Ok, so I bought the Convoy S6 from Fasttech and it came on Saturday. From what I’ve been told this is a copy/clone/same thing as the XIAOZHI. I purchased the XM-L T5-5C version which is spec’ed 675 lumens with a 3700-4000k tint. For comparison in tints, the light is quite a bit warmer than my EA4W (neutral white).
Also, I’m not much of a beam profile snob, but here’s a shot on the wall of about 2 or 3 feet away- for those who care.
I decided to purchase the T5 version because I didn’t need one of the 900-lumen scorchers, and I wanted a good balance between high and low modes. With the BLF discount code this light set me back $19 and change.
This light has mode memory with 2 groups. The first group is 5 modes with the following: Low (5), mid (40), High (100%), disco, and SOS. Naturally, I’d rather not have the blinkies. So for me, I prefer the 2nd mode group with just low, mid and high. To switch between groupings, put the light into low mode, wait for the blink then hold the light a half press for two seconds or so. In order for it to remember the mode, you will need to leave it on the desired mode for about 2 seconds. When you switch it back on it should remember the last mode. To scroll between modes just give it half-presses. The switch is a reverse clicky and it glows in the dark. Also any time you in low mode the light will blink once after the first few seconds, this is the blink that lets you switch groupings- it always happens for a fraction of a second one time while you’re in low mode.
I also have noticed a barely audible high-pitched whine while in medium mode. If there is any PWM- I can not detect it- and I’m usually very sensitive to this.
Tailcap readings from my Fasttech purchased Uni-T UT50B multimeter are as follows.
High 2.14a
Mid 1.07a
Low .13a
Mode spacing works for me. The low mode is probably equivalent to the brightness of a 1st generation 3AA mini maglite LED. The high mode is pretty bright- but not quite as bright as my EA4W on turbo.
Ok photos.
The light has a matte black finish, with no markings of any kind. No annoying websites, or anything. It’s plain and very tubular and symmetrical.
The finish on mine was flawless, and the machining is all excellent.
It also tailstands. The tailcap does make it ever so slightly wobbly- but it never fell over.
It comes apart in three sections. The battery tube, the tailcap, and the reflector/pill section. There are two O-rings on either end of the battery tube (although I accidently pulled one off in the photo.)
