Excellent thank you. FWIW, the 10 degree has plenty spread. The 60 degree would be closer to a light bulb.
Thanks again.
Thanks again.
Thanks very much for your effort on comparing optics, Cannga. Iâve got IF25 and Iâm on the fence of buying S21D 219B. How is the throw of 219B compared to SST20 under the same lens?
Very welcome guys. Once I loved Sofirn IF25a so much I bought two. Among my small lights, IF25a if a little âindustrialâ looking is otherwise similar to Emisar D4V2: best form, best âsolidness,â best fit in hand, best button. Then I went into Nichia and CRI/R9 madness, and havenât used the Sofirn much since :person_facepalming: .
When it comes to brightness and throw the Sofirn IF25a with SST20 4000K wins. When it comes to beam color/tint/beauty, then itâs all over, Nichia by TKO in first round. SST20 4000K looks very green in comparison and once seen, cannot be unseen. I would very highly recommend you give S21D 219b 4500K a try, and maybe ask Simon for a gift: 10 Clear and 30 Bead pair with the light (pls donât tell him I said this - grin). IMHO getting a 219b 4500K light is THE ânext stepâ for anyone new to this hobby.
Throw numbers - I just freshly learned how to do just yesterday, your question gave away my secret lol. Thank goodness my numbers seem to come very close to those of more experienced reviewers. I will post throws for all 5 optics for Convoy S21D later. Note that in real life use, good visibility for me is about 1/3 to 1/4 of throw numbers, meaning neither of these lights is what I would call a âthrower.â
IF25a w/ Luminus SST20 4000K LED: 246m
Convoy S21D w/ Nichia 219b 4500K LED: using same Sofirn optic 170m
Thanks for the throw numbers. I didnât expect that youâd have them in numbers, so thatâs even a plus for me.
After seeing Simon having 10 Clear lenses for sales, I was kind of thinking that it was the same lens as IF25 as appearance-wise they look very identical, but as youâve tested, theyâre not.
Think I will go for 10 Clear and 30 Bead pair.
Not sure if youâve already written somewhere, but if you were to choose just one emitter, which would you choose between 219b 4500k and 519a 4500k?
Just to clarify (if you already know then never mind/ignore this): First, the Convoy 10 Degree Clear optic is actually very similar to the Sofirn 10 Degree Clear optic. And second, the Sofirn flashlight has better throw mainly because of the LED (Luminus SST20), NOT the optic or the lens. In other words for this comparison a. the optics are the same and b. the lens is only very slightly different (AR vs non AR), therefore the cause of the difference is the LED â->Luminus SST20 has better brightness and throw than Nichia 219b. But yes, bottom line is 10 Clear + 30 Bead optic pair is a good start for S21D.
My order of choice would be:
1. 219b 4500K
2. 219b 3500K
3. 519a 4500K
Head to head comparison 519a is colder (higher CCT) and more greenish (more positive Duv), whereas 219b 3500K is warmer (lower CCT) and more rosy/reddish (more negative Duv). My order is that way NOT because one LED is âbetterâ than the other, just that the 219b 3500K has a unique and beautiful beam color with its warmth, saturated look, and rosiness. Simply put I just like it almost better than all other lights I have. Until proven other wise (because of personal preference or whatever), I personally would explore all CCTâs of 219b first before I venture to other Nichiaâs. Very subjective and IMHO (emphasized the O); you canât go wrong with either.
Thanks a lot.
If you follow this thread from beginning, you would see my own progression from newbie, to Olightâs green hell, Nichia, then finally these very interesting measurements and comparisons with the great Opple Light Master Pro. Iâve learned a lot thanks to BLF.
Followed are throw measurements of the Convoy optics. For anyone new to this like me, throw measurement essentially reflects how bright the hotspot/central brightness is and more or less âignoresâ the flood component of your beam. You put a light sensor some distance away, in my case 6 meters, place the flashlight so the center hotspot lines up exactly with the sensor, then measure the brightness 30 seconds after a âTurboâ start. Lights with higher central brightness win.
The progression from high throw numbers to low throw numbers means central hotspot brightness decreases obviously, but⌠peripheral brightness increases. Thatâs the trade-off (thereâs a price to pay for every thing in flashlights ).
