Review: Coast LED Lenser Mini Tac Torch
61 posts / 0 new
jekostas
Last seen: 10 years 1 month ago
Reviewer's Overall Rating: ★★★★☆
Summary:
Battery: 1xAAA
Switch: Forward Clicky
Modes: Single
LED Type: 5MM Nichia GS
Lens: None
Tailstands: No
Price Payed: $3.50
Date Ordered:11/20/2010
Pros:
  • Forward clicky!
  • Low price
  • Near ridiculously good battery life
  • Excellent build quality
Cons:
  • Ugly, ringy beam
  • Doesn't tailstand
  • Price only valid for Canada and US<--break->
Features / Value: ★★★★
Time for a new review!  This one is a little bit different from my last two reviews in that instead of a super-high-tech pocket rocket/hand burner/signal light, I'm looking at a very basic, well built, low-output torch, but one that's got a few very cool tricks up it's sleeve.  For those of us in Canada and the US, this light is available for the cost of shipping ($3.50) from coastportland.com from the front page.  Outside of those two countries, you'll probably pay close to $10 for the light, but that's not a bad deal for what you get either.
The torch I'm examining today is the Coast LED Lenser Mini Tac Torch.  There's been something like a half-dozen different versions of this light, but the latest (and I think the best) version is the one I'm looking at.  It's rated at 8 lumens for 18 hours off of an alkaline battery, and as such seems to be aiming squarely at the Fenix E01.  Same build, same LED, similar output and battery life numbers.  This is a picture of the packaging for the current version:
Package
Not my picture, unfortunately.  The light really doesn't come with much, just the light and a crappy alkaline battery, not even a split ring for the tailcap, but it's at least enough to get you started (and who doesn't have split rings laying around these days?).  The feature set is otherwise pretty nice - HA-II level anodized aluminium, "premium" Nichia GS 5MM led, forward (!) clicky, and a two-step driver similar to Fenix's.
One thing to note is that this light is on the large side for AAA keychain lights, as it has both a clicky switch and springs at the head AND tail for impact resistance.  Here it is compared to my current keychain light, the Mr Lite KC-05
Comparison
Quick picture of the back of the light as well, showing the forward clicky.
Forward Clicky
Design / Build Quality: ★★★★
I would overall rate the design and build quality of the light as very, very good with only a few minor niggles.  The light has both a removable head and tailcap, and both have very thick washers.  They came well lubricated, and the thread themselves were very clean and well-cut.  Both the head and tailcap sections have springs in them to prevent breakage from impact.  The clicky switch is a forward clicky that protrudes slightly, but kind of lacks texturing that would help find it in the dark.
Head and tail
As can also seen from the above pictures, there's also some diamond-pattern knurling over most of the body and it does give very good grip.
The one strange thing about this light (and something that it shares with the Fenix E01) is that the Mini Tac does not use a lens.  Instead, it uses a smooth reflector for light control, and LED itself is sealed for weather resistance in to the head via silicone rubber.  This is a perfectly reasonable solution, and I'd be happy enough to use this light in the rain - just no swimming.
Coast LED
Head
Coast Head
There are a couple of minor niggles in the design that kind of detract from a perfect rating, though.  First, the light doesn't tailstand.  Normally I wouldn't place a huge amount of importance on this fact but this particular torch would make a great long-term emergency light in case of power outages (I'll get to that in a bit), and tailstanding would be a really useful feature.  Secondly, the anodizing isn't great, and a week on my keychain left a lot of noticeable bare spots on the body.
Battery Life:  ★★★★★
Battery life is where the light absolutely shines.  Heck, if I could give it more than 5 stars I would.  Since my crappy multimeter no longer wants to give readings, I had to test battery life the old-fashioned way - I just put a fresh Duracell AAA alkaline in the body and left it on.
Result?  21+ hours of usable light.
What was that again?
