I must make it clear these were needed for first 500 batch, not so much for 2nd batch, but I'd still do a bunch of things for batch #2 Q8's. This is what I did on first 500:
20 AWG bypasses as shown in link above
tin the contact rings around the screws where PCB contact the battery housing
clean/sand the shelves on the battery housing to the tinned rings make good contact, use light amount of NO-OX-ID on that contact surface
drill out driver screw holes to 1/8", replace screws, remove burrs on screw holes on the head where driver screws go on
sand smooth the edge of the battery tube where it makes contact to the driver ground ring - removed burrs, sand to 2000 GRIT, light NO-OX-ID
These are the ones I did initially to get to 7,000 lumens, and was all about the battery tube. Later mods got into the driver and LED board.
Now i dont think ill do the spring bypass JUST IN CASE some of my fellow house members attempts to put batteries in it.
The amount of lumens it will add, wont be worth risking the light (imo).
If i would know im the only one touching the Q*, then i probably would.
From here-on-out, the Q8 is going to be fine the way it comes, stock
IF you mod it, or for just general safety, remember, do not tighten the battery tube so tight, that you can’t break it loose in less than a heart beat……to break contact if need be…
I plan to leave mine stock for much the same reasons. The cells will last longer as well.
On that note… I’ve been using mine mostly on moonlight mode and when I use it outside staying just below 2 flashes of the switch LEDs. When I started this the light told me I had 4 volts. It’s still at 4 volts 1.5 weeks later. My point is that I like the efficiency of this light. It’s a very nice blend of efficiency and light blaster when that’s required. Very nice light.
On a recent trip to Florida to clean up after the hurricane, I had an interesting experience with my Q8. They ended up having to check my carry-on bag which contained my Q8. The batteries were inserted, but I unscrewed the battery tube and used a bike inner tube “rubber band” to make sure that the mechanical lock-out was maintained. TSA went through my bag and checked out my Q8. When I opened my bag in Florida my Q8 was turned on! Luckily it was on a low enough level that heat was not an issue. It’s funny how my efforts to keep my light from turning on during the flight were foiled by the Transportation SAFETY Administration.
Thank you Jason. I made that mistake earlier, as shown to me in my preview of the message. I changed it quick, and then could see it. I also see it in my original comment.
Odd.
I would very much like to see some before/after pics for this, if you can. It’s my favorite emitter. The only thing holding me back a little is there’s likely to be a large lumens drop.
Weird - I looked at my first 2nd batch light carefully, one I just got today, and can't see any traces of AR coating. Maybe need a little more work at it with these ol eyes. Unless they changed at some point. The one I got today was shipped Sep 30th.
Tom. With all the Narsils out there at the moment I’m a little confused with which is the latest one for the Q8. Could you please post a link to the latest one. Thanks.
