Convoy SST40 drivers now coming with R020 sense resistors?
Ah on this one : https://www.aliexpress.com/item/33024197621.html
We can see the resistor values : R1=100k, R2=510K, R3=13k. This would mean Vreg= 2.875 wich is a weird value for an LDO, probably 2.8V and actual Vsense of 58mV for 5.8A.
Assuming they only changed R2 for a Vsense of 120mV the new R2 should be 191k.
edit : there are LDO with 2.85 or 2.9V output, could be one of those too.
I am likely wrong, but would not the 2 stages of RC filters provide a cleaner power path to the MCU and likely increase stability by cleaning up feedback? Also, is there a chance that production changes in the FET may have dictated the change in the sense resistors?
Also above I noted a comment regarding tail cap amps versus LED amps, I would think that based on AWG of the LED wires and quality of the the electrical path that these 2 numbers could differ. Any weakness in the electrical path can affect current flow and would generate some heat in the process. This is why we add spring bypasses, upscale LED wires and do most of the other silly things we do. :slight_smile:
Now, remember I am not a driver engineer, go easy on me if I am wrong!
Matt
What is the SVA1J ic—is it an op amp? The schematic and pin out traces don’t match.
Typically for a SOT23-5 op amp.
Pin 1 Out
pin 2 Gnd
pin 5 Vcc
Is it a comparator? It looks like the circuit is just using a bang-bang circuit to drive the FET—if PWM is actually a fixed frequency variable duty cycle signal, then the double LPF will remove any of that.
Maybe what is labelled PWM is actually the current limit level?
Yes, 1 is out, then count counter clockwise.
Random datasheet : https://www.mouser.fr/datasheet/2/268/MCP6V96_Family_Data_Sheet_DS20006467A-1948680.pdf
Edit: ah I see what you mean, on the schematic I must have chosen an SC-70 op amp, sorry for the confusion.
There is no feedback coming back to the MCU, it just ouputs a PWM signal, smoothed into a voltage (which sets Vsense) by the RC filters, it just better smooths it with 2 filters and thus reduces the current ripple, but really that’s unnecessary, one is enough, a little ripple is fine, we’re just powering an LED.
For the secong point, it’s a circuit with all the components in series, the current is the same anywhere in the circuit.
If you don’t want any flicker from PWM, then why generate and use it as a command, even with 2 LPFs—just extra stuff not needed.
Just generate a current set point voltage that you want and use the Rsense to feedback the current. Add some compensation or hystersis to prevent high frequency ringing or bang-bang. The setting should be in the command, not the sense resistor. just sayin’
i can’t find any part marked “SVA1” maybe it’s a custom order?
Does C3 connect downstream of the drive resistor R4 between the gate and the source?
ps. Thanks for drawing up the schematic.
That’s what YLP does in the Unicorn 1.0, it lacks precision limited by the ADC’s resolution, and they use an RC filtered PWM signal to drive the mosfet, could be because the MCU doesn’t have a DAC, or because its resolution is not high enough ?
So in the end there is a measurable ripple
It should be across In- and out, quoting an app note I read at some point , with R4 and R5 it forms a compensation network that prevents ringing.
Isn’t not turning the LED blue better? Increased resistance is never ideal but overdriving the LED is rather bad for life expectancy.
Wow! That was fast! I see. O:)
Despite what I said before, the newer version driver will also let a little bit more current if you stack more and more sense resistors, as it reduces the sense voltage burden. The lower modes will grow higher and higher, though, and if you dare to bypass the sense resistor with a blob of solder or by installing copper sheet or wire instead, all modes will top out in output; the lowest one, if set very low by the driver firmware (like 1%), may not (solution: use the most conductive, thickest sense resistor bridge you can afford). In short, you lose modes in this case.