1. Sofirn Clear 10 Degree 170 m
2. Convoy Clear 10 Degree 170 m
3. Convoy Beaded 10 Degree 157 m
4. Convoy Beaded 30 Degree 144 m
5. Convoy Beaded 60 Degree 113 m
The Sofirn 10 Clear is a touch brighter than Convoy 10 Clear photographically (I could eyeball brightness with my RAW software - will post pics later) but the two measure identically, confirmed with multiple attempts.
I have no picture to post, but followed is a shot of my most favorite place to visit, Italyâs Cinque Terre - @Argo.
Considering the timing, you ramped up extremely quickly. But then, you also benefit from a major mother lode of info & choices today (when I started it was a painfully anemic playing field and back then there was zero luxury on being tint picky). Some newbie people on BLF went crazy and bought up like every light they could find that had any appeal, but you seem to have been more methodical on your progression. Iâve actually learned a good bit from your explorations because you document them well. Thanks!
If you had it to do all over again, which two lights would you pick up first this time around?
EDIT: This post will be updated many, many times as Iâve decided to pin it to my signature and will update it whenever I have more measured data or more experience with other lights.
I love this kind of question because it forces me to think about what is most useful and what is most fun in this hobby for me. Two lights is not enough and life is short so I really need to have 4. And were I to start new today they would be as followed. (EDIT: please donât be surprised if there are changes in this list. Mistakes discovered, knowledge improves, opinions change, etc.)
1a. Convoy S21D with Nichia 219b 4500K HERE. For me, the gold standard for objective CRI & R9 accuracy, and subjective color rendition that all other LEDâs should be compared to. For those into photography, Nichia 219b 4500k is the LED that creates the most âpopâ in pictures. Other than the fact this is a short range floody light (not a thrower), it is the first LED/light to buy in a collection if color accuracy is a priority. This floody beam is absolute perfection for work around the house (throw light is blinding for close up work). And the rosy tint is most beautifully appreciated in the even spread of a floody beam, so yes IMHO S21D is the perfect host for 219b. Note IMHO this is THE first light to buy for hobbyists who are OCD about color accuracy, but not necessarily muggles. Muggles who care more about output and throw will not appreciate this light. For those I think you would give 1b, Wurkkos TS30S.
EDIT: Convoy M21H with 3 critical features not found in S21D: side switch, on-board USB-C charging, and good thermal regulation in Turbo mode (S21D gets too hot in Turbo mode), was released in 2024. With Nichia 219b 4500k as an option, M21H is a great alternative to S21D. Pls see review.
1b. (tied with 1a) Convoy M21E or M21F with Getian GT-FC40 4500k HERE. The only bright medium-range thrower on the market with Nichia-like color quality, and perhaps more useful than similar size Nichia lights because of much better brightness and throw (324 m per my measurement). This is the all around every day light and the perfect gift light because it does so many things so well. Getian GT-FC40 has fantastic high CRI beam color that no doubt imitates Nichia in real life viewing. The tint is between 219a and 519a, but more towards 519aâs sunset yellow than 219bâs rosy tint. My own M21E sporting Duv of â0.0064, closer to the legendary Nichia than any other throwy LED in existence. The M21F has a smaller head (fits pocket easier) and has a balanced beam between flood and throw, whereas M21E has more throw (324m M21E vs 276m M21F) but less flood, and is slightly bigger. Either is a big winner with no competition as a walk light IMvHO .
EDIT: Tint lottery (variation of Duv) might be a problem with this LED. I have two M21Eâs with identical GT-FC40 4500k LED, the first one bought in 3/2022 has perfect Duv and Nichia-like tint, the second one bought in 10/2024 has greenish tint, noticeably worse than the first one.
