Battery Comparison Guide
Here are quick view comparison charts of some of the higher quality cells that member HKJ has tested.
10440 Cells
Brand~~~ ~Label.Description~ Tested Review Wrapper Chem Top PCB IR(ohms) MFG.mAh mAh@0.5A mWh@0.5A mAh@1A mWh@1A mAh@2A mWh@2A mAh@3A mWh@3A Max.Dis V.Min V.Max Dia Len
AW ICR 10440 350mAh 2012 @ Blue ICR SB ~ 0.23 350 278 1018 220 782 ~ ~ ~ ~ 1 A 2.8 4.2 10.2 43.9
Efest IMR 10440 350mAh 2012 @ Black IMR SB ~ 0.16 350 307 1184 302 1153 281 1053 190 705 3 A 2.8 4.2 10.3 44.1
Sibeile IMR 10440 350mAh 2013 @ Black IMR SB ~ 0.35 350 313 1111 296 1015 196 647 105 335 3 A 2.8 4.2 10.3 44.3
14500 Cells
Brand~~~~~ ~~Label.Description~~ Tested Review Wrapper Cell.Description Chem Top PCB IR(ohms) MFG.mAh mAh@1A mWh@1A mAh@2A mWh@2A mAh@3A mWh@3A Max.Dis V.Min V.Max Dia Len
AW IMR 14500 600mAh 2012 @ Red ~ IMR SB ~ 0.1 600 606 2209 597 2142 592 2092 3 A 2.8 4.2 14.2 48.8
AW 14500 750mAh 2012 @ Black ~ ICR SB 4.9 0.22 750 697 2492 673 2281 ~ ~ 2 A 2.8 4.2 14.3 51.2
Coolook LiFePO4 700mAh 2013 @ Black ~ LiFePO4 BT ~ 0.1 700 526 1582 521 1510 521 1474 5 A 2 3.6 14 50.7
EagleTac 14500 750mAh 2012 @ Black ~ ICR SB 5.4 0.33 750 766 2684 638 2131 ~ ~ 2 A 2.8 4.2 14.3 51.2
Efest IMR 14430 600mAh (V1) 2013 @ Red ~ IMR FT ~ 0.15 600 623 2197 541 1831 353 1176 3 A 2.8 4.2 14.2 42.8
Efest IMR 14500 700mAh (V1) 2012 @ Red
IMR FT ~ 0.98 700 615 2250 605 2172 601 2122 3 A 2.8 4.2 14.2 50.1
Efest IMR 14500 700mAh (V2) 2012 @ Red ~ IMR BT ~ 0.09 700 563 2013 555 1943 551 1898 3 A 2.8 4.2 14.2 50.5
Efest 14500 800mAh 2014 @ Black ~ ICR SB 3 0.18 800 772 2708 743 2485 ~ ~ 2 A 2.8 4.2 14.3 52.3
EnerPower 14500 840mAh 2012 @ Yellow Sanyo UR14500P ICR SB 3.1 0.21 840 802 2901 774 2658 ~ ~ 2 A 2.8 4.2 14.5 52.6
Intl-Outdoor UR14500P 840mAh 2012 @ Black Sanyo UR14500P ICR SB 3.1 0.19 840 803 2912 774 2670 ~ ~ 2 A 2.8 4.2 14.4 52.6
MBI MBI Nuke 14500 2014 @ Black MBI Custom ICR FT ~ 0.16 650 591 2174 586 2111 582 2062 7 A 2.8 4.2 14 50.1
Keeppower 14500 800mAh 2012 @ Black Sanyo UR14500P ICR SB 3.1 0.19 800 808 2929 782 2694 ~ ~ 2 A 2.8 4.2 14.6 52.8
Keeppower 14500 800mAh 2014 @ Black DLG ICR 14500 ICR SB 4.8 0.21 800 758 2750 727 2511 627 2066 3 A 2.8 4.2 14.6 52
Keeppower 14500 840mAh 2014 @ Black Sanyo UR14500P ICR SB 4.9 0.23 840 803 2909 780 2681 734 2408 3 A 2.8 4.2 14.4 52.5
Kinoko IMR 14500 750mAh 2013 @ Grey ~ IMR BT ~ 0.09 750 603 2163 597 2093 594 2055 3 A 2.8 4.2 14.1 50.4
Sanyo UR14500P 840mAh 2012 ~ Red Sanyo UR14500P ICR SB ~ 0.18 840 803 2912 774 2670 ~ ~ 2 A 2.8 4.2 13.9 48.9
Sibeile IMR 14500 700mAh 2013 @ Black ~ IMR? FT ~ 0.71 700 718 2555 574 1955 325 1089 3 A 2.8 4.2 14.2 48.5
Sibeile IMR 14500 700mAh 2014 @ Black ~ IMR SB ~ 0.11 700 606 2218 599 2145 594 2093 5 A 2.8 4.2 14.2 50
Sibeile IMR 14500 700mAh 2014 @ Black ~ IMR FT ~ 0.1 700 611 2238 604 2165 601 2122 5 A 2.8 4.2 14.1 49.2
Trustfire TF 14500 900mAh 2012 @ Flame ~ ICR SB 3.7 0.19 900 724 2500 649 2126 ~ ~ 2 A 2.8 4.2 14.1 50.9
Xtar 14500 800mAh 2014 @ Black ~ ICR SB 2.8 0.23 800 746 2580 662 2155 ~ ~ 2 A 2.8 4.2 14.5 51
WindyFire IMR 14500 600mAh 2014 @ Red ~ IMR FT ~ 0.08 600 641 2361 634 2295 632 2255 7 A 2.8 4.2 14.2 49.1
16340 Cells
Brand~~~~~ ~~Label.Description~~ Tested Review Wrapper ~Cell.Description~ Chem Top PCB IR(ohms) MFG.mAh mAh@1A mWh@1A mAh@2A mWh@2A mAh@3A mWh@3A Max.Dis V.Min V.Max Dia Len
AW IMR 16340 550mAh 2012 @ Red ~ IMR SB ~ 0.1 550 559 2008 538 1877 450 1538 3 A 2.8 4.2 16.6 33.7
AW ICR 123 750mAh 2012 @ Black ~ ICR SB 5.1 0.2 750 538 1930 497 1683 379 1235 3 A 2.8 4.2 16.6 34.3
EagleTac 16340 750mAh 2012 @ Black ~ ICR SB 5.6 0.4 750 631 2181 464 1530 ~ ~ 2 A 2.8 4.2 16.8 34.3
