Protection Circuit (Against overcharge, over discharge, over current and short-circuit.)
4.2 volts max voltage and 3.6 volts nominal voltage
This is the latest cells from Panasonic with the highest capacity.
The cell used can be discharged down to 2.5 volt, in my test I only discharges to 2.8 volt, i.e. I do not measure the full capacity. But then, not all lights will be able to use the full capacity.
These batteries are good at both low and higher current.
Conclusion
This battery has higher capacity and better high current capacity than its predecessor (3100mAh/NCR18650A).
With the added protection from Keeppower it is a very good battery.
Notes and links
Keeppower is a OEM manufacturer, i.e. many of the batteries they produce is sold with other names on them.
The batteries was supplied by Keeppower for review.
Am I reading the information right? 11 amp draw before the protection circuit kicks in? If that is right, I will be getting a few of these to replace some of my IMR AW’s. For safety’s sake.
Hey I know these are only available in large quantities I.E. 100 pieces. I don’t have any need for that many batteries… yet
I’ve made an inquiry as to price for 100 pieces.
My question to y’all is if I make a purchase of these batteries direct from source at 100 pieces would anybody be interested in buying excess batteries off of me. I don’t yet know what the cost is seing as I just sent the inquiry 5 minutes ago. But I will keep y’all posted.
Well it looks like I can pick up 50 or 100 pieces and sell what I’m not going to use at about 8.50 a piece plus S&H and make a small amount back in my pocket. If enough of y’all are interested ill buy some and share the love with this new incredobat. PM me if you think you’d like to buy some pending a purchase from keeppower.
