https://www.fasttech.com/products/1601/10002364/1195010
I’ve always bought lights based on BLF reviews so I’ve never felt the need to write a review till now
To view any pics in full size please right click and click view image
Specs
105C driver, Low Voltage Warning, Reverse Polarity Protection, Mode Memory
Flashlight Modes - Group 1 (5-Mode): Lo (5) > Mid (40) > Hi (100) > Strobe > SOS; Group 2 (3-Mode): Lo (5) > Mid (40) > Hi (100)
Coated Glass Lens
Reflector Type Aluminum Textured/OP
Switch Features Glow-in-the-dark
Switch Type Clicky
Light Source BIN U2
Light Source Color 1B
Light Source Model XM-L
Battery Form Factor 18650
Dimensions
Depth 24 mm
Height 124 mm
Width 24 mm
Product Weight 78 g
FASTTECH SKU 1195010
Body only
Pill
Hollow head
Reflector and lens
Backside of pill installed in the head
Head
Tailcap
Innards of tailcap
Empty tailcap
Empty tailcap from the outside
Reassembled tailcap from the back
Two flaws, present when light arrived
Alternate view of same flaws
Pros
It has a floodier beam with less throw then most lights I’ve encountered which comes in handy in some situations, especially when used indoors
It can take protected cells
Many lights have a turbo mode that you can’t bypass, I think of this light as having a user controlled turbo (see overheating below)
Cons
If jostled the right way an unprotected cell can lose contact for a fraction of a second, leading to a flicker and sometimes the low voltage warning
The head heats up very quickly, and can get too hot to hold after 5-10 minutes if used on high, i don’t know what would happen if it were left on till battery depletion, would there be LED damage or just your hands burned? Therefore i use medium the most and high for short periods.
There was a blob of thermal paste under the star which would reduce heat transfer, but is easy enough to remove
Thoughts
The quality of the anodizing is great except for the nicks shown above
If the lens is coated, I can’t tell, most coated lenses i’ve seen have a green or purple hue, but none is seen on this light, however that doesn’t mean it is not coated
The tailcap end has the double brass treatment, the headcap does not, however most people won’t be opening the headcap very often (except for certain BLFers) so brass inserts are not really needed on that side
The lanyard broke after about 2 weeks, fortunately it happened to fall on my chair so no harm done
The light took about 2 weeks to arrive, which is faster then my order from intl outdoor (registered) and any other order I’ve received, I dunno how they do it
The tailcap threads were anodized but the headcap ones are not, its an example of cutting costs by using cheaper solutions where they won’t be seen and don’t need the full treatment (this ‘feature’ is not a big detraction for the light, its rather inconsequential)
The tailcap didn’t need lubrication on arrival, but the headcap did, and on my Convoy M1 both ends needed lube (yes, pun somewhat intended)
This light uses the venerable 105C driver, but with a twist, it has 2 group modes, Low-Med-High and Low-Med-High-Strobe-SOS
You toggle between them by putting the light in low and waiting a few seconds for a single flicker then quickly turning off the light or changing modes brings you to 5 mode operation.
I find this to be annoying and have ended up in 5 modes inadvertently a few times, and also several times the light has changed groups on its own. My Convoy M1 also does this so its not a specific problem with my light
One can hope that soldering the correct star can get rid of the 5 mode group.
Summary
This light is great for situations that need more flood then an average light, and do well on medium output for longer periods and high for short periods (under 5 minutes)
The quality of construction is excellent, rate of thermal transfer is great, and the only problem in everyday use is the unprotected cell jostling issue, but it doesn’t come up unless you subject the light to a good force (say with your hand)
Writing this review has shown me how much of my photography skills come in handy and how long composing a review takes, so thanks for reading, and thanks to all the other reviewers on BLF
If I’ve missed anything please let me know, i’m going to get a head shot and beam comparison with the Convoy M1 tomorrow