Efest IMR 16340.550mAh (V2) 2012 @ Red ~ IMR SB ~ 0.1 550 505 1848 497 1779 494 1737 3 A 2.8 4.2 16.6 34.2
Efest 16340 850mAh 2013 @ Black ~ ICR SB 2.9 2.9 850 541 1924 278 935 ~ ~ 2 A 2.8 4.2 16.6 34.4
Efest 16340 850mAh 2014 @ Black ~ ICR SB 2.8 2.8 850 600 2144 592 2023 ~ ~ 2 A 2.8 4.2 16.6 36.5
Keeppower 16340 700mAh 2012 @ Black DLG 16340 700mAh ICR SB 3.4 0.2 700 609 2191 578 1965 ~ ~ 2 A 2.8 4.2 16.7 35.6
Kinoko IMR 16340 700mAh 2013 @ Grey ~ IMR SB ~ 0.2 700 599 2131 586 2010 568 1887 3 A 2.8 4.2 16.5 34.1
Soshine RCR-123 650mAh 2013 @ Black ~ ICR SB ~ 0.3 650 437 1180 324 815 168 393 3 A 2 3.2 16.7 33.3
TrustFire TF 16340 880mAh 2012 @ Flame ~ ICR SB 3.5 0.2 880 669 2286 519 1690 342 1079 3 A 2.8 4.2 16.5 36
UltraFire ICR 123A 800mAh 2013 @ Green ~ IFR SB ~ 0.2 800 333 946 298 783 242 597 3 A 2 3.6 16.5 33.4
Yezl 16340 880mAh 2012 @ Grey ~ ICR SB 3.4 0.2 880 630 2169 536 1747 ~ ~ 2 A 2.8 4.2 16.5 35.8
18350 Cells
AW IMR 18350 700mAh 2012 @ Red ~ IMR SB ~ 0.09 700 751 2739 738 2650 730 2586 6 A 2.8 4.2 18.3 35.1
Efest IMR 18350 800mAh (V1) 2012 @ Red ~ IMR FT ~ 0.09 800 679 2455 670 2364 664 2306 3 A 2.8 4.2 18.2 35.6
Efest IMR 18350.800mAh (V2) 2012 @ Red ~ IMR BT ~ 0.09 800 703 2533 692 2437 689 2389 3 A 2.8 4.2 18.2 35.4
Efest IMR 18350 700mAh 2014 @ Purple ~ IMR FT ~ 0.9 700 695 2553 687 2476 686 2433 10 A 2.8 4.2 18.3 34.8
Efest 18350 900mAh 2014 @ Black ~ ICR SB 5.1 0.54 900 661 2346 494 1676 368 1204 3 A 2.8 4.2 18.6 37.5
Kinoko IMR 18350 850mAh 2013 @ Grey ~ IMR SB ~ 0.16 850 858 3071 842 2925 816 2764 5 A 2.8 4.2 18.2 35.5
Sibeile IMR 18350 800mAh 2013 @ Black ~ IMR FT ~ 0.1 800 859 3038 765 2596 474 1565 5 A 2.8 4.2 18.2 34.5
Sibeile IMR 18350 700mAh 2014 @ Black ~ IMR FT ~ 0.1 700 698 2516 692 2437 689 2383 7 A 2.8 4.2 18.2 34.9
Sibeile IMR 18350 800mAh 2014 @ Black ~ IMR BT ~ 0.17 800 866 3089 847 2929 823 2766 5 A 2.8 4.2 18.2 35.4
Tensai LC 19350 950mAh 2014 @ Grey ~ ICR FT ~ 0.14 950 872 3124 858 2987 846 2864 3 A 2.8 4.2 18.2 34.7
UltraFire XSL 18350 1200mAh 2013 @ Orange ~ ICR SB ~ 0.17 1200 788 2885 741 2588 562 1905 5 A 2.8 4.2 18.1 35.3
Xtar 18350 900mAh 2013 @ Black ~ ICR SB ~ 0.23 900 943 3372 914 3141 865 2870 3 A 2.8 4.2 18.2 36.3
18500 Cells
Brand~~~~~ ~~~Label.Description~~~ Tested Review Wrapper Cell.Description Chem Top PCB IR(ohms) MFG.mAh mAh@1A mWh@1A mAh@3A mWh@3A mAh@5A mWh@5A Max.Dis V.Min V.Max Dia Len
Efest IMR 18500 1100mAh (V1) 2013 @ Red ~ IMR FT ~ 0.05 1100 1095 4016 1066 3816 1065 3742 7 A 2.8 4.2 18.2 49.8
Efest IMR 18500 1100mAh (V2) 2013 @ Red ~ IMR SB ~ 0.05 1100 1058 3924 1045 3779 1043 3697 7 A 2.8 4.2 18.2 49
Efest IMR 18500 1000mAh 2014 @ Purple ~ IMR FT ~ 0.06 1000 1177 4356 1152 4169 1151 4088 15 A 2.8 4.2 18.3 49.6
Efest 18500 1500mAh 2014 @ Black ~ ICR SB 6 0.16 1500 1509 5537 1463 4964 1371 4292 5 A 2.8 4.2 18.4 53.5
EnerPower 18500 2000mAh 2014 @ Black ~ ICR SB 6.3 0.13 2000 1933 6891 1891 6365 1750 5583 5 A 2.8 4.2 18.4 53
Keeppower 18500 1500mAh 2012 @ Black Sanyo UR18500F ICR SB 8.3 0.21 1500 1589 5855 1549 5329 1504 4866 5 A 2.8 4.2 18.7 53.8
Keeppower 18500 1500mAh 2014 @ Black DLG ICR 18500 ICR SB 7.2 0.17 1500 1438 5277 1403 4774 548 1763 3 A 2.8 4.2 18.7 52.9
Keeppower 18500 1700mAh 2014 @ Black Sanyo UR18500F ICR SB 7.5 0.16 1700 1619 5975 1596 5500 1551 5000 5 A 2.8 4.2 18.6 53.5
Kinoko IMR 18500 1200mAh 2013 @ Grey ~ IMR SB ~ 0.06 1200 1114 4121 1093 3939 1095 3866 7 A 2.8 4.2 18.2 50.7
Sanyo UR 18500 F 1600mAh 2014 ~ Red Sanyo UR18500F ICR FT ~ 0.12 1600 1619 5900 1590 5456 1545 4998 5 A 2.8 4.2 18.2 49.3
