Well, 2.0 isn't finalized, but I have it on my KR4 and it works wonderfully and you can build it yourself -- just do the following in an Ubuntu or Debian VM.
I donāt have many tools to do this, I do have avrdude to flash the file, but not tools to build the files. Iāll wait until someone makes this available for the more casual user.
So I bet the answer is in here somewhere, but I could not find it. How does one use the resolution of the voltage correction factor to 0.05V? All my lights with Anduril2 only give a value to 0.1V, not sure how / why there is the ability to enter a value to 0.05V? Perhaps some lights provide that extra digit of resolution?
I think I answered my own question. My Q8 measures 3.6 during battcheck, but he cells are at 3.52. So I went into battcheck configuration mode, and lowered the measurement by 0.05V. Now battcheck produced 3.5V for the measurement. The 0.05V steps allow a bit more resolution to the adjustment, and I finally figured out how to use that.
Are you expecting Battery Check to blink a number down to a resolution of 0.05V? E.g. 4.15V
Battery check:
Blinks out the battery voltage per cell. Full is 4.2V, empty is
about 3.0V. The light blinks the whole-number digit first, pauses,
then blinks out the "tenths" digit. Then a longer pause, and it
repeats.
So for 4.2V, it would be "blink-blink-blink-blink .. blink-blink".
A "zero" digit is represented by a very quick blink.
The voltage config menu has one setting:
1. Voltage correction factor. This adjusts the battery
measurement sensor, allowing the user to add or subtract up to
0.30V in 0.05V steps. Click N times to enter a value:
1C: -0.30V
2C: -0.25V
3C: -0.20V
4C: -0.15V
5C: -0.10V
6C: -0.05V
7C: default, 0V
8C: +0.05V
9C: +0.10V
10C: +0.15V
11C: +0.20V
12C: +0.25V
13C: +0.30V
Do you need to define BATTCHECK_4bars, BATTCHECK_6bars, BATTCHECK_7bars to adjust the readout style?
No, I wasnāt expecting my lights to do that (unless it was an upgrade via Anduril2), I was more wondering the utility of the 0.05V resolution, then when I went to use it I figured it out.
But I will admit I would be interested in having the extra digit of resolution. I donāt think its really that valuable from a user point of view, but the geek in my would love it.
Iām not interested in brewing my own code to get it, each time I flash my lights its an adventure.
Does anyone know what the voltage readout specifications for the ATtiny processors used with Anduril are?
Has anyone tested the processor's voltage readout for accuracy, resolution and consistency across the usuable voltage range using an accurate bench power supply?
When I tested the battery voltage values returned by my Anduril lights from the "triple click voltage query"; the points where the values changed by 0.1 volt were surprisingly consistent from fully charged to the low voltage cutout when compared to the correct voltages. The only issue has been that the voltage values for an individual light are sometimes also consistently off by up to 0.2 volts from the correct voltage.
My inexpensive bench power supply is not accurate enough for testing, so the way I tested was to do a series of separate tests over time by charging many batteries with an analyzing charger to slightly different voltages and after at least a 24 hour rest I selected a series of batteries that were 0.01 volts apart based on readings from my Fluke multimeter and then tested those batteries in my lights to determine the actual voltage where the light's voltage readout changed by 0.1 volts.
I have over a dozen Anduril lights and knowing how far off each of their voltage readouts is has been helpful to me.
Since the processor's voltage readout can be calibrated with newer versions of Anduril and if the voltage readout was sufficiently accurate to within 0.02 volts or so and consistent across the usable voltage range, to avoid wondering if a 3.6 voltage readout from the light is actually closer to 3.5 or 3.7 volts, I would welcome an Anduril voltage query that reported out to two decimal places using three sets of blinks instead of to one decimal place using two sets of blinks.
Are you aware about voltage sag? I.e. if you draw 1A from 4V battery you get 3.8V (just an example). The voltage returns to 4V after some time after current draw is stopped. Faster for newer battery and slower for older. I donāt see any added value in more digits in voltage check since it depends so much on battery condition.
Hi! I started with a FW1A a few weeks ago and quickly moved onto a KR1 (and have already vowed to never again purchase a non-ISP light).
Anduril2 on the KR1 is using only about half of the firmware space on its 1634, so I've been playing with adding additional strobe modes, etc. For example, I have a strobe that flashes at both the party-strobe frequency and the tactical-strobe frequency (i.e. it normally flashes at 50%, but flashes at 100% when the two cycles happen to overlap). I also have a fun mode where it will flash any pattern compiled into the binary.
However, I'm finding that going from 5 flash modes to 7 (or more) is annoying if you're already familiar with the classic 5 strobe modes. What do people think of having two groups of flash modes (i.e. the classic ones and auxiliary ones), and having 3C alternate between them? This way, the current Anduril2 behavior would be unchanged unless you happened to 3C from within strobe mode. (Of course, once you're within auxiliary strobe modes, 2C would cycle amongst them and 3C would return to the main set of strobes.)
