I have no idea how you did it CRX but you have and it works. Well done. :+1:
You must be approaching around 5000 mods this year come out of your mod factory. Whats up next?
It’s one of these with one leg bent underneath and the other bent up the side of the switch, pressed into the 10mm hole i drilled. About 3mm of the switch sits inside the battery tube which i epoxied around with the copper taped contact just sitting proud. These are small forward clickies that seem to be well made.