Sibeile IMR 18490 1100mAh 2014 @ Black ~ IMR SB ~ 0.09 1100 1095 4062 1069 3864 1072 3790 10 A 2.8 4.2 18.3 48.8
Sibeile IMR 18500 1100mAh 2013 @ Black ~ IMR? FT ~ 0.35 1100 1209 4446 1043 3542 728 2316 5 A 2.8 4.2 18.2 49.3
WindyFire IMR 18500 1100mAh 2014 @ Red ~ IMR SB ~ 0.06 1100 1196 4434 1178 4263 1176 4166 10 A 2.8 4.2 18.3 50.6
18650 Cells
Brand~~~~~~~~~~~~ ~~~Label.Description~~~ Tested Review Wrapper ~~~Cell.Description~~~ Chem Top PCB IR(ohms) MFG.mAh mAh@1A mWh@1A mAh@3A mWh@3A mAh@5A mWh@5A Max.Dis V.Min V.Max Dia Len
AW IMR 18650 1600mAh 2011 @ Red ~ IMR SB ~ 0.05 1600 1553 5713 1514 5492 1499 5370 20 A 2.8 4.2 18.4 65.3
AW IMR 18650 2000mAh 2012 @ Red ~ IMR SB ~ 0.09 2000 1969 7191 1929 6839 1927 6650 10 A 2.5 4.2 18.4 65.2
AW 18650 2200mAh 2011 @ Black ~ ICR SB 9.2 0.16 2200 2072 7413 2006 6751 1926 6134 5 A 2.8 4.2 18.5 67.8
AW 18650 2600mAh 2011 @ Black ~ ICR FT 9.4 0.16 2600 2328 8660 2309 8125 2287 7646 5.2 A 2.8 4.2 18.3 67.8
AW 18650 2900mAh 2010 @ Black Pan NCR 18650 NCR FT 9.4 0.11 2900 2692 9658 2634 9055 2595 8517 5 A 2.5 4.2 18.4 68
AW 18650 3100mAh 2011 @ Black Pan NCR 18650 A NCR FT 9.3 0.11 3100 2833 10092 2746 9295 2631 8540 5 A 2.5 4.2 18.4 68
BattEnergy 18650 2600mAh 2013 @ Black SamsungICR18650-26C ICR SB 6.5 0.12 2600 2512 9197 2490 8597 2456 8028 5 A 2.8 4.2 18.5 68.5
BattEnergy 18650 3400mAh 2013 @ Black Pan NCR 18650 B NCR SB 9.3 0.1 3400 3196 11379 3129 10603 3011 9787 5 A 2.5 4.2 18.6 69
CalliesCustoms 18650 2250mAh 2011 @ Grey Pan CGR 18650 CH Hybrid LB ~ 0.08 2250 2222 8114 2167 7679 2153 7430 10 A 2.8 4.2 18.2 65
CalliesCustoms 18650 3100mAh 2011 @ Black Pan NCR 18650 A NCR LB 8.3 0.1 3100 2877 10246 2798 9468 2697 8745 5 A 2.5 4.2 18.7 68.8
EagleTac 18650 3100mAh 2012 @ Black Pan NCR 18650 A NCR SB 6 0.14 3100 2865 10166 2763 9213 2461 7811 5 A 2.5 4.2 18.5 68.2
EagleTac 18650 3400mAh 2012 @ White/Gr Pan NCR 18650 B NCR SB 6.4 0.12 3400 3196 11363 3099 10437 2876 9257 5 A 2.5 4.2 18.4 68.3
EnerPower+ 18650 2250mAh 2012 @ Black Pan CGR 18650 CG ICR? SB 6.3 0.12 2250 2191 7879 2174 7399 2139 6877 5 A 2.8 4.2 18.4 68.8
EnerPower+ 18650 2250mAh 2012 @ Blue Pan CGR 18650 CH Hybrid SB 9.3 0.09 2250 2223 8077 2200 8065 2198 7414 10 A 2.8 4.2 18.5 69.1
EnerPower+ 18650 2900mAh 3C 2012 @ Blue Pan NCR 18650 PD NCA SB 9 0.08 2900 2808 10113 2764 9596 2758 9258 7 A 2.8 4.2 18.6 69.1
EnerPower+ 18650 3400mAh 2012 @ Blue Pan NCR 18650 B NCR SB 8.9 0.09 3400 3237 11541 3159 10732 3048 9936 5 A 2.5 4.2 18.7 69
Efest IMR 18650 1500mAh (V1) 2012 @ Red ~ IMR FT ~ 0.05 1500 1471 5423 1437 5196 1435 5109 10 A 2.8 4.2 18.3 65.6
Efest IMR 18650 1600mAh (V1) 2013 @ Red ~ IMR FT ~ 0.05 1600 1520 5654 1478 5377 1401 5290 30 A 2.8 4.2 18.4 64.8
Efest IMR 18650 2000mAh (V1) 2012 @ Red ~ IMR FT ~ 0.09 2000 2148 7769 2099 7302 2089 7006 7 A 2.8 4.2 18.3 65
Efest IMR 18650 2000mAh (V1) 2014 @ Red ~ IMR FT ~ 0.18 2000 2205 7960 2156 7452 2131 7075 7 A 2.8 4.2 18.4 65.1
Efest IMR 18650 2000mAh (V2) 2014 @ Red ~ IMR SB ~ 0.18 2000 2212 8001 2166 7533 2148 7199 7 A 2.8 4.2 18.4 65.9
Efest IMR 18650 2250mAh 2012 @ Black Pan CGR 18650 CH Hybrid SB ~ 0.09 2250 2200 8019 2158 7627 2161 7442 10 A 2.8 4.2 18.5 67.1
Efest IMR 18650 2500mAh 2014 @ Purple ~ IMR FT ~ 0.05 2500 2355 8597 2320 8317 2307 8135 30 A 2.8 4.2 18.3 65.1
Efest 18650 2600mAh 2012 @ Black ~ ICR FT ~ 0.11 2600 2439 9118 2411 8617 2375 8170 5 A 2.8 4.2 18.3 65
Efest 18650 3100mAh 2012 @ Black Pan NCR 18650 A NCR LB 2.8 0.14 3100 2891 10210 ~ ~ ~ ~ 2.7 2.5 4.2 18.6 68
Efest 18650 3400mAh 2013 @ Black Pan NCR 18650 B NCR SB 5.9 0.12 3400 3201 11386 3122 10513 2742 8858 5 A 2.5 4.2 18.5 69.8
