with just about any color. You can see them here in this pic, the 0402's just below the LED's, below the switch, horizontal. The left one is covered over with red junk:
Fescron
Tom E wrote:
Yikes! Wonder how the parasitic drain is – I don’t have a Q8 Pro, got lots of Q8’s though…
Hmm, I’ll try to give it a shot to measure that, I suppose I can power it with a bench-power supply at about 4.2v and have a low current measuring meter in between measuring leads that I press against the pads, since I can’t simply remove the back of the battery holder Innocent
Fescron
Tom E wrote:
Well the stock current limiting resistors are both 100 ohms, very low, should work with just about any color. You can see them here in this pic, the 0402’s just below the LED’s, below the switch, horizontal. The left one is covered over with red junk:
Ah yes I see them thanks! Yeah that gunk might cause a bit of trouble if I end up trying to swap the LED’s… I also wonder if it has an effect on the color the LED produces?
Tom E
Tom E's picture
To measure drain, I just remove the battery tube, sit an 18650 batt+ on the batt+ brass ring, and use a DMM meter across the batt- to the ground ring: easy.
I carefully removed the red junk off the LED - dunno about it's effect because I swapped resistors in the process - 100 ohm to 8.2K, but only for the amber color.
Fescron
Ah, yes good point, that’s also another way of doing it!
Tom E wrote:
I carefully removed the red junk off the LED – dunno about it’s effect because I swapped resistors in the process – 100 ohm to 8.2K, but only for the amber color.
… and also for the blue LED then right? Because they are both in the same package and use the same current limiting resistor? Or are there two more resistors somewhere else on the board?
Tom E
Tom E's picture
I believe 1 resistor is used for amber (1 side of each double LED), 1 resistor for Blue. I don't see separate resistors per LED, and each double LED acts as 2 distinct LED's, separate wiring, 4 connections.
Fescron
Yeah turns out I won’t be needing to swap the LED’s, the main light is already orange instead of green. However, on low you can’t see anything of the LED, that’s a shame… And high is too bright I guess, maybe I’ll change those resistors instead…
Also, I have to say it charges quite fast, a bit too fast for my liking. It peaked at 5V 2.9A and the battery for sure got hotter, the Q8 Pro charged at “only” 2.6A max from what I’ve seen…
EDIT: luckily it didn’t overcharge the battery as well, I measured 4.17-4.19V
Fescron
I measured the “parasitic” currents of my black TS21 with Anduril 2 with a Current Ranger from LowPowerLab (no auto-lock or hybrid memory mode, locked or unlocked is about the same):
  • LED low: ~150 µA with regular jumps to to 300-400+ µA
  • LED high: 13.7 mA (what?)
  • LED off: ~95 µA with regular jumps to to 300-400+ µA
I also measured it for my Q8 Pro (no auto-lock or (running) hybrid memory mode, locked or unlocked is about the same):
  • LED low: ~135 µA with regular jumps to to 300-400+ µA
  • LED high: 3.2 mA
  • LED off: ~90 µA with regular jumps to to 300-400+ µA
So yeah, my TS21 measurements are about the same as yours, and unexpectedly the currents of the Q8 Pro are lower. With the LED on high even way lower, even though the Q8 Pro (I think) features 2 LED’s. I suppose it’s down to the different LED color, and maybe current limiting resistors?
EDIT:
I also measured the same currents for my IF25A:
  • LED low: ~80 µA with regular jumps to to 200-300 µA
  • LED high: 1.5 mA
  • LED off: ~40 µA with regular (but less frequent) jumps to to 300 µA
pennzy
pennzy's picture
I went through this with the Astrolux EA01. Didn’t learn my lesson to wait for the debugged model.
zoulas
zoulas's picture
Last seen: 13 hours 27 min ago
Nice, this is invaluable information.
Tom E
Tom E's picture
I pm'ed Barry from Sofirn about these high parasitic drain issues - we'll see.
Just received a Mateminco MT70 Mini (FT03) w/SFN55.2 running Anduril, measured:
  • LED low: 48 µA
  • LED high: 101 µA
  • LED off: 20 µA
This is where the #'s should be for most lights! 20-40 uA on OFF is acceptable, any higher, something is wrong - there's a leak!