The Convoy “ramping” driver is very solid, really good. Employs a 6788 MOSFET, and just an R005 (5mΩ) sense resistor for up to 8A, so only up to 40mV spent in sense, and the lowest minimum resistance (resistance with the MOSFET “pedal to the metal”, all closed or completely unthrottled) of all linear drivers at Convoy, afaik.
Over time I've learned to appreciate it, despite its weird firmware. It is ideal for gun shooting (hunters), as the mode selection is by series of quick taps: one quick tap, first mode; two quick taps, second mode; three quick taps, third mode. Since the first two modes can be current set with ramping, and the third or special mode can also be set to 100% via the special menu among other options, this means it can be set so that the vibrations of a gun shoot cannot change the output of its flashlight, as all three modes can be easily set equal at 100%.
Here's the sales link of the ∅17/∅22mm ramping driver at Convoy. Oh! :facepalm: I see the chart for the driver mode selection and setting instructions of the driver is missing! Nevermind, the graph is there; it was some sort of connection problem.
Overall I smell a “race for the highest current or output” around here. This is not necessarily a good approach. With the coming of the Osram emitters, with a pretty low Vf and lowest current limits, you need to learn that its drivers must be (or should be) set to limit the maximum current, to avoid any chance of overdriving them. This of course involves looking at the test graphs. However, please bear in mind that not all emitters are equal, and some may have somewhat lower limits. Even if all of them were to stick to no less than the test curves, it is not necessary nor wise to drive them at up to the maximum output current. At these levels, reducing the maximum driving current to let's say ≈80% only renders reliability benefits for the emitter, barely affecting the output. Let's for example see the output graph of a Samsung LH351D 5000K -test- by Texas Ace:
Maximum output current is 9.25A, delivering 2333 lemons.
80% of 9.25 is 7.4, so what do we have at 7.4A? 2220 lemons. This is 2220 / 2333 = 95.15645…% of maximum output at 7.4A, according to test graph information. Do you think this will make a difference to the eye? Go try. x-D
By the way, in the above graph it was easy to see where the maximum output is. Let's take a look at the Reflow conditions tested of Osram KW CSLNM1-KW (White Flat 1mm2) test graph by djozz:
I'll make an small explanation on these duties, just for the sake of it.
So where is the maximum output for these CSLNM1.TG emitters? Is it at 5A? Is it at 6A? Wrong.
djozz only took discrete output measurements each 1A in the latter test (each 0.5A in the former one), and drew straight lines between each discrete value. This is not how the actual output current curve, with continuous measurement or infinite discrete values, looks like.
The actual peak value or maximum in a curve plotted with discrete values and straight lines joining them, is always around the highest discrete value measured for it, and between it and the closest, next highest value. If there are two next highest values, like in the above LH351D curve, then the maximum is spot on the measured point. When there are two maximum discrete values, the peak is between them and higher than both.
In djozz's test the two best emitters peaked a hair above 5.5A, while the lesser performers (excluding the first test's specimen) peaked a little above 5A. In my lightful opinion, I'd probably choose to set my drivers at 4.5A for CSLNM1.TG emitters (the “S” in CSLNM1.TG -1mm²- and CSLPM1.TG -2mm²- means 3030 footprint). There are no tests for the CULNM1.TG or CULPM1.TG ones, so we don't have an idea of the gains for the 4040 footprint. My prediction, though, is that a CULNM1.TG (4040, 1mm²) is barely going to be any better than a CSLNM1.TG (3030, 1mm²). The impact of the footprint may be more noticeable when comparing the CULPM1.TG (4040, 2mm²) to the CSLPM1.TG (3030, 2mm²), but I hardly predict any noticeable gains at stake anyway. Emitter bin is more important in this respect.
Thanks for the technical contributions, thefreeman, it's enlightening. Still, I am @#$% with all of this. I'll see what I do with the sense voltage dividers. I also have a driver from Kaidomain, the P4000, which looked good on paper. But after inspection, I discovered a fairly gross sense resistor stage of an R050 plus 1R0, which is 47.619mΩ, which is efficiency killer for a buck driver driving a 3ish volt load.
