Shots are only on close range (started snowing more), so they are good for comparing output and beam size, not so good at comparing throw.
Im standing at an elevated position (around close to 3m off the ground.) The green thing you seen in the pictures are a compost bin ,1meter tall and 75cm wide,.
Camera settings:
1s, F5,7, ISO400, 5200K, 17mm focal length on APS-C
All lights are heavily modified, all use copper mcpcb and have various tweaks. All lights with several emitters have a mixed emitter setup.
More info about the following lights here:
Direct drive MT-G2 (The Switch killer aka single TR-J18 thrower)
SRK, 9,3A total, kinda leans leans towards being slightly warm with that emitter setup.
Next is actually a Supfire M6 with SRK reflector. More oomph going to each emitter than the typical SRK, but less then my other king. It may look a bit dim (partially because its spill does not hit as much snow in the foreground), but its a really usable beam with good range, and wide spill. I would say its nicer than the picture shows.
My STL-V6 had a hollow pill, not anymore. Regulated at 5,2A. (Its now sold, but it was a nice light.)
Regulated at 6,4A.. Oh yeah. (whoops, 2U bin not "U1" :p )
Pushing more than 9A to an MT-G2 in the shot below..
By looking at the spill you can seen the slight yellow-almost "greenish" tint from the de-domed emitters, and the cold CW on right. But the mix is nice white light. :) This effect is not as visible in real life as on the picture. But a large triple like this will show the effect much better than any other light. Normally I put the cool emitter up, and then I don't notice the difference between those.
Time for the beast! Tint is awesome and throw is way better than stock. This light actually have very good range.
Some mouse-overs, pictures from above:
9XM-L vs Lustefire triple
9XM-L vs direct drive MT-G2
MT-G2 vs SRK triple XP-G2. An interesting comparison, before you say that MT-G2 lights kicks ass. Also consider, that it consumes more than twice the power, its twice as long, wider, have around half the battery capacity, but the triple XP-G2 slightly out throws it, and have more spill, and can easily have a better UI. Not saying one is better than the other, it depends on what you are after, but just shows how different lights can be built. The MT-G2 light is very impressive at close range to medium range.
If you want to see a certain mouseover comparison, say so. But you can also download two pictures and compare them yourself. Again, considering the wide angle shot and location, these are not the best shots for comparing throw. More lumens will easily look better here. Currently my favorite are probably the Lustefire triple. Its a thrower than can play with the big output lights as well. They are all great in their own way.
My previous beamshot comparison (Mostly completely different lights, or modded differently)
