Here are a few pics of a very rough (my only way
) and ready mod on a pair of SF lamps that arrived yesterday.
these two
https://www.myled.com/p3313-led-zoomable-flashlight-cree-xm-l-t6-800lm-5-mode-with-charger-1x18650-black-sliver.html
https://www.myled.com/p3317-led-zoomable-flashlight-cree-xm-l-t6-800lm-5-mode-with-charger-1x18650-black-sliver.html
Photos hosted on my own server space. I'll try and leave them there as long as possible (the downside of not being able to upload to the BLF servers)
I did not screw up the lathe work too badly, and they work better after. The wide flood is now double what it was.
I must get my self a set of reading glasses, 46 years old and presbyopia setting in :( I can only see the true 'quality' of my lathe work now in the pictures..how the hell I cut the "O" ring groove without being able to see clearly and did not slice through the tube...just lucky I guess.
You will see in the before and after shots of the barrels the section with no anodising where I took material off the body. This allows the zoom body to slide back further. On the small one with the white emitter surround, I also removed metal from the front of the 'drop in' allowing the lens to nearly touch the LED..(note to self...read up on de doming). Had to cut a second "O" ring groove too as the internal "O" ring contact point in the zoom head was small and 'fell off' the back as I zoomed to wide.
These are both advertised as 800 Lumen, though on the myled website the bigger 132 is given as 200 meter range while the smaller one is given as 80.
Switch on both is Forward clicky with a glow in the dark green cap, that only glows once you have shined a bright light on it.
Very basic beam shots at full zoom of the 132, taken at about 0300, out of bedroom window across fields to derelict glasshouses.
I really like the sharp cut off of the square image of the LED at full zoom, virtually no spill just a nice spot.
Will try some wide flood shots later.
White balance set to manual of 4800K
I changed exposure, accidentally between shots , so used the "Match Total Exposure" function of Adobe lightroom to bring them back to comparable shots. The palm type trees are about 20 meter away, the glasshouse is near on 60 meter
Here is the spec
| Brand | SingFire |
| Model | SF-132 |
| Color | Black+Silver |
| Material | Aluminum alloy |
| Emitter | CREE XM-L T6 |
| Color BIN | Cool White |
| Total Emitters | 1 |
| Working Voltage | 3.7V |
| Battery Configuration | 1*18650/3*AAA battery |
| Circuitry | 2500mAh |
| Brightness | 800LM |
| Runtime | 3-4h |
| Modes | 5(Hi>Mid>Low>Fast strobe>SOS) |
| Beam Range | 200-300m |
| Dimension (cm) | 15.5*3.4*3.4 |
| Net Weight (kg) | 0.177 |
| Lens | Plastic 30mm diameter |
| Reflector | No |
| Mode Memory | No |
| Brand | SingFire |
| Model | SF-707C |
| Battery Configuration | 1*18650 battery |
| Circuitry | 2500mA |
| Runtime | 3-4h |
| Modes | 5(high>Mid>Low>Fast strobe>sos) |
| Beam range | 200-300m |
| Dimension (cm) | 11.5*3.1*3.1 |
| Net Weight (kg) | 0.075 |
| Lens | Plastic 20 mm diameter with flange to 25mm |
| Reflector | No |
| Mode Memory | No |
The angle of this shot makes them look the same size, but no, The rear one has a body about 30mm, and the front one is 24mm.
I'd be interested to know how these screw-in units are opened? I am guessing the PCB is just glued in ? Might be destructive to remove them. But it needs to be done.
I want moonlight mode first ON and memory at OFF feature. No need for strobe and SOS. I see Mountain Electronics have custom Drivers for that I'd like 2% 5% and then maybe 50 and 100%.
I'd like to drive these at bit more on 100%. Even on full s they are now, they barely get warm. I am sure they can take more, What can I run these at before burning them out instantly ? Not looking for 100% continuous, 20-30 seconds will be all I'd want
Might be able to machine a mm off the front of the black one to get that slightly greater flood.
What is the chance these unscrew? Tried a gentle turn but nothing . I won't force them just yet.