P.S.: Now I understand why my latest flashlight build for a brother had such a small brightness difference between the highest mode, and the second highest, as I swapped the sense resistor in its “new downgraded” driver to an R010, like in the older versions of the driver with smaller sense voltage. :facepalm:
I am having a private conversation with Simon right now, this is the last message I just sent him:
I definitely noticed the newer driver with R020 dropping out of regulation quicker compared to an older 17mm 5A driver with R010 and resetting mode group bug in a C8 XP-L HI.
It’s a shame because the 17mm 5A drivers were my go to for modding and Convoy builds, are there other similar alternatives in 17mm besides the LD-A4 and Convoy ramping driver?
Took some time to draw the following picture, peeking at a “new version” (huh?) ∅20mm 12-groups driver, while I was reading the values with my cheap multimeter (maybe gold plated probes can make a difference in this regard) and ensuring all connections were accurate. The SVAKF part is the operational amplifier, LoL. Resistance for R2 would only stick quickly when read with positive probe between it and R3, giving 436.3kΩ. The other way around I get 494.3kΩ after I wait a few seconds for the value to climb up.
Compared to thefreeman's diagram, C2 <=> C3. I also didn't mess with certain stuff (for example didn't make sure if R5 goes to Rsense first, then to ground).
It's enough for now. O:)
Fri, 08/06/2021 - 16:51
Thanks for that, i was wondering about the capacitor values.
Here is a simulation using the 10mR resistor parameters with your capacitor values running 4A in LED. The ripple in the LED current is due to the low frequency of the “PWM” pulse; if the frequency were increased, then that would be filtered out.
Would you be able to check and provide the actual connection of the R4, R5 and C3 on the output of the op amp to the FET—correct any errors in the schema.
The only difference i can see between the 20mR and 10mR version is the R2 value that you measured, and that difference is not really significant. (436 - 494k vs 510k)
Tom E has a pic of another Convoy linear driver with the components desoldered :
So yeah C3 isn’t between the out and in- contrary to my shematic (I just guessed since it was difficult to see) or shematics found in app notes or even in suggested application in op-amp datasheet , for example this one in the OPA333 DS :
Detailed here : http://www.ti.com/lit/ug/slau502/slau502.pdf
First stage is a constant current sink, the Noctigon kr4 driver is exactly like that, with an added resistor between the gate and source of the mosfet.
Note that with Falstad the circuit is stable even without the compensation capacitor, in LTspice there are large oscillations without it.
It could be that it was intended to be connected for compensation as you have shown, but a trace error was made in the layout. As it is now C3 seems to serve no real purpose or provides any filtering.
If i connect C3 for compensation and increase the command level, now i see 6A in the LED and a 60msec delay in reaching the full drive of the FET with a nice ramp up to the desired current. This sort of soft start puts less wear and tear on the parts and is less abusive than a full hard on start; maybe this was intended but the traces weren’t in place.
[edit]
The op amp will drive the output as necessary to cause the feedback at IN- to match the input at IN. The RC combination of R3*C2 causes an exponential ramp up of the input. With C3 wired as shown it is bleeding off charge from the output thru R5 (10k) to cause IN- to match IN. Once the IN+ reaches its final value and is no longer changing, the contribution by C3 gets reduced and the op amp must drive harder to compensate, which raises the output until it reaches the 1.5V gate threshold voltage of the AO6788 SRFET (30V, 80A, 4mR). Now the FET turns on and the feedback is from the Vsense reading. This is the effect of compensation to create the soft start 60msec delay of current in the LED and FET.
