My light was ordered from WB a few months ago...
If I understand correctly the driver is essentially direct drive with some PWM on high. Even stock, this is extremely bright, especially after resistance mods. Just need to have the right batteries, especially if you want to avid sag. Output sinks fairly soon.
I improved driver cooling (heatsinks+ fujick), not sure if it was necessary, but I felt like doing it. Added 18+22awg wires. I ended up only using 18 up to the emitters. Double copper braid on driver spring. I did the switch side too (not pictured)
16mm Noctigons was cut. (Stock size was 14mm). Used 22/24awg wires. Stock was slightly thinner, 26 awg?. Lapped the head a bit too, there was a tiny edge on it. Thermal paste was probably 60% Artic silver 5 and 40% fujick. I wanted the emitters to be properly attached when doing some current tests. Added kapton tape on the back of the reflector. I like to have some sort of "short-circuit protection".
3,3A at one of the emitters! J) I measured 9,4A going through the wires (3s3p). But there is probably some extra loss in the DMM wires and DMM at such high currents.
Emitter setup:
Center emitters: stock CW dedomed + stock CW dedomed + T6 3C dedomed
Edge: 2x stock CW, 2x stock CW dedomed + 2x T4 7C.
Sony 26650 (rated 50A) were used. They quite good at keeping the current high.
The front of the head can reach about 140C/280F in around 15 minutes, indoors no breeze or cooling. I changed batteries through the test (to another fully charged set) Used welding gloves when changing batteries. :p Just had to test that the driver and emitters was up for it... J) They were.. I have no issues running it constantly on high outdoors in cold weather..
I seem to have some issues with a bit moisture on the inside of the lens when using it outdoors, it appeaser in the middle of the lens. I don't think the head is properly waterproof, probably needs an extra O-ring. Or is this a common issue with extreme heat? I have heard about other lights having the issue.
Im very impressed by the tint and beam. I did not mix in any emitters with extra red/pink tone. Despite this and all the dedomed emitters, its just a lovely NW tint not overly yellow or greenish or anything bad, which I had a feeling it would be. For a flooder this light throws! :)
I think this light is enough in terms of heat and lumens for me. It serves as hand warmer and sun at the same time! Perfect! :)
Did I say I like the beam and tint? :) Ohhh, and its BRIGHT!
Beamshots to come some time in the future for those who are patient..
