USB Power Supply/charger Test
I decided to check a couple of cheap USB power supplies and also a few more expensive ones. Recently there have been some tear downs of USB power supplies on the internet, where people has shown how bad quality and safety they where, I decided to also include a tear down to see how safe they look.
In the test I also included a test with a high voltage ohm meter, to see how much voltage they can handle between mains and low voltage.
Note: Many people call these units USB chargers, but they are not battery chargers, if you connect a battery directly to them they will damage the battery. Most of the time I will call them "ps" for power supply.
USB Power Supply #1
Name: EU USB AC Power Adapter Charger For iPod iPhone 3G S 4G
Official specifications:
- EU AC Plug.
- Output: 5v - 1A.
- Input: 100-240v - 50/60Hz 0.15A.
- Easy to use, plug and play. No installation needed.
- Featuring a new, ultracompact design, this power adapter offers fast, efficient charging at home, in the office, or on the go.
- It works with any iPhone and all iPod models with a dock connector.
- Compatible with: iPod Nano, iPod Video, iPod Touch, iPhone, iPhone 3G, iPhone 3GS?iPhone4G.
- Color: White.
- Size: 5cm x 3cm x 2.5cm.
Measurements
A small PS that can deliver 1A, lets test it:
The PS can supply about 0.6A, but the voltage is slightly low.
How does it handle the load over time, in the curves below I test for one hour.
At 0.5A it is only slightly below minimum voltage.
but with 0.6A it is significant below.
How does the output look at 0.5A:
A lot of spikes, this might be fine for running a simple charger, but not for anything electronic.
High voltage test failed.
Tear down
The electronic can be pulled out of the box with a bit of force.
The ps has a single rectificer diode, that charges a 2.2uF capacitor. It has two transistors and a opto coupler for feedback. This opto coupler is the reason for the stable voltage during load sweep.
There is not much space between the mains and the low voltage side.
The (mostly missing) resistors R6, R7, R8 and R9 is used to make it Apple compatible.
The distance between the two red lines is what it protecting the user from the mains voltage. This distance is way to low (The ruler has 1 mm between tick marks)!
USB Power Supply #2
Name: USB AC Power Supply Wall Adapter MP3 Charger EU Plug 35DI
- Color : Black
- Compact and exquisite design, convenient to carry
- USB interface
- Fast charging speed and low power consumption
- Suitable for DVs, cell phones, MP3 players, PDAs and etc.
- Input Voltage:100-240V 50/60Hz 0.1A
- Output Voltage: 5V 500mA
- LED power indicator.
- Build-in Smart IC chip can recognize a full battery and automatically switch to stand-by mode to protect your cell phone's battery from over charging
Measurements
According to specifications this ps can deliver 0.5A, how does it measure:
That load test shows a very interestning looking curve, the ps start at 6 volt, drops to 4.5 volt, goes up to 5.5 volt and drops again. This is not good!
At a 0.3A load the ps will stabilize at an acceptable voltage after 10 minutes.
At a 0.4A load the voltage is way to low.
How does the output look at 0.3A
The output is not very stable and has a lot of noise, this can also be used for a charger, but is not very good for anything with electronic in it.
Tear down
One screw to remove and it is open.
The ps has a single rectificer diode, that charges a 2.2uF capacitor, this is very easy to see in the output with the 20 ms periode time. It has one transistors (or IC) and not feed back, i.e. very bad stabilization as can be seen on the load sweep curve.
Notice the twisting trace at the red wire, it is probably supposed to be a fuse.
This ps has much better distance from mains to low voltage side.
USB Power Supply #3
Name: EU USB Wall Home AC Charger Adapter For iPhone 3G 3GS 4 4G 4SAC Adapter EU
- USB AC Adapter Charge for iPhone 3G 4G 4S
- Compact and lightweight, easy to use and storage
- This power adapter offers fast, efficient charging ,great for home use and traveling
- World traveler (100-240V). The innovative travel charger automatically adjusts to all voltages and frequencies in the Europe
- Patented circuit board design to protect your valuable gadgets from short circuits
- Compatible With: iPhone 3G 4G 4S
- Plug: EU plug
- Input: 100V-240V 50/60Hz 0.15A
- Output: 5V 1A
- Size: 66 x 34 x 14mm (approx)
- Color: White
Measurements
Again a 1A ps, how does it live up to that:
It does deliver 0.5A with a good voltage.