1c (tied with 1a & b) Wurkkos TS30S with SBT90.2 HERE. In some hobbies, car, photography, stereo, etc., once in a while a product, whether by luck (kidding) or by talent, hits that magical perfection level. This humble $60 light is such a unicorn and has proven to be a FORMIDABLE competitor to all the newer lights in my collection. The Wurkkos rocks my Opple meter by clocking 1 km throw (holy macaroni), and outputs a cool 4500 plus lm on Turbo, meaning fantastic brightness. That all of this is in a smallish form that fits jacket pocket is the magic of modern LED and flashlight technology. The beam profile is âbalancedâ: some super throwers have an extremely bright hotspot but little to no spill, resulting in a very narrow field of vision, the Wurkkos OTOH strikes a perfect balance between good-size hotspot (throw) and good-brightness spill (flood) click here. I use this light often during my evening walk and the beam is an absolute thing of beauty: a bright central beam piercing darkness like a light saber. Turbo as expected in ALL lights without active cooling, is not going to last long. In my use case, light is at Turbo-1 or T-2 level, then switched to Turbo when I need to look for safety reason (coyotes, not-well-meaning people, etc.). The beam color at ~5100K is very nicely warm (as opposed to harsh flat blue) and has a green tint that I forgive in a super-thrower LED. As OCD picky as I am, the green tint is not a hindrance in actual use. Nothing on the market comes close, not at 60 bucks.
4. Budget âsuper-lightsâ - Wurkkos TS32 with 12 Nichia 519a and SFT40 HERE. The 15000 lumen of TS32 Nichia 519a goodness is UNLIKE anything Iâve ever seen. It has a golden creamy (meaning not too yellow) tone and is so very very bright and floody (why itâs often described as âwall of lightâ). Note that this 519a 5000k is most beautiful in Turbo mode; the lower brightness has some green tint and more positive Duv. In the context of comparing against these other 15000 lm super-lights, it has very clearly the most beautiful warm-colored wall-of-light, with the best color rendering as a result of its 98 CRI. 519a 5000k is less yellow than 519a 4500k, and I welcome this change. Combining twelve hot 519aâs with the throwy, cool, bright SST40 central LED is an ingenious move, a result of this light being born and bred in BLF by hobbyists. The 519a stepdowns very quickly so I would suggest to use light with SST40 throw on Turbo or high, and 519a only on medium, with occasional burst of Turbo for the ultimate OMG Nichia hit.
For more lights if you would like, I have a few to mention. Sorry I canât narrow it down because I love all of them.
5. Nightwatch Super Valkyrie with Chinese LED SFP55.2 This is the brightest single LED single cell flashlight on the market. Itâs a stupendously bright light and a âcollectorâs itemâ because nothing like it exists at this price and who knows how long itâs going to be in stock. Check my âreviewâ because this thing has many odd behaviors, like you have to click button for it to begin charging. Unfortunately itâs available only on Neals Gadgets web site, with which I truly have a love-hate relationship
(51% love for offering unique lights, 49% hate for good-luck-youâll-be-ignored if the item doesnât work). My measurements: Output 13090 lm (!), throw 676 m, CRI 6700, CRI 71, Duv @ Turbo -0.0002, T-1 0.0011.
6. Lumintop D3v2 with Chinese LED SFN60 Fantastic 6500 lm when paired with Nealsgadgetsâs mystery Lishen battery, and fit in a pocket. And Anduril. And inexpensive - whatâs not to like? Small and pocketable, but not too small such that heat would kill the fun. If you are into high output small light, IMO this is the best of them all.
7. Convoy S21D with Nichia 519a 4500k or 219b 3500K. Tough choices between these two. The longer I play with flashlights, the more I enjoy a warmer tone. IMHO my flashlight adventure is NOT complete without a low CCT light. Although there are many 3500K LEDâs, I would like Nichia 219b version because for me it has a most beautiful warm golden tone with rosy/reddish tint. It seems like the secret sauce that is Nichia 219b series has not been seen again, not in the Nichiaâs I have, 219c, 519a, or E21a. 219b 3500k has a âsaturatedâ warm tone that I sometimes prefer over the legendary 219b 4500k. 4500k has a colder, more sterile look by comparison.
519a is recommended because of how different its beam color is from 219b, and yet it still has spectacular CRI specs ( Ra 93.6, R9 82, R12 80, Duv 0.0009). While 219b has incredible and un-matched color rendering, sometimes the magenta tone of 219b might be too much for me :-), and 519aâs beautiful and relaxing golden tone provides a relief. I love having both because for me itâs like having different wines or food from different restaurants, all good yet different. I guess itâs called having fun with a hobby :innocent: .
