CRELANT 7G3CS CREE XM L2 960Lm
Price 23$ ( after coupon LED2015GB)
Order from GearBest: http://goo.gl/x7bymC
Model: 7G3CS
LED: Cree XM-L2 U2
Luminous Flux: 960Lm
Color temperature: 6100-6500K
Switch Type: Tactical Clicky + side switch
Feature: Lightweight, Infinitely Variable Brightness, Integrated Heat Dissipation Design, Lanyard, Stainless Steel Bezel, Pocket Clip
Function: Hiking, Camping, Night Riding, Household Use, EDC, Walking
Battery Type: CR123, 18650
Battery Quantity: 1 x 18650 / 2 x CR123 battery (not included)
Mode: 4(High; Low; Strobe; SOS; Dimming Light)
Mode Memory: Yes
Waterproof Standard: IPX-8 Standard Waterproof (Underwater 2m)
This is my third light from Crelant, and after one week from receipt decided to share my opinion, and how impressed I am, with very good quality-price ratio from Crelant flashlights. Also Crelant light have one of the unique UI known as infinitely variable brightness or dimming from 1% to 100% which I like a lot. Strobe and SOS modes are hidden and you can preset your output however you like ,or depending on the application.
It came in very nice military-style packaging
Spare O-rings and lenyard are included
Deep and shiny OP reflector with perfectly centerd XM-L2
There is no AR coating,but glass is really clear and 2,5mm thick
Compared to BLF A6, Crelant reflector is wider and deeper
bezels seems to be stainless steel,witch can be very helpful
Perfect tipe III Ano,and good knurling makes very nice feeling in hand, also side switch is in perfect place just under your thumb.
With 134 mm lenght its more close to EE X6 then Convoy S2,or A6
ss clip is the same as on X6
threads are sguare on both sides,and prelubed
There is no pill, integrated shelf for LED makes heat transfer much better
Springs are a bit long for my taste but 1mm in thickness. Forword tactical switch feels nice on touch and can stand
HI amps from driver.
Driver is protected with plastic,which can be easy removed
Big plastic centering ring above LED and aluminium mcpcb
Reflector sits on that plastic ring,with no moving around
Really thick glass,and O ring
I have done some measurements with thick copper wire instead standard probes and get 3.01 Amp on tailcap at start with LG HG2 fully charged,and 2.88A after 15-20 sec, which is very impressive and close to the 960 claim lumens.
Beam pattern look almost identical to BLF A6,but due to dipeer reflector hotspot is a little smaller,and
does have better throw.. (150-200 meters)
Because camera auto setings you almost can't see the difference from 5 meters between this two lights.
In real A6 is about 20-30% brighter on turbo as expected,but on level 6 output is identical.
Mouse over for Crelant 7G3CS
A6 is on turbo,Crelant on HI
Again mouse over for Crelant
Impressions:
As I said at the beginning I am really pleased with this flashlight, and I think that is the right budget option for those who want excellent quality and unique user interface for a fraction of how much would you pay for a more well-known brand,as a Nitecore P12,and others similar flashlights.
Cons:
Might be too long for someones taste as a EDC light, more tint option would be nice
