This is what I do, Build it outside the light using long leads. Use your batteries fully charged in your desired set-up.Take your amp probe and test at the LED’s then trim the leads to you get the desired amp reading or Poof one! :+1:
I am hoping to get some numbers before long, KB was nice enough to offer up some sacrificial LED’s to be killed tested.
I got some early numbers from a low bin C4 90+ CRI HD and they were pretty good, it handled 3A for quite awhile without an issue and even handled PWM from a full 16.8V. I think these are tougher then we have given them credit in the past.
That said from the early test output seems to peak at ~2.8A with very little gained over 2.5-2.7A but I will wait till I have the nicer bins to make any conclusions.
Yeah, I think I recall reading here somewhere that going over 2.8A doesn’t give much… But still, interested to see any test results where some actually end up frying :smiling_imp:
Also remember to let the LED warm up a little before going full power.
I recently killed an XP-G2 by cold starting it immediately to 6A and the tiny gold wire blew.
With my other XP-G2 I left it on medium for quite a few seconds before switching it to 6A and it survived
I have noticed this as well. In the sweep test it will be on for a long time as I build up to max power. Although once lumens start dropping I will most likely turn it off, let it cool down and start the test from that point again to see what happens.
When I did this test a few days ago, I basically had my emitters floating in mid air so I only let them have power for a second to get the reading then quickly shut them off. Even in that 1-3seconds, I got a little smoke. I figured it was due to the non-existent heatsinking. I now have the 4 of them in a TM16 head and I’m testing again. I’m up to 240pwm level = no smoke, but as soon as I give them direct drive, I see the smoke. This is still while drawing around 8.5amps according to my clamp meter. Under inspection, the emitters look immaculate. I’m not sure where the smoke is coming form.
Wait a sec… just got a “low battery” on the meter… brb —— New batteries=same results
Interesting. What bin XHP35 are you using? Based on my measurements of the forward voltage of the XHP35 HI E2 3C, I estimate more like 12.5A in total flowing to the 4 emitters direct drive. Maybe your emitters have a higher forward voltage or there is more resistance in your circuit than in my calculation.
If you put them in parallel without balancing resistors you could get one with a relatively low forward voltage, resulting higher current to that emitter