PS Replace Convoy S21D with the beautiful Emisar D4V2 if you want a smaller form with 18650 battery that fits better inside hand, and has beautiful styling and knurling. Convoy S21D does maintain brightness longer than D4V2. All subjective and IMHO. Hope this helps.
Thanks for the beamshots and sharing your journey, cannga. I should be getting my S21D before the end of the week. I think I'm as passionate about driver efficiency and sustainable lumens as you are about the 219b 3500k and 4500k. I refuse to even consider lights with linear or FET drivers anymore, which is saving me a lot of money on the bright side. As much as I appreciate the existence of Sofirn, Wurkkos, Convoy, and Noctigon/Emisar, I also feel like they've contributed substantially to the proliferation and longevity of linear and FET drivers for 3v emitters, at the cost of switching drivers becoming the norm and standard for 3v emitters, outside of the big brands.
^ Thanks for sharing that cannga.
I agree, there is something special about the Nichia 219b. I have a few from 5000k down to 3000k. I do appreciate warm white, with about 3500k to 4000k to be my âsweet spot.â I do have one R9050 sw30k and itâs so much like incandescent. One day when I get around to finally reflowing LEDs, Iâve got a few of those in waiting to be installed in a triple.
Iâve been looking for a modest form factor single cell long thrower. Right now I have an old Nitecore EC4GT that has decent throw for its size (475 meters). I love the form factor, 2x18650 in parallel creating a rectangular body. Iâve been looking for something that can throw at least as far while also delivering a broader hotspot. My Sofirn SP33v3 falls about 200 meters behind the EC4GT but has excellent spill⌠despite the tint being cooler than I like. Anyway, I wanted to try something newer. First, I considered getting something on the inexpensive side, like the IF22A. But then I saw what Convoy was doing and that drew me to nearly buying an M21E. Then I thought maybe I should give Emisar a go. But after seeing the TS30S specs with SBT90.2⌠the price is very attractive. I just wish it came in 5000k.
Good news: the CCT of SBT90.2 in my Wurkkos TS30S is ~5200K. The beam of SBT90.2 will surprise a lot of people. For a super thrower it is suprisingly warm. Golden yellow slightly green, like the color of the LED itself. The only other thrower that has similar warm beam is Olight M2R Pro Warrior XHP35 HI, which is around 4700K. Very pleasant, except the green here could be a touch much depending on LED lottery (I have 3, all different colors). Although green tint doesnât bother me as much in throwers - subjects being so far away.
The other two throwers that I have, Sofirn IF22a ~6400K (w/ SFT40) and Nitecore MH12S ~5900K (SST40) both have steely harsh blue beam that obliterates colors. Stay away from those 2 if that would bother you. In addition stay away from IF22a unless you are looking for a very narrow beam with hardly any spill, as a result of the 5 Degree TIR used. For me that kind of beam is unbalanced and the light therefore not my favorite, but of course thatâs strictly personal preference.
Wurkkos TS30S will obliterate M21E and IF22a both in brightness and in usefulness of beam (wide, bright beam). IMHO the only competition for a SBT90.2 light is another SBT90.2 light. I looked at Convoy L8 but didnât go for it because it is getting too large, costs twice as much, and uses that 26800 battery (I wanted to stay with 27100). Larger reflectors tend to create tighter smaller brighter hotspot (better throw) but may sacrifice spill (less flood). In retrospect I love the hotspot/spill balance of the Wurkkos so Convoy may not be an âupgradeâ outside of throw. Hope this helps and sorry way OT to discuss Luminus and Cree in a Nichia thread lol.
As you know by now Convoy has released a goodie bag of TIR Optics to use with your Convoy S21D. The goodie bag includes 4 optics total, and in the order of decreasing throw and increasing flood they are: 10 Clear, 10 Bead, 30 Bead, 60 Bead.
For anyone new to this, decreasing throw means the hotspot in the middle of the beam becomes less bright, at the same time that the periphery becomes brighter and larger (covers more area). That is the tradeoff between hotspot/throw and spill/flood, like tax, unavoidable. You could see this very clearly in the beamshot below.