When it gets hot, the voltage drops a bit, but because it starts well above the minimum limit, there is no problem.
The output is not very stable, and has a lot of noise, it is not very good for anything with electronic in it.
Tear down
The glue used to keep this ps together was very easy to break (Oops).
On this ps the two usb data pins are shorted, this signales that it is a dedicated charger.
The resistor with brown-black-gold might be working as a fuse.
There is a good distance between mains and low voltage side.
USB Power Supply #4 Ioncell
Name: Ioncell 4 USB 2A Power adapter
- Input: AC 100-240V ~50/60Hz 15W
- Output: 5V DC 2A (For 1-4USB)
- 5V-2A using 1 USB
- 5V-1A using 2 USB
- 5V-0.66A using 3 USB
- 5V-0.5A using 4 USB
- Power LED
- Can be used with a 2 Prong/Figure-of-8 power cable
Measurements
This is a 2A ps, the total current can be drawn from a single port or from multiple ports. Can it really deliver 2A?
The answer to that is definitly yes, it has absolutely no problems delivering 2A, it can deliver considerable more.
The output is perfectly stable while doing it.
The ps does also show a nice output with 3A, at least for the first 30 minutes.
How much current can it deliver, here I tries 3.3A, sadly that was fatal for the ps. After I removed it from the test bench it could not power up anymore.
How does the output look at 2A:
Very smooth output, perfect for anything.
Tear down
I could not open this ps, except with help from a Dremel.
This ps has a nice construction with input noise filter, bridge rectifier, control IC and opto coupler feedback.
The four usb outputs are in parallel and there is some resistors to control the voltage on the data pins, probably to make it compatible with Apple.
It does also have a capacitor between primary and seconday, this is used to reduce noise and due to safety it MUST be a Y capacitor. The capacitor looks like it is.
This ps uses a real chip for control, it is called THX203H
There is a good distance between mains and low voltage. At the usb connectors it looks like the distance is short, but when the pcb is in the box, there is a plastic shield between the mains and the low voltage section.
USB Power Supply #5 Skross
Name: Euro USB Charger
- Ideal for iPad, iPhone and all other USB devices
- Suitable in all countries with Euro plug standard and modularly compatible with all SKROSS Adapters worldwide
- 2 USB ports for simultaneous powerful charging
- Input range: 100 – 250V
- USB Output: 5V / 1300mA
- Colour: white
Measurements
This ps has two usb output, that can deliver a total of 1.3A according to the specifications, lets check:
Between 1.2A and 1.3A and then it shuts down, this is very nice doing.
Running a load test for 1 hour is no problem, it has perfectly stable output.
How does the output look at 1.2A:
Only a little noise, can be used for anything.
Tear down
This adapter does not use wires to connect from the plug to the pcb, but some custom clips.
This ps is designed with a bridge rectifier and a control IC. I cannot see any feedback, but it has a very good regulation anyway (It is probably using a extra winding on the transformer for regulation).
The distance between mains and output is not that long, part of it is protected by the plastic shield.
Note: There is something that looks like a PCB trace near the wide slot, but it is not.
Nothing is hidden under the USB connectors.
USB Power Supply #6, KY-738
The charger was rattling when I got it, that turned out to be some loose plastic pieces inside the charger.
Name: MP3 MP4 Mobile Cell Phone EU Plug USB Power Adapter AC Wall Charger
- Product Name: USB Power Adapter AC Wall Charger
- Input: AC 110-240V 50/60Hz
- Output: DC 5V 500mA
- Plug Type: USB to EU Plug
- External Material: Plastic
- Color: Black
- Overall Size: 60 x 36 x 56mm / 2.4" x 1.4" x 2.2" (L*W*H)
- Weight: 27g
- Package Content: 1 x USB Power Adapter AC Wall Charger
Measurements
This ps has one usb output, that can deliver a total of 0.5A according to the specifications, lets check:
About 0.4A, then the voltage goes below the minimum limit, this is below specifications.
