A bit hidden in this thread here I posted a quick output test of a red XR-E (it appeared to be called XR-C actually although the die size is more like XR-E
). I was told there that the XP-E was much better, but I did not have a red XP-E to test that. In the meantime I got one (from Fasttech), I put it on a 16mm Noctigon and did the test yesterday, the graph below also has the data from the XR-C I tested for the other thread. I do not have a clue what bin was used for both the XR-C and XP-E. The XR-C was a bit more to the orange side than the XP-E, now I found in my emitter-box another red XR-C that did have the exact the same colour as the XP-E (probably 630nm instead of 620nm), in series on the led-tester at 50mA the brightness of both XR-C's looks the same.
As usual, the emitters were tested outside a flashlight, mounted on a big aluminium block, directly connected to a bench power supply, a reflector placed on top facing the ceiling, output was measured with a lux-meter, of light bounced from ceiling.
So this is a test on a few emitters that have been around for quite a while and while the test could be more thorough (like finding out the exact bins), the differences are clear enough, and I believe there's a few people interested anyway.
The die of the XP-E is clearly smaller than the XR-C, if you measure the surface area, it is a bit over 30% less, so at the same output, the surface intensity of the XP-E die should be 50% more. The XR-C was on its aluminium board (copper does not give much gain over aluminium with the XR-C), the XP-E was mounted on a 16mm Noctigon copper board. (the second picture is a stereo pair, for fun).
So indeed this XP-E has all the advantage of the world compared to this XR-C: lower Vf with higher output, higher max. current, smaller die for better throw, and there are dedicated copper boards available (although you can mount the XR-E on a MT-Noctigon).
I hope there's someone who finds this useful. (I have not seen any red XP-E2's in the wild yet, by the way. EDIT: I see now that cutter has the red XP-E2, too expensive for me to order there, but they are around, at least).
