I bought this light from a US seller. On Ebay - Seems like more lights are now being shipped in the US, by Chinese sellers with US contacts.
It has an Aluminum bezel and button. The finish is ok. About as good as any other SRK.
The reflector looked good and it was pretty clean.
The tail cap is not glued on. It came off easily.
Same driver as another SRK 3-up that I got a while ago.
Same single FET. Small wire diameters.
The top end. Four XM-L T6 on a single star, glass lens and O ring.
I do not like these tall locaters. It seems like they are trying to direct the light. It doesn't work that way too well.
I just removed the resistors, like I did on the other driver.
I added a Copper disc between the star and the led plate. I also beefed up the wires to 18ga.
I sanded down the locaters till they were flush with the bottom of the reflectors.
I measured amperage with my digital meter and all I could get was about 8-9 amps. I should have done it with the analog meter that has heavy wires. The digital one has thin leads.
This was just a quickie. Stock, it wasn't all that bright. I didn't read amperage stock.
All in all, it's at least a way to get a 4up SRK within the US, so shipping is fast, but it needs to be modded.