The green led on the power supply turns on at about 90 to 100mA load, the red is on when it has power.
With a 0.35A load there is no problem running for 1 hour.
Increasing the load to 0.4A does not look good, the voltage is way to low.
How does the output look at 0.35A:
It has some noise in the output.
Tear down
The ps has a single rectificer diode, that charges a 2.2uF capacitor. It has two transistors and a opto coupler for feedback. This opto coupler does keep the output fairly stable, but because the ps cannot deliver much power, the output will drop at around 0.4A.
USB Power Supply #7
Name: USB AC Power Supply Plug Adapter for MP4 MP3 Charger EU
- Output Voltage: DC5V
- Charges most USB devices and MP3 Players
- Works with most devices that can be charged with the USB Port
- Save the hassle of finding a computer to charge your USB devices
- People who needs to charge their MP3 players frequently necessary to have one
- Color:White
- 1x USB AC Power Supply Plug Adapter
Measurements
This ps has one usb output, that can deliver a total of 1 according to the specifications, lets check:
About 0.6A, then the voltage goes below the minimum limit.
The output at 0.55A looks nice.
At 0.6A the voltage varies a bit, probably due to temperature changes
Increasing the current a bit more and the voltage is far below specifications and not very stable.
How does the output look at 0.55A:
There is a lot of noise in the output.
Tear down
The ps has a four rectificer diode (i.e. a bridge), that charges a 2.2uF capacitor. It has two transistors (one of them a power transistor) and a opto coupler for feedback. This opto coupler does keep the output fairly stable.
It does also have a capacitor between primary and seconday, this is used to reduce noise and due to safety it MUST be a Y capacitor, but the used capacitor is not.
The distance between mains and low voltage is way to short on this ps.
USB Power Supply #8
Name: BlackBerry Power AC Charger Mini Micro USB Adapter EU
- Compact, lightweight, and portable.
- Easy to operate, carry around and store, very convenient indeed.
- Powers handset and charges battery.
- Rapid Charge.
- Single USB Port.
- Compatible with any Blackberry device with the appropriate USB Cable (mini or micro):
- Blackberry Torch 9800 Bold 9700 Style 9670 Bold 9650 Tour 9630 Storm2 9550 9520 Storm 9500 9530 Blackberry Curve 8300, 8310, 8320, 8330, 8350i, Pearl 8100, 8110, 8120, 8130, 7250, 7520, 7100 and more.
- Input Voltage: 100-240 Volt.
- Output: 5V.
- Size: 3cm x 3cm
- Color: black.
- 1 x BlackBerry Power USB AC Adapter EU
Measurements
This ps has one usb output, that can deliver a total of 0.75A according to the specifications, lets check:
About 0.65A, then the voltage goes below the minimum limit.
The output at 0.65A looks acceptable.
At 0.7A the voltage is way to low.
How does the output look at 0.65A:
Tear down
The ps has a single rectificer diode, that charges a 4.7uF capacitor. It has two transistors (On smd and one power) and a opto coupler for feedback. This opto coupler is the reason for the stable voltage during load sweep.
The main capacitor is mounted very close to the usb connector, this is not very safe.
It looks like there is a white line between mains and low volt on the pcb, but this does not help with the distance, that is very short.
USB Power Supply #9
Name: 230V til 1 x USB lader - 1000 mA
- Charge function by 100-240 V / AC
- Input Voltage: 100-240V AC
- Output Voltage: DC 5,0V
- Output current: max.1000mA
Measurements
Looking at this curve, the ps can deliver 1.4A, this looks very good.
The first test at 1A does not work as expected, after 23 minutes the ps begins doing funny stuff.
Doing a test at 0.9A works much better.
I was curious about 1.4A load, as can be seen above it can do that for about 5 minute.
How does the output look at 0.9A:
Tear down
No tear down for this charger (It requires a Dremel to open).
USB Power Supply #10
Name: 230V til 2 x USB lader - 2000 mA.
