I signed up for BLF last year because I wanted to build a light for finding amber at the sea. (slowly turning into a flashlight-oholic)
At that time, I realized I did not have the skills for building one myself. Instead, I bought a p60 drop-in with a LedEngin 365nm, and got a C8 size 400nm from fellow BLF member djozz.
Since then I learned a bit more about building and modding lights. Especially the “hands on” parts is no problem. I have built two zoomies with Ir-LED’s, and one Convoy with a normal LED. Therefore, reflowing and soldering is no problem.
However, I still find it hard to figure out the theoretical and technical stuff (divers, PCB, MCPCB, etc)
Therefore, what I need help for is finding the parts for the light – I’ll do the assembly/modding myself.
I have been researching a lot, and have many ideas for hosts and LED, but I don’t know which parts to buy, to make it all work.
What I want to build is a light with:
- Mininimum three uv LED’s, and a maximum of six. In the range from 390-405nm
- Water resistant (not waterproof, just to be able to use it in rainy weather).
- No need for long throw – more like a lot of flood within 3-6 meters
- Fairly easy to mod - has available parts - has been modded by others here on BLF
- A budget of max 150 dollars
I don’t care if the light has internal or external batteries or if its 18650 or 26650.
I don’t care how the host looks, as long as it’s fairly portable. So the host could be something like:
Normal flashlight:
Bicycle light:
Motorcycle light:
Lightbar: (for a car)
Light pod:
I actually found this light (click image for link):
that more or less fits my requirements – but I would rather try building one myself.
I also found these LED’s:
SemiLEDs True Violet UV LED (400-410nm)
395-400nm Purple Light LED Emitter w/ 20*1.5mm Board - 3.5-3.6V / 700mA
395-400nm Purple Light LED Emitter w/ 16*1mm Board - 3.5-3.6V / 700mA
Led Engin LZ1 U6 400nm-405nm Violet 5W LED (you can choose MCPCB at the bottom )
7W Tri-Core High Power Violet LED 395-400nm
5W Dual Core High Power Violet LED 395-400nm
Does anyone want to help me, and be my “project manager”
(pic from the link)
