Stock SPL-120 SSC P4 emitter:
Low - 14lm
Med - 46lm
High - 96lm
Modded SPL-120 Nichia 219C 4000K 90+ CRI:
Low - 29lm
Med - 110lm
High - 435lm
Slightly trimmed 16mm copper DTP MCPCB with Nichia 219C.
I made a prototype brass sleeve to contain a copper sliding bar with a spring on the end so the light can run on 18350 cells and dispense with the signal spring.
Swapped the black O-ring for a green GITD version, the plastic window for a 22.7mm x 2mm ARC glass version and some GITD tape in the grooves.
This model seems to have an upgraded pill/ LED retainer compared to other Novatac models I have seen, which also saved my fingers some punishment from filing the MCPCB into a cross shape this time :-)
Outputs vary quite a bit too on these lights, pre and post mod.
Stock Novatac 120-E:
Low – 10lm
Med– 30lm
High – 106lm
Nichia 219BT-V1 4000K 90+ CRI:
Low – 26lm
Med – 100lm
High – 310lm
Stock Novatac SPL-120 - Light - 01:
Low – 10lm
High – 74lm
Low – 38lm
High – 250lm
Stock Novatac SPL-120 - Light - 02:
Low – 8lm
High – 54lm
Nichia 219C D280 5000k 80CRI:
Low – 38lm
High – 220lm
Low - 14lm
Med - 46lm
High - 96lm
Low - 29lm
Med - 110lm
High - 435lm
Nice lights though :THUMBS-UP:
See Also:
NovaTac 120T Triple Nichia 219C 5000K - H17Fx - 18350 - Tail Clicky.
NovaTac 120P Triple Nichia 219C 4000K 90CRI H17-Fx - 18350 - Tail Clicky.
NovaTac 120T Triple XP-L HI - D4UI - 18350 - E-Tail Sw - 2240lm.
