This is just a copy of user Wormminator’s post here, with minor reformatting. I don’t trust reddit to keep it up forever and find reddit posts difficult to search for, so I’m making a copy here on BLF to make this remarkable work more visible.
This chart is not intended to compare different emitters or lights, it is intended to show the (sometimes major) differences between five spectrometers:
- Opple Light Master 4
- LitDuo (0.9 beta 4)
- Hopoocolor HPCS-330P
- Hopoocolor HPCS-330Pro
- Sekonic C-800
The brightness was set to the declared level to not overwhelm the poor Opple. I used a tripod + claw to hold each light in a fixed position for comparable measurements. Roughly 215mm away from the sensor.
DUV measurements were rounded to a 4 decimal place format. In the case of the LitDuo a 0 was added to the end to match the rest. I have now expanded results to include TM30 (Rf/Rg) for the HPCS-330Pro and the C-800. Further additions are the LitDuos 0.9 beta 4 firmware and the aforementioned Hopoocolor 330Pro.
This chart is a reboot of the previous 3 posts. Almost the same lights, replaced one and did minor modifications to some between the last post and todays.
Since I have re-measured the lights again, this chart IS NOT comparable with the previous 3 versions. These are new sets of data, taken at possibly different distances and slightly different angles, with different brightness levels.
The important piece still remains: The difference between each set of the same measurements.
Previous rounds:
A few notes:
The LitDuos DUV measurements seem a bit off. A lot 0.0020 and 0.0030 results. Overall accuracy seems to be improved though. I am not convinced that it is accurate. 3 other devices disagree with it regularly while agreeing with each other.
High CCTs result in quite the gap between all units, while the lower the CCT gets the more every unit agrees with each other.
I have no idea if this is useful to anyone, so only one more round is planned once the 1.0 version of the LitDuos firmware is released.
I also can not tell anyone if any of these are “worth it”. For a rough idea the LM4 is still fine. Anything else is up to you. I would not recommend buying a spectrometer. But if you want one, this chart may help you.
I happened to find a few spare hours of time so figured I may as well do this now.
I just hope I did not miss anything as Im constantly tired. This is a re-post of an earlier attempt. Corrected 1 mistake (thank you excel and your CONSTANT need to change the users input WITHOUT any prompts) and also because reddit assumed that resolutions above 240 horizontal pixels are not important.
Thank you for reading and hello BLF,
-Waldherz