That's right, 21+ hours of usable light.  I started this light at midnight two days ago, and when I woke up at 8AM, it was still going strong.  At around ~9:30, it shifted in to a not-quite-moonlight mode of a couple of lumens, which is similar to the Fenix E01.  The light then kept going until about 9:15PM at night in moonlight mode, until it finally became too weak to use.  Taking out the battery and letting it rest for 20 minutes gave me about another 15 minutes of a usable moonlight mode until the battery was utterly dead.  If you take a look at the packaging again, Coast actually rates this flashlight at 18 hours of light, meaning the usable battery life was *better* than stated.  This was a pleasant surprise.  My thought right now is if you stuck an Energizer Lithium primary in to this light, it would make a fantastic long-term "emergency" or power outtage torch.
Light Output: ★★★☆☆
The light output, on the other hand, is a weakness. Not so much the lumens output (which I understand is a necessity for the battery life), but rather the beam pattern.  To put it mildly, it's ugly.  REALLY ugly.  The light uses a reflector with no lens for light output and it creates a lot of artifacts in the beam, and these are noticeable at close range.  It can be distracting, but you'll probably get used to it pretty quick if you were using it reading or as an emergency light.
Beamshot
As to tint, well, I lucked out and got a pretty neutral colour beam but there's a reason why Nichia is said to have a "tint lottery" - who knows what you'll end up with.
Summary: ★★★★
Coast doesn't really market this light as a competitor to the Fenix E01, but in reality it pretty well is - same body styling, same LED, similar battery life and output.  I also think it competes pretty well - you give up the smaller size and better anodizing of the Fenix and gain a forward clicky switch and better knurling.  Not a bad trade off, I think.  If Coast redesigned this light to somehow tailstand, I'd easily rate it 5 stars.
Edited by: sb56637 on 08/26/2014 - 17:13
Don
Don's picture
Given that I paid 5x as much for the E01, this sounds like a pretty good deal to me. The E01 is equally a long way from perfect but is HA3. Whether this is worth an extra $11.50 is entirely a matter of personal taste. Had this existed at that price when i bought the E01, I'd not own an E01.
Thanks for the review.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
brted
brted's picture
Last seen: 3 weeks 4 days ago
Good review! I am amazed how many fans the E01 has and this looks like is every bit as good. Love that it has a forward clicky.
Match
Match's picture
Last seen: 5 years 9 months ago
Ack!  The link is broken and I'm feeling impulsive... Well, hard not to when it's only $3.50.  Nice job and thank you for the review, Jekostas... Now, if I can only find em for $3.50...
jekostas
Sorry, I haven't quite figured out how to do external links using this site's format yet, but if you just type coastportland.com in to the address bar it should work fine.
Match
Match's picture
Heh...I should have stated I tried that also...It takes me to their site, but when I go to buy it, it takes me to one of their "preferred vendors" who wants $11 for it...
Ah well...
jekostas
On the front page, there should be a link that says "Free Coast LED Light".  That's where I got this one.
Match
Match's picture
Ah!  I see it now.  It just tells me "free gift" and doesn't mention what it is.....Well, I took the bait.  Here's hoping it's the same light with same decent tint you got.  Thanks again, Jekostas!
Boaz
Boaz's picture
Last seen: 10 hours 9 min ago
 Seems they are sending the Multi button cell keychain lights again instead of the AAA mini tac ..
I'm mad at myself for not getting a few more of these they are nice little cheap AAA lights ..
Coast just makes people nutty by switching around the lights they put in this 3.50$ deal
If it's a crap shoot it's not a good deal ...WAIT until they start shipping the mini tac's again .. it's a nice light for 3.50
@ 7 lumens the battery will last into the next decade
Hayley
Last seen: 10 years 10 months ago
Interesting, thanks for the excellent details about lenser mini tac torch
Match
Match's picture
Karen, my Mail Lady (yup...we're on a first name basis nowLaughing) just dropped off a plain manila envelope.  Inside was my $3.50 coast torch.  Boaz had me wondering which one I'd get, but it's safe to say I'm more than happy:
Guys, if you haven't purchased one of these yet you should.  This is a crazy good deal.  Heck, even get a couple for gifts in the future...if they come in the same box as mine it'll make a stellar present.  So far I can confirm everything Jekostas stated in his review...except runtime (although I'm looking to try this out).