Intl-Outdoor UR18650FM 2600mAh 2012 @ Black Sanyo UR 18650 FM ICR LB 7.6 0.12 2600 2433 9070 2424 8567 2396 8043 5 A 2.8 4.2 18.7 69.1
Intl-Outdoor NCR 18650A 3100mAh 2012 @ Black Pan NCR 18650 A NCR LB 11.7 0.1 3100 2869 10241 2790 9495 2723 8906 5 A 2.5 4.2 18.5 68.9
Intl-Outdoor NCR 18650B 3400mAh 2012 @ Black Pan NCR 18650 B NCR LB 11.6 0.1 3400 3171 11310 3102 10575 3039 9960 5 A 2.5 4.2 18.6 69.4
Keeppower IMR 18650 1600mAh 2014 @ Black Sony IMR? (2014) IMR SB ~ 0.05 1600 1498 5543 1468 5337 1465 5237 30 A 2.8 4.2 18.5 66.3
Keeppower IMR 18650 2100mAh 2014 @ Black Sony US18650 VTC4 IMR SB ~ 0.05 2100 2021 7422 1969 7105 1964 6978 30 A 2.8 4.2 18.5 66.8
Keeppower IMR 18650 2250mAh 2012 @ Black CGR 18650 CH Hybrid SB ~ 0.08 2250 2234 8148 2198 7785 2200 7595 10 A 2.8 4.2 18.5 66.6
Keeppower IMR 18650 2500mAh 2014 @ Black LG 18650 HE2 IMR SB ~ 0.05 2500 2407 8752 2364 8464 2351 8289 20 A 2.8 4.2 18.6 66.7
Keeppower IMR 18650 2600mAh 2014 @ Black Sony IMR FT ~ 0.04 2600 2559 9340 2498 8961 2496 8807 20 A 2.8 4.2 18.3 65.1
Keeppower IMR 18650 2900mAh 2014 @ Black Pan NCR 18650 PF NMC SB ~ 0.07 2900 2757 9956 2678 9386 2668 9099 10 A 2.5 4.2 18.6 66.8
Keeppower IMR 18650 3200mAh 2014 @ Black Pan NCR 18650 BD? NCR FT ~ 0.07 3200 3029 10926 2956 10345 2972 10126 15 A 2.5 4.2 18.4 65.8
Keeppower 18650 2200mAh 2012 @ Black Samsung UR 18650 A ICR SB 8.5 0.11 2200 2157 8057 2132 7779 2062 7703 5 A 2.8 4.2 18.5 69.3
Keeppower 18650 2600mAh 2012 @ Black Sanyo UR 18650 FM ICR SB 8.4 0.12 2600 2405 8957 2390 8462 2369 8011 5 A 2.8 4.2 18.6 69.3
Keeppower 18650 3100mAh 2012 @ Black Pan NCR 18650 A NCR SB 10.8 0.1 3100 2904 10357 2826 9608 2750 8981 5 A 2.5 4.2 18.6 69.7
Keeppower~(4.20vc) 18650 3200mAh 2014 @ Black LG ICR 18650 E1 ICR SB 7.5 0.14 3200 2613 9629 2623 9090 2612 8538 5 A 2.8 4.35 18.6 68.9
Keeppower~(4.30vc) 18650 3200mAh 2014 @ Black LG ICR 18650 E1 ICR SB 7.5 0.16 3200 2886 10704 2890 10048 2868 9386 5 A 2.8 4.35 18.6 68.9
Keeppower~(4.35vc) 18650 3200mAh 2014 @ Black LG ICR 18650 E1 ICR SB 7.5 0.15 3200 2833 10112 2823 9822 2782 9137 5 A 2.8 4.35 18.6 68.9
Keeppower 18650 3400mAh 2012 @ Black Pan NCR 18650 B NCR SB 11.5 0.09 3400 3211 11465 3130 10679 3046 9994 5 A 2.5 4.2 18.7 68.8
Keeppower 18650 3600mAh 2014 @ Black Pan NCR 18650 G NCR SB 11.4 0.09 3600 3289 11847 3197 11043 3090 10272 5 A 2.5 4.2 18.6 68.8
Kinoko IMR 18650 2250mAh 2013 @ Grey Pan CGR 18650 CH? Hybrid BT ~ 0.08 2250 2208 8050 2178 7700 2168 7466 10 A 2.5 4.2 18.3 67.2
LG 18650E1 LG DAME 11865 2011 @ Brown LG DAME 11865 2100 ICR FT ~ 0.06 2100 1985 7234 1931 6830 1845 6692 10 A 2.8 4.2 18.3 65
LG 18650B3 LG DBB 31865 2011 @ Salmon LG DBB 31865 2600 ICR LB ~ 0.12 2600 2471 9041 2427 8452 2420 8096 5 A 2.8 4.2 18.2 65
LG 18650C2 LG ABC 21865 2011 @ Orange LG ABC 21865 2800 ICR FT ~ 0.09 2800 2601 9795 2592 9381 2597 9077 5 A 2.8 4.3 18.3 64.9
LG 18650D1~(4.20vc) LG ABD 11865 2011 @ Pink LG ABD 11865 3000 ICR FT ~ 0.08 3000 2523 9393 2500 8932 2508 8650 5 A 2.8 4.35 18.3 64.9
LG 18650D1~(4.30vc) LG ABD 11865 2011 @ Pink LG ABD 11865 3000 ICR FT ~ 0.08 3000 2728 10281 2707 9797 2713 9489 5 A 2.8 4.35 18.3 64.9
LG 18650D1~(4.35vc) LG ABD 11865 2011 @ Pink LG ABD 11865 3000 ICR FT ~ 0.08 3000 2847 10751 2826 10251 2832 9933 5 A 2.8 4.35 18.3 64.9
LG 18650HE2 LG DB HE2 1865 2014 ~ Red LG 18650 HE2 IMR FT ~ 0.05 2500 2407 8752 2364 8464 2351 8289 20 A 2.8 4.2 18.3 65
Orbtronic IMR 18650 2250mAh 2012 @ Black Pan CGR 18650 CH Hybrid SB ~ 0.08 2250 2224 8114 2183 7737 2188 7559 10 A 2.8 4.2 18.3 66.9
Orbtronic 18650 PD 2900mAh 2012 @ Black Pan NCR 18650 PF NMC SB ~ 0.06 2900 2759 9970 2711 9518 2733 9354 10 A 2.5 4.2 18.4 66.7
