This is a compilation of various material I find useful for understanding the theoretical foundations of a flashlight’s function. Some of these pages are not on the mainstream radar and difficult to search for, hence this post.
Being a somewhat self-centered individual, many of these are within my scope of interest/knowledge (or even my own threads); this unfortunately means the exclusion of many excellent pages on topics I know little about (e.g., drivers and circuits). On the bright side, it also means that I can personally vouch for the accuracy/utility of items on this page.
Hope the broader community also finds this page helpful, either as a quick reference or a gateway to doing flashlight theory research yourself. Feel free to suggest more pages you find helpful!
Note: authorship is indicated by [author] rather than @author, to circumvent BLF’s limit of 10 mentions per post.
Citable data sources and general interest
- [1Lumen]'s comprehensive library of well-controlled flashlight reviews, with extreme throwers measured using proper methodology.
- [grzybek337]'s Fantastic collection of well-controlled beamshots and tests of different configurations of the same light.
- [koef3]'s library of detailed LED performance tests.
- [djozz]'s library of detailed LED performance tests, focusing on older and unusual emitters.
- [mcjtom]'s visual map of flashlights based on output and throw, great for quick comparisons.
- A repository of Old Lumens contest builds–there is much to learn from the build threads!
Beam profile and general optical design
- A calculator for the collection efficiency of reflectors and lenses.
- An illustrated clarification of the terms “hotspot, corona, spill”, plus rough estimation formulas.
- [Probably]'s extremely comprehensive physics-engine simulator for reflector beams.
- A reflector beam profile calculator. Less comprehensive than the simulator but simpler/faster, accuracy validated by the simulator.
- A similar beam calculator, verified accurate for lenses and recoil reflectors but not standard/forward reflectors.
- An easy-to-use ray-tracing tool (Phydemo) for simulating all sorts of reflectors and lenses.
- An extremely comprehensive/advanced optical design tool–thank you @Enderman for the suggestion!
- A set of very clear expository slides on optical elements in a flashlight.
- A catalogue of Convoy’s 21mm S21E TIRs, with photos and beamshots.
Results relating to throwers
- A basic expository article (translated from TLF) on what features of a reflector/optic affects throw.
- A simple ballpark throw estimate for any light.
- Throw calculator given LED+reflector parameters.
- [Enderman]'s technique of collimating extreme throwers at a finite distance.
- A quantitative answer to a common question: how do a reflector’s depth and diameter affect throw?
- A formula relating candela, lumens, and beam angle in a uniform beam.
- [DrJones]'s clear explanation of why dedoming changes CCT and throw. A shorter/illustrated version here.
- [Enderman]'s map of extreme throwers–see where yours stands!
- Real-world throw calculator that accounts for atmospheric scattering, which becomes significant at 1km+ distances.
Colorimetry and photometry
- [SyntheticSol]'s incredibly comprehensive tool for digitizing a spectrum from an image file and generating a color report.
- [fizzgig]'s dedicated spectrum analyzer (hcri.io) with a repository of user-submitted spectra.
- [Wormminator]'s comparison of 5 spectrometers and [mcjtom]'s statistical analyses of results and related discussion, to help you decide how much to trust the readings.
- [zeroair]'s reviews, a great source for color measurements of mainstream lights.
- Study on adding a dome to a flat LED to adjust CCT and tint.
- A simpler, more precise alternative to “integrating shoebox” for measuring total output.
- Attempted digest of a paper proposing a new geometric model for color space, which contains enough differential geometry to give me indigestion.
Miscellaneous projects
- An analog battery indicator using the correspondence between Vf and color.
Tools/applications pending peer review
Authored by [six7]:
- Ray-tracer/optical design tool.
- Spectrum mixer/analyzer.
- Driver for X-Rite i-1 spectrometer.
- Simulator of how Lee color filters interact with various LEDs.