Lumintop EDC18 - Anduril, switch LED always ON, not controlled by Anduril:
  • 85 µA (no option on switch LED)
FT03 Mini w/SST-40, w/switch LED's and 4 LED's around the main LED in multiple colors, Anduril:
  • LED low: 120 µA
  • LED high: 3155 µA
  • LED off: 22 µA
For this MT03 Mini, the OFF and LOW readings are fine, but the high is way too excessive - no need to be this bright, but this is a definite "bling" light with all those extra LED's around the main LED. It probably would be fine at 500-1000 µA by adjusting the resistor.
I'll go along with a HIGH reading of up to 300 µA - that's acceptable. Any higher means the resistor value they are using is too high, or something is restricting the switch LED output, so they had to up the output to make it bright enough.
The "regular jumps" noted above is the standby checks for LVP, maybe other housekeeping - that shouldn't be a factor because of it being infrequent short durations (though it's longer and more frequent than I would like).
pennzy
pennzy's picture
I hope he listens to you. Too many lights seem to be plagued with this problem.
Muto
Last seen: 2 hours 17 min ago
TomE and every member here who cares about the entire performance of the new flashlight products that come out and tests them, THANK YOU ALL!
This is why the BLF Flashlight forum is sooooo valuable.
By reading the process and seeing the drawbacks of this model you have just saved me money/time/frustration and best of all because of the the measurements taken and verified from other members proving that the driver does indeed have parasitic issues it will probably lead to improvements made at the factory level to cure these matters.
Now show me where that Charles Bridge-something on Youtube that always does fluffy reviews so he can continue to get mountains of free stuff does any of these things?
He doesn’t and even admits everyone of his reviews will never be negative, always 5 stars, He may gloss over with “Id like to maybe see this/that changed in the future” but never warns people of bullsheet specs or worse inherent problems.
Here we share the Good, the Bad, and the Ugly just the way it should be.
Love the step by step of breakdowns Tom and appreciate the time taken, You Rock!
Thanks Again,
Keith
The difference between Hoarding and Collecting is the illusion of Organization
.“I will get one of flashlight from patrol car”
“History doesn’t repeat itself, but it sometimes rhymes,” Mark Twain
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
Tom E
Tom E's picture
These kind of tear downs may be somewhat dated compared to many of the great vid reviews being posted now, but we shouldn't loose touch with our base principles. Yea, we are not doing enough of these kind of deep dive looks, though in many respects, we are so much farther along now then ever, regarding measurements of output, throw, tints, CRI, etc.
Thanks for the kind words!
pennzy
pennzy's picture
Heads up. Roku streaming sticks are going through the same thing with remote batteries. They kill batteries in a matter of a few days. The problem has been going on for years. Replacement remotes have the same problem. https://community.roku.com/t5/Remotes-Accessories/Roku-streaming-stick-d...
Correllux
Correllux's picture
Last seen: 1 day 23 hours ago
Muto wrote:
TomE and every member here who cares about the entire performance of the new flashlight products that come out and tests them, THANK YOU ALL! This is why the BLF Flashlight forum is sooooo valuable.
Ditto…x100. I don’t always comment but over the years this information has proven so incredibly valuable and usually just super interesting as well.
Tom E wrote:
These kind of tear downs may be somewhat dated compared to many of the great vid reviews being posted now, but we shouldn’t loose touch with our base principles. Yea, we are not doing enough of these kind of deep dive looks, though in many respects, we are so much farther along now then ever, regarding measurements of output, throw, tints, CRI, etc. Thanks for the kind words!
Not dated…original core and still invaluable! All the info, the closeup photos, measurements….often times those tidbits are just gold for someone who needs to replace parts or wants to mod some way. And since most of us need to order from overseas with long wait times, getting it right the first time is a huge benefit (in time, if not in wasted costs). Your contributions are fantastic and it’s folks like you and the couple handfuls of others that are to me the biggest reason I stuck with this forum and got deeper into this fine hobby than I ever suspected I would. Big hats off to you! Smile
TheIntruder
Last seen: 1 week 1 day ago
Not at all. A picture can be worth a thousand words. On YT, a video and a thousand words can amount to little to nothing, depending on the source. And at a higher time cost.
There may be a few good reviewers who are worth spending the time to watch, but more often than not, clicking on a promising link results in disappointment, and wasted time.
Video can be useful, but there are many reasons texts are the tools most often used to teach.