Orbtronic 18650 3100mAh 2012 @ Black Pan NCR 18650 A NCR SB 11.4 0.1 3100 2923 10435 2849 9705 2784 9112 5 A 2.5 4.2 18.6 68.8
Orbtronic 18650 3600mAh 2013 @ Black Pan NCR 18650 G NCR SB 7.8 0.1 3600 3276 11784 3177 10918 3049 10050 7 A 2.5 4.2 18.5 69
Panasonic CGR 18650 AF ~ ~ Green Pan CGR 18650 AF ICR FT ~ ? 2050 ? ? ? ? ? ? 5A 2.8 4.2 18 65
Panasonic CGR 18650 CG ~ ~ Green Pan CGR 18650 CG ICR? FT ~ 0.12 2250 2192 7880 2180 7400 2140 6800 5 A 2.8 4.2 18.2 65
Panasonic CGR 18650 CH 2011 @ Grey Pan CGR 18650 CH Hybrid LB ~ 0.08 2250 2222 8114 2167 7679 2153 7430 10 A 2.8 4.2 18.2 65
Panasonic NCR 18650 A 2012 @ Green Pan NCR 18650 A NCR FT 6.2 0.11 3100 2923 10415 2832 9592 2707 8773 5 A 2.5 4.2 18.5 69.7
Panasonic NCR 18650 B 2012 @ Green Pan NCR 18650 B NCR FT 6.7 0.11 3400 3162 11254 3071 10398 2928 9491 5 A 2.5 4.2 18.6 70.3
Panasonic NCR 18650 B 2012 @ Green Pan NCR 18650 B NCR FT ~ 0.11 3400 3197 11472 3103 10727 3080 10296 5 A 2.5 4.2 18.3 65
Panasonic NCR 18650 BE ~ ~ Green Pan NCR 18650 BE NCR FT ~ ~ 3200 3064 ~ 2876 ~ ~ ~ 5 A 2.5 4.2 18.3 65
Panasonic NCR 18650 G 2013 ~ Green Pan NCR 18650 G NCR FT ~ 0.1 3600 3276 11784 3197 11043 3090 10272 7.2 A 2.5 4.2 18.6 65.2
Panasonic NCR 18650 PD 2012 ~ Green Pan NCR 18650 PD NCA FT ~ 0.07 2900 2850 10114 2750 9590 2740 9250 10A 2.5 4.2 18.3 65
Panasonic NCR 18650 PF 2013 ~ Green Pan NCR 18650 PF NMC FT ~ 0.06 2900 2759 9970 2711 9518 2733 9354 10A 2.5 4.2 18.3 65
Samsung~(4.2vc) ICR 18650-28A 2012 @ Purple ICR 18650-28A 2800 ICR FT ~ 0.12 2800 2405 8861 2374 8299 2354 7899 5 A 2.8 4.3 18.4 65
Samsung~(4.3vc) ICR 18650-28A 2012 @ Purple ICR 18650-28A 2800 ICR FT ~ 0.16 2800 2629 9813 2599 9197 2580 8750 5 A 2.8 4.3 18.4 65
Samsung ICR 18650-30A ~ ~ Purple ICR 18650-30A 3000 ICR FT ~ 0.15 3000 2577 9205 2492 8293 2951 10063 30 A 2.8 4.35 18.2 65
Samsung ICR 18650-30B ~ ~ Green ICR 18650-30B 3000 ICR FT ~ ? 3000 2918 ? 2859 ? 2849 ? 6 A 2.8 4.35 18.2 65
Samsung ICR 18650-26C ~ ~ Pink ICR 18650-26C 2600 ICR FT ~ 0.12 2600 2512 9197 2490 8597 2456 8028 5 A 2.8 4.2 18.2 65
Samsung INR 18650-29E 2014 @ Blue INR 18650-29E 2900 INR FT ~ 0.06 2900 2738 9925 2675 9405 2686 9164 7 A 2.8 4.2 18.3 64.9
Samsung ICR 18650-22F ~ ~ Green ICR 18650-22F 2200 ICR FT ~ 0.09 2200 2094 7682 2071 7263 2059 6935 7 A 2.8 4.2 18.2 65
Samsung ICR 18650-26F ~ ~ Pink ICR 18650-26F 2600 ICR FT ~ ? 2600 ? ? ? ? ? ? 5 A? 2.8 4.2 18.2 65
Samsung INR 18650-15M ~ ~ Blue INR 18650-15M 1500 INR FT ~ ? 1500 ? ? ? ? ? ? 20 A 2.8 4.2 18.2 65.1
Samsung INR 18650-20Q 2013 @ Green INR 18650-20Q 2000 INR FT ~ 0.05 2000 2002 7337 1959 7053 1962 6947 20 A 2.5 4.2 18.2 65.1
Samsung INR 18650-20R 2013 @ Green INR 18650-20R 2000 INR FT ~ 0.04 2000 2019 7220 1965 7107 1962 6995 22 A 2.8 4.2 18.2 64.9
Samsung INR 18650-25R 2014 @ Black INR 18650-25R 2500 INR FT ~ ~ 2500 2514 ~ 2451 ~ 2415 ~ 20 A 2.8 4.2 18.4 65.1
Sanyo ~ 2012 @ Red Sanyo UR 18650 FM ICR FT ~ 0.1 2600 2390 8960 2370 8519 2346 8130 5 A 2.8 4.2 18.5 65
Sanyo~(4.20vc) ~ 2012 @ Orange Sanyo UR 18650 ZT ICR SB 6.4 0.13 2600 2330 8597 2319 8074 2290 7537 5.2 A 2.8 4.3 18.5 70.1
Sanyo~(4.20vc)
2013 @ Orange Sanyo UR 18650 ZT ICR FT ~ 0.09 2800 2292 8519 2274 8063 2252 7682 5 A 2.8 4.3 18.2 65.1
Sanyo~(4.30vc) ~ 2013 @ Orange Sanyo UR 18650 ZT ICR FT ~ 0.09 2800 2505 9344 2488 8857 2470 8479 5 A 2.8 4.3 18.2 65.1
Sanyo~(4.20vc) ~ 2013 @ Magenta Sanyo UR 18650 ZTA ICR FT ~ 0.08 3000 2386 8820 2359 8297 2324 7852 5.8 A 2.8 4.35 18.3 65.1
Sanyo~(4.30vc) ~ 2013 @ Magenta Sanyo UR 18650 ZTA ICR FT ~ 0.12 3000 2625 9539 2602 9282 2563 8778 5.8 A 2.8 4.35 18.3 65.1
