These Three SRK’s are the old school quality ones. They are the old versions with screw in shelves and real XM-L LED’s, plus they are just nicer then the newer versions.
They work fine but put simply after so much stinking time dealing with SRK’s I just do not feel like rewiring 6 individual LED’s at this point plus I would want to replace them with DTP and newer LED’s. If I was going to do all of that I would use one of the other hosts I have with the press fit shelves as they would have better heat transfer.
So I am offering them to BLF, these are a great host for modding or just upgrade the wiring and use as is!
Stock these are making around ~2400 lumens even with those hair thin wires. With a wiring upgrade that should increase greatly.
$40 shipped for the 6x I took apart and would need to be re-wired SOLD
$45 shipped in con USA for the still assembled 6x version SOLD
$50 shipped for the 7x LED version also with shelf SOLD
I also have some Drivers that would be perfect for these for sale as well: SkyRay King 46mm FET+1 V2 Drivers W/ Temp sensor and custom Copper contact plate *SOLD*
Yes, those hairs coming off the driver are actually supposed to power the LED’s! It needs a wiring upgrade for sure. Or get one of the custom drivers below.
I also have another 20 8x LED SRK’s that are fully modded with 1/2” thick press fit shelves, Customized FET+1 drivers, temperature regulation ect. Over 3 hours of time in each one.
They are a little much for the crowd here I know but asking $75 each.
If someone really wants one PM me, got a few “prototypes” with some dents/scratches that might be more reasonable priced.
1/2” thick aluminum slug ready to be installed
Press fit with temperature sensor hole (also needed for “machining” since I don’t have a proper lathe)
Holes for wires and mounting the reflector drilled:
Overall didn’t come out too bad, just way too much work without a lathe to be practical for what I was planning.