Personally and for example, if I like to see further ahead for safety reason, such as during my evening walk, then I prefer the Convoy 10 Clear because its brighter central hotspot means further throw. OTOH, if I am doing close up work, for example repainting the brake caliper of my car, then the floody 60 Bead is much nicer. In this situation a bright hotspot such as with 10 Clear is blinding. The throw measurements below show how optics directly affect how far a light shines (throw). The Sofirn 10 Clear is the optic on Sofirn IF25a that just happens to also fit in Convoy S21D. Iâve also included Emisar throw numbers for comparison.
PS If you are buying a S21D from Aliexpress, at the time of ordering just send a nice note to Simon and asks if he could gift you some extra optics (and please donât quote my name lol). A pair of 10 Clear and 60 Bead or 10 Clear and 30 Bead would be a nice start IMHO.
S21D with 219b 4500K
1. Sofirn ~10° Clear 170 m
2. Convoy 10° Clear 170 m
3. Convoy 10° Bead 157 m
4. Convoy 30° Bead 144 m
5. Convoy 60° Bead 113 m
S21D with 519a 4500K
Convoy 10° Clear 157 m (using same optic, 519a less throwy than 219b)
Emisar D4V2 219b 4500K
Carlo 10621 Clear 140 m
Carlo 10622 Clear 137 m
Emisar D4V2 E21a 4500K
Carlo 10621 Clear 174 m (using same optic, E21a is more throwy than 219b)
Carlo 10622 Clear 170 m
Carlo 10623 Frosted 111 m (frosted optic makes âhotspotâ (central area of beam) of D4V2 w/ E21a very dim)
^ Thank you, Cannga â the TS30S is now top of my list!
Iâve been looking to pick up the S21D in 3500k 519a but now I see this S21E with integral C charging⌠Sure its lower output but still brighter than my backpack zebralight. Anybody want to sway me one way or the other???
In the following picture note how hotspot becomes brighter (more throwy) at same time that tint shift appears and spill decreases (less floody) as we move from Carlo 10623 to 10622 and then 10621. Also the interesting difference between E21a and 219b: both has tint shift, but it appears âearlierâ and more severe in E21a , resulting in Hank needing to use frosted 10623.
For 219b lights Hank uses 10622, a clear optic. For E21a however he switches to 10623, which is frosted and results in a beam that is for me, way too dim. D4V2 has more aggressive thermal stepdowns than Convoy in the first place, and starting that dim is not good for me. 10623 also drops overall brightness as well as throw using ceiling bounce method (down 16% from 10622). This is not something I see with the various Convoy optics wherein overall brightness stays the same between the 5 optics.
10622 versus 10621 for 219b 4500K: The little gain in throw from stock 10622 to 10621 is not worth it because now I see the appearance of a yellow tint shift. I also like the larger spill (more floody) of 10622, and the more gradual and pleasant transition from bright hotspot to spill to darkness. 10622 in this Emisar light creates a most beautiful beam.
10623 versus 10622 for E21a 4500K: This one is a little more difficult. 10623 decreases throw AND brightness so much that I am willing to trade to 10622 despite the appearance of tint shift with 10622.
The S21D has a big step up in max and sustained lumens over the S21E. The latter does have a better UI, a bit smaller, and charging.
Guys, are we picking up the Ti T3 or naw ;D
https://www.aliexpress.com/item/3256804460263119.html?spm=a2g0o.cart.0.0.6cdb38daqJ8xaW&mp=1
White wall hunting beamshots could only tell so much. How does it translate into real life scenes? Here are some actual pictures comparing the three 10 Degree optics:
Sofirn 10 Clear
Convoy 10 Clear
Convoy 10 Bead
The comparison between Sofirn 10° Clear vs Convoy 10° Clear optic is very interesting. They measure identical, the throws are identical, but photographically the Sofirn is just a touch brighter. But this could be shot to shot variation and it is so close I wonât argue if you see differently. Either of the two 10 Clears are winners for those wanting more distance.
I think itâs a matter of time until my neighbors complain about these beamshots into their yards.
Great shots!