Sanyo~(4.35vc) ~ 2013 @ Magenta Sanyo UR 18650 ZTA ICR FT ~ 0.15 3000 2735 10311 2711 9727 2678 9219 5.8 A 2.8 4.35 18.3 65.1
Sony ~ ~ ~ Green Sony US 18650 GR ICR FT ~ ? 2550 2346 ? 2345 ? 2291 ? 5 A 2.8 4.2 18.3 65
Sony ~ 2014 ~ Green Sony US18650 VTC4 IMR FT ~ 0.05 2100 2021 7422 1969 7105 1964 6978 30 A 2.8 4.2 18.2 64.8
TrustFire TF 18650 2400mAh 2011 @ Flame ~ ICR SB 6.6 0.17 2400 1986 7027 1904 6238 1588 4881 5 A 2.8 4.2 18.5 68.5
TrustFire TF 18650 3000mAh 2012 @ Flame ~ ICR SB 7.4 0.13 3000 2514 9242 2508 8698 2478 8108 5 A 2.8 4.2 18.4 68.8
Xtar 18650 2250mAh 2013 @ Black Pan CGR 18650 CH? Hybrid SB ~ 0.08 2250 2151 7846 2122 7501 2105 7246 10 A 2.8 4.2 18.4 66.6
Xtar 18650 2600mAh 2013 @ Black Sanyo UR 18650 FM ICR SB 6.2 0.12 2600 2506 9189 2488 8601 2458 8023 5 A 2.8 4.2 18.6 68.8
Xtar 18650 3100mAh 2012 @ Black Pan NCR 18650 A NCR SB 6.6 0.13 3100 2869 10184 2774 9267 2471 7863 5 A 2.5 4.2 18.5 69
Xtar 18650 3400mAh 2012 @ Black Pan NCR 18650 B NCR SB 6.3 0.12 3400 3168 11251 3076 10351 2880 9265 5 A 2.5 4.2 18.6 69
26650 Cells
Brand~~~~~ ~Label.Description~ Tested Review Wrapper Cell.Description Chem Top PCB IR(ohms) MFG.mAh mAh@1A mWh@1A mAh@3A mWh@3A mAh@5A mWh@5A Max.Dis V.Min V.Max Dia Len
Efest IMR 26650 3000mAh 2012 @ Blue ~ IMR FT ~ 0.06 3000 2509 9679 2523 9463 2528 9265 15 A 2.8 4.2 26.2 65.2
Efest IMR 26650 3000mAh 2014 @ Red ~ IMR BT ~ 0.06 3000 3371 12536 3351 12210 3339 11943 15 A 2.8 4.2 26.5 66.4
EnerPower 26650 4500mAh 2012 @ Blue TENSAI TN26650 ICR LB 8.4 0.07 4500 4698 17107 4593 16216 4590 15725 7 A 2.8 4.2 26.5 68.4
Keeppower IMR 26650 3500mAh 2014 @ Black MNKE IMR LB ~ 0.06 3500 3487 12964 3466 12596 3453 12290 20 A 2.8 4.2 26.6 67.7
Keeppower 26650 4000mAh 2012 @ Black ~ ICR LB 15.1 0.08 4000 4287 15579 4193 14740 4214 14334 10 A 2.8 4.2 25.6 70.7
Keeppower 26650 4000mAh 2014 @ Black King Kong ICR LB ? 0.1 4000 4254 14901 4212 14685 4201 14410 10 A 2.8 4.2 26.7 69.7
Keeppower 26650 4500mAh 2014 @ Black HT ICR 26650 ICR LB ? 0.1 4500 4740 17234 4669 16406 4723 16019 10 A 2.8 4.2 26.5 69.6
Keeppower 26650 5200mAh 2014 @ Black ~ ICR LB ~ 0.07 5200 5159 18781 5090 17977 5095 17453 15 A 2.8 4.2 26.3 67.3
Keeppower 26650 5200mAh 2014 @ Black ~ ICR LB 9.4 0.09 5200 5143 18646 5086 17729 5074 16985
2.8 4.2 26.4 71.7
King Kong INR 26650E 4000mAh 2012 @ Gold ~ INR LB ~ 0.08 4000 4235 15460 4127 14651 4141 14327 15 A 2.8 4.2 26.2 68.2
King Kong ICR 26650 4000mAh 2012 @ Gold ~ ICR FT ~ 0.05 4000 4346 15862 4224 14966 4223 14553 10 A 2.8 4.2 26.3 65.7
King Kong ICR 26650 4200mAh 2013 @ Gold ~ ICR FT ~ 0.05 4200 4412 16097 4314 15388 4314 15077 10 A 2.8 4.2 26.2 65.8
Sony 26650 2600mAh 2013 @ Green SE US 26650VT ? FT ~ 0.04 2600 2559 9544 2495 9175 2470 8963 30 A 2.8 4.2 26.2 65.4
Soshine 26650 4200mAh 2013 @ Black ~ ICR LB 7.9 0.09 4200 4343 15749 4245 14859 4258 14373 7 A 2.8 4.2 26.3 71.1
TrustFire TF 26650 5000mAh 2012 @ Flame ~ ICR FT 6.9 0.12 5000 4263 15645 4196 14546 4075 13311 5 A 2.8 4.2 26.2 68.2
TrustFire TF 26650 4000mAh 2012 @ Black/Sil ~ ICR SB 6.9 0.12 4000 3238 12217 3224 11479 3172 10663 5 A 2.8 4.2 26.2 70.5
UltraFire UF 26650 5000mAh 2012 @ Flame ~ ICR FT 5.9 0.08 5000 4109 14900 4019 14039 3989 13397 5 A 2.8 4.2 26.7 68.9
Xtar 26650 4000mAh 2013 @ Black ~ ICR LB ~ 0.06 4000 4267 15560 4174 14851 4207 14641 10 A 2.8 4.2 26.2 67.7
NiMH Cells
Brand~~~~~ ~~Label.Description~~ Size Tested Review ~~Wrapper~~ ~Chem~ Top MFG.mAh mAh@1A mWh@1A mAh@2A mWh@2A mAh@3A mWh@3A mAh@5A mWh@5A Max.Dis V.Min V.Max Dia Len
Eneloop BK-4HCC 900mAh AAA 2014 @ Panasonic-Black NiMH~LSD BT 900 865 1028 809 908 738 790 ~ ~ 3 A 0.9 1.45 10.2 44.2