- Input Voltage: 100-240V AC.
- Output Voltage: DC 5,0V.
- Output current: max. 2000mA (1xUSB).
- Max. 1000mA (2xUSB).
- Dimensions: 64.5 x 40.7 x 62.4 mm.
Measurements
This ps has two usb output, that can deliver a total of 2A according to the specifications, lets check:
Looking at this curve, the ps can deliver more than 3A, this looks very good.
A test at 2A looks very good.
A 2.5 test does also look very good. I am not going to test at higher current, I do not want to risk damaging this ps.
The ps has a very nice output voltage with low noise.
Tear down
The ps has input noise filter, a rectificer diode, that charges three 6.8uF capacitor. It has an IC and a power transistors. There is no opto coupler, but it has a fairly stable output anyway.
It does also have a capacitor between primary and seconday, this is used to reduce noise and due to safety it MUST be a Y capacitor and it is.
There is a very good isolation distance between mains and low voltage on this charger.
USB Power Supply #11
This ps is the same as #3, but from another dealer.
Name: EU PLUG USB POWER ADAPTER TRAVEL HOME WALL CHARGER FOR IPHONE 4G 4 4S IPOD
- Color: 8 colors ( blue/white/orange/black/green/purple/rosy/red)
- Plug: EU plug.
- Input: 100V-240V 50/60Hz 0.15A.
- Output: 5V 1A.
- USB AC Adapter Charge for iPhone 3G 4G 4S 4GS/iPod
- 1 x USB Charger
Measurements
This ps has two usb output, that can deliver a total of 1A according to the specifications, lets check:
Looking at this curve, the ps can deliver about 0.5A.
Doing a actual load at this current, shows that 0.5A is a bit too much for this ps.
Reducing the current to 0.45A looks much better.
How does the output look at 0.45A:
Tear down
USB Power Supply #12
This ps looks the same as #2, but when looking at the tear down it is easy to see that the construction is different.
- USB interface
- Color: Black
- 1x EU Europe USB Wall Charger Adapter for PDA DV Mp3 Mp4
Measurements
Looking at this curve, the ps can deliver about 0.35A.
Doing a actual load this, shows that 0.35A is a tiny bit too much for this ps (the voltage goes below 4.75 volt).
Tear down
The ps has a single rectificer diode, that charges a 2.2uF capacitor. It has two transistors and a opto coupler for feedback. This opto coupler is supposed to stabilize the output voltage, but does not really work.
There is some isolation distance.
USB Power Supply #13
This ps is nearly the same as #1, but from a different dealer.
Name: EU Plug USB Wall Charger AC Power Adapter For iPhone 3GS ...
- USB adapter wall charger for iPhone & iPod, except iPod Shuffle
- Suitable for home, office or on travel use
- This item with protective circuit to prevent overcharging (IC chip)
- Compact and exquisite design, easy to carry
- Color: Green
- Input: 100-240V, 50/60Hz, 0.15A
- Output: 5V, 1A
- Plug: EU Plug
- Size: About 4.5 x 2.5 x 2.5cm
Measurements
This ps has one output, that can deliver a 1A according to the specifications, lets check:
Looking at this curve, the ps can deliver about 0.6A.
Trying to draw slight more current does not work.
How does the output look at 0.6A:
Tear down
I have marked the mains connected parts with red and the low volt parts with blue. There is less than 0.5 mm between them.
This is extremely unsafe.
Conclusion
With the cheap chargers I had not expected much and the result proved that. The isolation distance is seldom large enough and many of the chargers has a lot of noise in the output. There is also a problem with the output current, it is often considerable lower than rated.
Looking at the result, the only ones I will be using are 4, 5, 9 and 10.
Number 1 and 13 is way to dangerous to use
Notes
5, 9 and 10 are bought in Denmark, this means higher price (Denmark is very expensive) and probably better safety due to EU regulations.
Efficiency and noise is measured at the "Measured current"
In the tear down section for each ps, it is possible to click on some of the pictures to get larger versions.
One important aspect of safety is the transformator, in the above I have not disassembled it to see if it is safe, but anything that can handle 5kV will be mostly safe.
