WTB: Jetbeam RRT01 – Any place to buy it?! + [RRT01 2019 discussion]
X3 check your inbox
thanks for sharing the link
I agree it changed during the day
a triple sw45 for 150 cant be bad… Im impressed
add trits for $75… and Glow!
Rotary UI
High CRI LEDs
Game Changers
That’s a lovely offer, PM incoming
My 2019 version :
SST20 3000K, triple MCPCB from KD (1mm thick) and their optic (really smooth beam), plus a small alu spacer that I made today at work.
I had to add some length to the stock wires, but the good news is that the stock pill already have a 4mm hole right in the center.
It’s not waterproof anymore, I like when the optic sits flush in the bezel but it’s doable with an o-ring too.
I love it already.
Oh, it does 600 lumens on the highest mode too… not too shabby for a 95CRI 3000K source !
(the precedent LH351D with stock reflector was about 470 lumens, talk about low current efficiency !)
beautiful work!
thanks for the photos and info about LED options, parts, and optics you used
you could almost build a kit, or people could copy your example, if they had a few specs for the spacer… etc
can you line up some of those LEDs so I can see what they look like?
iphone, daytime, white printer paper:
If anyone would like to buy the new model RRT01, Fasttech has a 20% off sale going on that brings the price down to about $49 bucks shipped to the US.
Use code CHERISH for 20% off. https://www.fasttech.com/products/9691168
Nice comparison pics jon_slider :+1:
thats a great price!
and thanks for liking my pics
a couple advantages, or differences, of the New model
  1. Strobe
  2. Protected 18350 fits
  3. unmodified Carclo fits, so people can add a tritium head from Andy
New model RRT-01 on left:
note slight tribute resemblance to McGizmo PD
maybe your little cnc shop or RPM will offer a trit bezel for the new and original RRT-01’s
and Big Hope that a Titanium Version of the Original RRT-01 is re-released, with tritium fins… in my dreams… lol
“(factory trit precedent: Sunwayman Ti Dream)”:[Review] SUNWAYMAN M11R Ti Dream (XM-L2, 1x (R)CR123a) - #18 by hIKARInoob
I started a trit bezel poll here, for the Jetbeam Rotaries:
Maybe flash sale is over? Coupon code invalid, but current price is $55.67 which is still very good.
M4D M4X has a code for this light, I cannot say the price. See his thread for details, or just message him.
Thanks to Jon_Slider, through him I got my first old RRT-01 and also thanks to M4D M4X for the money saved when buying the new 2019 RRT-01 :+1:
Both are now converted to Nichia 219C 4000K and I am very happy about these two jewels!
Code works for me - make sure you use CHERISH without any space at the end.
So I replaced the clip on my 2019 RRT01 by a shorter one, which is far better.
It’s the same as the pic just above my post, it comes from an Enogear SS 11 flashlight…
Does anyone know where I could source a spare one ?
yes, thanks to toddcshoe:
Thank you jon_slider !
With the help of BanL (Thanks BanL) I finally got a variety of reflectors. After trying several different reflectors from Fasttech that didn’t fit, I even cut one down on the lathe to fit but was worse than the stock reflector my KD shipment finally came in. I now have two reflectors here that drop right in to original RRT01 with no modifications.
The both produce a very nice beam compared to the original reflector. I have only tested them using a LH351D shaved dome led but I don’t expect them to be any different with a 3535 led. Nice hotspot with even spill and no visible rings.
Reflector #1 being slightly larger in diameter (19.4 mm in diameter).
Reflector #2 slightly smaller in diameter (19.3 mm in diameter).
They look identically to my eye but when measured KD list the right dimensions, one is .1 mm bigger than the other.
They are OP reflectors but are very fine ripples, barely noticeable.
To me with the shaved LH351D the smaller #2 reflector has a slightly better beam but ever so lightly. It could be it just looks better with the shaved LH351D.
There not that expensive so it might help to order both and see which one works best for you.
The best thing is they drop right in with no rings… :+1:
Great info on an alternative reflector for the Original RRT-01 to help eliminate rings in the beam
I will go ahead and order some to try out.
Thank you moderator007 for your efforts and generous sharing of information
a friend reports his stock reflector in an Original RRT-01 does not have a problem with rings in the beam using a 5000k 219c, but I certainly do have a problem with a 219b in an original RRT-01 w original reflector
I lent the Original RRT-01 w 219b to a friend, and he noticed the rings too, so Im really looking forward to trying the alternate reflectors.
It opens up some better possibilities for a run of Single N219b LED modded Original RRT-01.
woohoo!, going shopping :slight_smile:
Done! ordered 3 of each…
Awesome thanks for doing this. Ordered!
Thanks! Ordered.
Thanks! Ordered
Now that I’ve used mine so much, I wish Jetbeam would make a 18650 body for it…
I thought about modifying mine with a lathe to add so length in the narrowest part of the original tube but I’m afraid of ruining it…