Imedion Imedion 950mAh AAA 2014 @ Black/Silver NiMH~LSD BT 950 885 1058 857 969 815 886 ~ ~ 3 A 0.9 1.45 10.3 44.2
Powerex Powerex 1000mAh AAA 2014 @ Black/Silver NiMH BT 1000 898 1061 854 958 807 868 ~ ~ 3 A 0.9 1.45 10.2 44.2
Eneloop HR-3UTGB 1900mAh AA 2013 @ Eneloop-White NiMH~LSD BT 1900 1823 2254 1790 2142 1763 2049 1718 1894 10 A 0.9 1.45 14.2 50.2
Eneloop BK-3MCC 1900mAh AA 2014 @ Panasonic-White NiMH~LSD BT 1900 1858 2294 1826 2185 1804 2100 1766 1958 10 A 0.9 1.45 14.2 50.2
Eneloop HR-3UWXB 2450mAh AA 2013 @ XX-Black NiMH~LSD BT 2450 2402 2968 2366 2823 2336 2698 2265 2466 10 A 0.9 1.45 14.3 50.1
Eneloop BK-3HCC 2450mAh AA 2014 @ Panasonic-Black NiMH~LSD BT 2450 2401 2982 2367 2848 2342 2735 2286 2529 10 A 0.9 1.45 14.4 50.3
Imedion Imedion 2400mAh AA 2014 @ Black/Silver NiMH~LSD BT 2400 2228 2720 2189 2582 2152 2464 ~ ~ 7 A 0.9 1.45 14.3 50.2
Fujitsu HR-3UTHA 2400mAh AA 2014 @ Silver NiMH~LSD BT 2400 2366 2924 2329 2786 2297 2668 2237 2463 10 A 0.9 1.45 14.3 50.2
Powerex Powerex 2700mAh AA 2014 @ Black/Silver NiMH BT 2700 2464 3030 2422 2877 2383 2742 ~ ~ 7 A 0.9 1.45 14.4 50.3
Tensai TR-6 2000mAh AA 2013 @ White NiMH~LSD BT 2000 2178 2600 2083 2376 2012 2212 ~ ~ 5 A 0.9 1.4 14.3 50.3
Tensai Plus TR-6H 2500mAh AA 2013 @ White NiMH~LSD BT 2500 2378 2833 2309 2622 2221 2424 ~ ~ 5 A 0.9 1.45 14.4 50.6
Primary Cells
Brand~~~~~ ~~~Label.Description~~~~ ~~Size~~ Tested Review ~Wrapper~ ~Chem~ Top mAh@0.5A mWh@0.5A mAh@1A mWh@1A mAh@2A mWh@2A mAh@3A mWh@3A mAh@5A mWh@5A Max.Dis V.Min V.Max Dia Len
Duracell Plus Power AA AA 2013 @ Black/Gold Alkaline BT 1506 1692 1097 1155 785 748 599 534 ~ ~ 3 A 0.7 1.6 14 50.3
Energizer Ultimate Lithium AA AA 2013 @ Silver Lithium BT 3076 4162 3016 3834 2800 3217 2480 2769 ~ ~ 3 A 0.7 1.8 14 50.1
Nice Lithium AA AA 2013 @ Blue/Sil Lithium BT 2878 3744 2759 3038 2707 3032 2582 2740 ~ ~ 3 A 0.7 1.8 14.1 50.1
Panasonic Evolta AA AA 2013 @ Blue/Gold Alkaline BT 1113 1327 781 880 639 657 542 517 ~ ~ 3 A 0.7 1.6 13.9 50.1
Panasonic Pro Power AA AA 2013 @ Black/Gold Alkaline BT 1290 1527 1013 1118 800 815 657 606 ~ ~ 3 A 0.7 1.6 13.9 50.1
Duracell Plus Power AAA AAA 2013 @ Black/Gold Alkaline BT 612 672 449 454 298 274 ~ ~ ~ ~ 2 A 0.7 1.6 10.1 44.3
Energizer Ultimate Lithium AAA AAA 2013 @ Silver Lithium BT 1198 1507 1053 1171 744 707 199 165 ~ ~ 2 A 0.7 1.8 10.2 44.2
Panasonic Pro Power AAA AAA 2013 @ Black/Gold Alkaline BT 443 504 319 341 ~ ~ ~ ~ ~ ~ 1 A 0.7 1.6 10.1 44.3
Panasonic PhotoPower CR123A CR123A 2013 @ Red/Gold Lithium BT 1549 3732 1450 3180 1184 2311 602 1179 ~ ~ 3 A 1 3.2 16.4 34.1
Panasonic Industrial Lithium CR123A CR123A 2013 @ Black/Sil Lithium BT 1580 3675 1556 3239 1343 2412 758 1469 ~ ~ 3 A 1 3.2 16.6 34.3
Key to charts
Chem = Cell Chemistry
Top = Small Button, Large Button, Flat Top
PCB = Protected Cell, Protection Trip Current
IR(ohms) = Cells Internal Resistance
MFG.mAh = Manufacturers Stated Capacity
mAh@1A = Measured Capacity at 1 Amp Continuous Discharge
mWh@1A = Measured Energy at 1 Amp Continuous Discharge
mAh@3A = Measured Capacity at 3 Amp Continuous Discharge
mWh@3A = Measured Energy at 3 Amp Continuous Discharge
mAh@5A = Measured Capacity at 5 Amp Continuous Discharge
mWh@5A = Measured Energy at 5 Amp Continuous Discharge
Max.Dis = Maximum Capable Discharge Level in Amps
V.Min = Fully Depleted value of cell in volts
V.Max = Fully Charged value of cell in volts
Dia = Cell Diameter in millimeters
Len = Cell Length in millimeters
Cell Chemistries
ICR = Lithium Cobalt oxide positive electrode (LiCo)
IFR = Lithium Iron Phosphate (LiFePo4)