Hello again. :-)
Just edited my previous post, I noticed that I am not really sure if the ∅20mm driver I was speaking of in it is actually a new version driver. This in part is because the results I was obtaining with thefreeman's equation didn't make sense, and because the driver was resent to me from Simon maany months ago because of an old firmware faulty unit. I obtained two values for R2, but of course I wasn't measuring R2 with one of its legs unsoldered, something which is a must to do away with any distorting measurement interactions with the remaining parts in the circuit. Because of this, out of the two values I reported for R2 the correct one must be the highest: 494.3kΩ.
Now, here's the figure for R2 out of thefreeman's equation presuming the LDO is a 2.6V one:
R2 = ((Vreg – Vsense) x R3 / Vsense) – R1 = ((2.6V − 0.06V) × 14kΩ / 0.06V) − 100kΩ = 492,666.6̅Ω
This sort of matches my 494.3kΩ measured value for R2.
Now I just have to rig up the driver to some led load, and raise its voltage to see if it goes beyond ≈4.2A (it has an R020 in parallel with an R050 as Rsense). It should not…
Sun, 08/08/2021 - 09:56
What about the ∅17/22mm ramping driver? Did someone around here bought some lately? Does it come home as seen in the pictures?
It's been been a while since the last time I bought one of these, hope all is good. The ∅22mm one is easily grinded down to ∅20mm, btw. ;-)
Got mine for less than 2 months ago, 5 of them (17mm) pretty much the same like the older ones…
Finally spent some time assembling the head of my custom red L21A… for @#$%. Tested it on my power supply, and it went well above 4.2A, which should be the limit with an R020 and an R050 as sense stack.
:facepalm:
After all what has been discussed here, do you need such a thing? I have links, but if your drivers are new their sense voltage is a tad above twice the old one (more voltage drop loss), and causing the absolute current limit to also be more than doubled with an older value resistor… this is why I am dumping mine. Sheesh!
Had to test this again for some :GLASSES: reason…
By the way, the holes in the retaining rings are too tiny. Even my finest tips round nose pliers are too thick for them. After some struggle in part due to me having tightened the ring, I decided to make use of my drill plus a 1.5mm bit to enlarge the holes. Problem solved, but again I have to say this sort of stuff should not be needed.
So I dismantled the driver from the pill, took out my heat gun and proceeded to desolder the smaller resistance sense resistor (R020), leaving just an R050 for sense. Moments afterward I assembled it together with the pill again. I wanted to measure the current limit the driver allowed, and since somehow I was expecting it to be a new version unit, I removed the R020 sense resistor to make sure my SST20 emitter could deal with the current.
I am using a Wanptek 30V 10A precision PSU, I first set a current limit (just in case), raise the output voltage enough for the resistance of the output wires and alligator clips not to be a limit (≈6V), and then proceed to stick the alligator clips in the spring and over a pill border by hand, using this latter connection to switch modes. Here are the tared to zero numbers of the PSU's digital amperimeter for mode group 1 (0.1%, 1%, 10%, 35%, 100%, strobe, biking, battery check), with strobe, biking and battery check ignored; all values in mA:
  1. 17 - 6 - 98 - 426 - 1275/1300 (here are two 100% figures, as I raised the negative probe and re-connected it >0.5s later).
  2. 20 - 16 - 134 - 461 - 1302
  3. 18 - 15 - 135 - 462 - 1303
So I obtained two matching series of measurements, and according to the last 100% figures of ≈1300mA, sense voltage must be 65mV.
Thank God I tested the driver again instead of dumping it, this means I need to solder the sense resistors more carefully.
With this data, thefreeman's equation gives out a more or less matching R2 value with my measured values if presuming the use of a 2.8V LDO. For other drivers we need component measurements.
Oh now i see why—that is a very specialized op amp with proprietary internal chopper circuits to reset the offsets which limits the Unity Gain BW to 350kHz, and with ultra low input offset voltages. So it would be prone go unstable and oscillate at the slightest sneeze, similar to some of the older op amps that had no internal compensation.
The OPA2333 basically is 2 amps in 1—it has another op amp built inside it in addition to the one that is available to the user…too damn smart for me.