  Jekostas, thanks again for posting this review....I'm off to order another (I wish they had it were you could get more than one at a time).
jekostas
Damn, that's nice packaging for a freebie light!  I got mine in the clamshell packaging, not a gift box.
fishinfool
fishinfool's picture
Last seen: 2 years 5 months ago
Dang!  The packaging alone must cost about $3.50 or so.
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
Carleton
Last seen: 10 years 11 months ago
Good review! Thanks for sharing
jekostas
Be-Seen Triker wrote:
The domed tailcap seems to be a signature feature for coast.
Just double checking... is this an AA or an AAA light?  Are there 2 modes or just one with a "battery saver" as the cell output becomes low?
This is an AAA light.  As the cell drops below a certain voltage threshold it switches to a moonlight mode, which is more or less constant for about 10-11 hours.  Very similar to how the Fenix E01 works.
sb56637
sb56637's picture
Last seen: 7 hours 47 min ago
Nice review of a nice light! Sorry I think I missed this review and I never frontpage'd it. Now it is. Smile
Pity these are only available at that price within the USA. Otherwise I'd pick one up too.
cessnapilot
cessnapilot's picture
Last seen: 4 years 8 months ago
http://www.coastportland.com/surveyCC.php
Should I splurge and see if I get the mini-tac for the 3.50? Hopefully they are still sending those
Boaz
Boaz's picture
not ringy not purpley or ugly ,Some people say they have gotten really ugly beam and odd tints minitac , these have always been a crap shoot you lay your money down and you roll the dice ...sometimes they send you a great lil light .. other times  a real piece of junk  /keychain light .  Makes life interesting ..
kragmutt
Last seen: 10 months 3 weeks ago
I did...We'll see what I get. I dunno, even their cheapest keychain light seems kinda ok. Not a deal, but ok:
http://www.lightsandknives.com/UFO_Light-_White_Beam.html
kragmutt
Yay, got the Minitac! It feels quite good in the hand. Definitely won't blow away with the output or beam quality, but can't really complain, especially for the price. Probably a fantastic emergency light for the car.
Boaz
Boaz's picture
Did you get the boxed one or the plastic  packaging .?? I got the box like match ..makes it seem much nicer .. smart marketing
kragmutt
Got the boxed one, but it's not a pretty blue one. Just black with a crooked Coast LED Lights sticker. Can't complain though.
okyeung
okyeung's picture
Last seen: 6 years 1 month ago
Got the box one, too. very nice indeed.  Thanks jekostas for the tip.
3
Zeros
I'm sorry to revive an old thread, but I had a quick question about this light.  Does anyone know if a 10400 would fry it?  I'm guessing it is direct drive, but that is just a guess.  I think the 5MM Nichia GS is only rated to 3.4 v though.
agenthex
agenthex's picture
Last seen: 8 years 2 months ago
The current that you're supposed to send through these are tiny compared to cree's, so no it probably won't work and you wouldn't want to do it even if it did.
Reading this makes you smarter: http://lesswrong.com/
Zeros
I thought so. Thanks!
SkunkApe
Last seen: 9 years 3 weeks ago
Just ordered, thanks!
Boaz
Boaz's picture
They have been sending the tiny keychain version which uses the watch batteries instead of the mini tac ..it's a very cute little nichia light too..it looks exactly like a mini tac .. it's just 1/3rd the size and just as bright ..i like both ..let us know what they are sending out when you recieve your light .
SkunkApe
Boaz wrote:
..let us know what they are sending out when you recieve your light.
Will do.  Where is a good resource for battery replacements for these little lights.  I am guessing the same size as the Streamlight Nano?
jekostas
Nah, it's about twice the size of the Nano.  I prefer the AAA battery light for run time.
SkunkApe
I would prefer the AAA also.  Beggars can't be choosers I guess.  lol