IMR = Lithium Manganese oxide positive electrode (LiMn)
INR = Lithium Nickel oxide positive electrode
NCA = Lithium Nickel Cobalt Aluminium oxide
NCR = Lithium Nickel Cobalt?
NMC = Lithium Nickel Manganese Cobalt oxide
Hybrid = Hybrid Technologies?
This is going to come in very handy for me. Thank you for all the hard work.
Great information, thanks for sharing!
Wow, very helpful charts, thanks!
I’d like to point out that Ultrafire and Trustfire have no consistency, they are made by so many companies and knockoffs that two samples from the same store purchased in the same order could vary by 90% in capacity and build
btw Thanks for the chart, i hope your able to keep it updated over time because it would be a valuable resource
Thanks for posting this, it’s a very nice overview. Can you maybe post it in some format that can be imported in a spreadsheet as well? That would make it easy to sort on specific colums etc.
While quickly checking a few things I noticed a couple of typo’s:
AW Black 14500 should have 2.281Wh@2A (2 digits have been swapped). The number shown right now is higher than @1A.
The Magneta colour of the Sanyo UR 18650 ZTA could be very nice though :slight_smile:
You're a hero, crx, this is a very helpful chart. I hope this chart stays around some way, so that it keeps being updated.
Panasonic NCR18650 PF has green wrapper color (it was grey in the beginning)
Is it possible to post this in another format here other than images, i don’t know?
Well spotted, it’s still a work in progress so if you see any other mistakes let me know,thanks.
Inserting a table could be a possibility. It seems to use | as a separator. Copying cells from a spreadsheet usually uses tabs as column separators. So replacing those with | and adding one at the start at end of each line might not be too much work. You could use a spreadsheet function like concatenate to create the text for 1 row in the spreadsheet as well.
Brand Colour Cell Description
AW Blue ICR 10440
Efest Black IMS 10440 (V1)
If you quote this post, you can probably see the text I entered to generate this table. It seems to require an empty line after the table to mark the end of the table.
It is possible to copy/paste directly from a spreadsheet, but you loose some of the formatting.
Here is a example (Original can be found in my charger reviews):
Supported battery types
Type Chemistry Nominal Voltage Charge voltage Supported
ICR LiCoO2 3.6/3.7 volt 4.2 volt Yes
IMR LiMn 3.6/3.7 volt 4.2 volt Yes
IFR LiFePO4 3.2/3.3 volt 3.5/3.6 volt Yes
If you know html you can also make it directly in html and insert it (Press "Disable rich-text" first).
Thanks for the tips, it’s starting to take shape now.
Incredible! Thank you. Did you parse the data manually, or did you use a tool to scrape the data?
VERY nice work my friend. Thanks for doing this. Of course a BIG thanks to HKJ for all of his hard work also.
I made a spreadsheet using open office and typed the data in manually from looking at HKJ’s reviews.
Sorry to bring back an old post but was wondering if there were plans to add more batteries to this op. I find this post very useful whenever I am shopping for batteries.
That’s great you find this useful, i do try to keep the charts fairly up to date with the newer good quality cells information after HKJ has reviewed them.
I’m planning on another update sometime this week :wink:
Sweet! Thanks CRX
What’s the consensus on these ?
Couldn’t find any matching info.
They are on the chart above Samsung ICR 18650-26F. I have some of these from a laptop pool. If you can get past the color these are pretty good cells for the money.
