MtnDon's hand-made entry; 9th BLF OL challenge
16 posts / 0 new
MtnDon
MtnDon's picture
Last seen: 4 hours 31 min ago
I will post here, but nothing going on yet.
MascaratumB
MascaratumB's picture
Last seen: 7 hours 23 min ago
Subscribed Wink I’ll be looking for your build Beer
MtnDon
MtnDon's picture
I took a little time to get a start on this project this afternoon. I am starting this with some copper parts the light will be built around. I have most of the parts for what I have planned. A couple of things are somewhere between China and here, so this is a small leap of faith.
The images in this thread will all be clickable to open a larger version.
Uppermost is a piece of 1/2” × 1/2” 22 gauge copper angle that I purchased as scrap from a surplus store a year or so ago because it looked like something I could use someday. The lower left is a short strip of 18 gauge copper, 3/4” wide. Lastly is a copper heatsink, 20mm x 70mm x 4mm thick, that is sold as a cooler for an M.2 SSD. These shall be silver soldered together to form a right-angle shape.
Here they are with flux paste applied.
Clamped together before soldering.
Still clamped and cooling after soldering with the butane torch.
Here’s the assembly. The visible side has been sanded smooth. There was some solder drip to clear away.
The other side where the extra length of the angle is visible. That was filed and sanded down.
Pretty much square as I wanted it.
My plan includes the use of a quad Optisolis (4000K, CRI of Ra=98 and R9=93). A Carclo 10623 quad optic will be used. That is a frosted medium spot optic.
The copper heat sink is 20mm wide. The copper strip soldered to the angle is US sized at 3/4” wide which is about 1mm smaller than the heatsink. That is visible in the 8th image above, if one looks carefully. (sorry, that corner is slightly out of focus.)
The heatsink sets the width at 20mm. The mcpcb is 20mm across the flats.
The optic is 24mm in diameter. (measures at 23.92mm). The 20mm heatsink is an actual 19.89. So I will need to file or sand two parallel flats on the areas of the optic that exceed the width of the heatsink. That will be close to the edges of the actual lens portion of the optic. Hopefully that operation will go well and not harm the beam.
I will be using a 17mm Lexel driver, purchased a few years ago. This one has no FET; just 4 – 7135 regulators, three of them are 380 mA for a total current of 1.87 amps. That will provide up to 467 mA per led. For this light that should be plenty. The body will be wood; don’t want to set it on fire! Wink The solder blobs are temporary remnants from testing. The blue wires are for the e-switch. I plan to reflash the firmware to Anduril 2. Preesntly it still has NarsilM. That is how long I have had this driver.
I need a mount for the driver. I am making one from copper tubing. I have a small collection of mm sized copper tubes. I am using a short piece of 20mm OD x 1mm wall with a shorter piece of 18mm x 1mm wall tube slipped inside the larger one.
That is all for today.
MtnDon
MtnDon's picture
I could use some help with the Andurol 2 firmware. I know from past experience with Narsil that when the FET is not in place there needs to be a tweak, otherwise there is a dead spot where the firmware expects the FET to be supplying the current to the led. At least that was true with Narsil. Back a few years ago Lexel helped set up NarsilM to work without the FET. I am uncertain where that tweak is needed and what it entails.
Is there an Anduril 2 version for no FET? Where would I find it and what is the file name? Can anyone point me in the right direction for a ready-to-go hex file?
Thanks all.
gchart
gchart's picture
Last seen: 5 hours 28 min ago
Looking good, Don!
If no one else beats me to it, I’ll take a look about the firmware when I’m in front of my PC. Could you link me to which of Lexel’s drivers you’re using? I’m sure I could find it, but that would save me some time and guesswork.
MtnDon
MtnDon's picture
I bought it in October 2017 according to my records. All I know it came with Narsil on an attiny85 and no FET, just a single 7135. Here is a better image of the FET side. That is with a dark purple mask. I don’t know much about these other than it is an attiny 85 and in the past I have been able to copy the hex file from a Lexel driver and flash it to another driver with the same hardware setup. Thanks for whatever direction you can steer me.
gchart
gchart's picture
I’m not super familiar with the Lexel / TA triple channel drivers, never had one myself. I’m pretty sure they stuck to a “standard” layout though which should be consistent with TA’s FET+6+1 driver from this thread. Based on what I see with your driver, it of course is lacking the FET and it looks like it’s set up for 3+1 7135’s (one chip on it’s own channel for low modes, the other 3 on another channel). One thing that has me curious is the solder job by the middle pin of the 7135 that’s on the same side as the t85. As long as that isn’t doing something strange with the hardware layout…
I think the closest pre-built firmware you’ll find is the FW3A-NoFET build. The FW3A was a FET+7+1 normally. The NoFET build resulted in a layout like yours, but with 8 total 7135’s. The only real difference would be that the top end is lower (3× 7135 instead of 7x), so it might look a little slower at the top end when ramping.
It looks like TK’s most recent pre-built hex files for Anduril2 are from 2021-08-31:
http://toykeeper.net/torches/fsm/anduril2/anduril.2021-08-31.fw3a-nofet.hex
It sounds like you’re experienced with backing up hex files from a driver and flashing them to another. Just to be on the safe side, it might not hurt to make sure you have that original hex file sitting around just in case you need to revert.
MtnDon
MtnDon's picture
Thanks for the links and your insight.
Yes, I will make a backup copy of the firmware that is on this driver right now before I try out a replacement. That won’t be right away as I have just decided that cedar has dropped enough in price to make it more or less sensible to rebuild a section of fence before it gets too cold.
MtnDon
MtnDon's picture
I’ll have to have a careful look at the driver out in the shop. One thing I do know is that on the other side of the driver there is no pad for the center terminal of any of the 7135’s to connect to.
I have no idea what that means. My knowledge of how these things works is limited; I copy others. I have swapped attiny chips, removed and installed 7135’s and fet’s and flashed firmware. What and how those things do the things they do is another matter all together.
gchart
gchart's picture
That’s not a problem. That center pin is one continuous piece of metal with the grounding tab that sticks out the other side. It doesn’t have to be connected there as long as the tab on the other side is properly grounded (it is).
MtnDon
MtnDon's picture
Earlier this afternoon I did a little more work on this project.
I silver soldered the two nested rings together and simultaneously soldered the pair to a piece of copper to cap one end. Why will become evident a little later.
Then it was filed and sanded round and the cap sanded to be smooth and flat.
That will have some holes drilled later. For now it will be set aside in the little box with other parts.
I verified the alignment and squareness of the soldered together copper heatsink and the other pieces.
The next stage involves making a wood block that will hold the 18650 cell in alignment with the driver, as well as provide a mount for the e-switch. The assembly with the heatsink and mcpcb, etc will be slipped inside a wood body.
Cutting with the table saw is difficult to photograph when one is both the sawyer and the photographer. Since I have managed to retain all my fingers and thumbs for 75 years I don’t want to lose one now. I took a picture of a slice being made with the saw static. Smile
I look at this block to be a test block. I’ll probably have to do a second one after I figure out just how the idea in my head is going to be made real.
So far I cut the block to 19.95mm width. I cut slight notches and rounded one corner to fit inside the 90 degree angle formed by the heatsink and the 18 gauge copper strip.
The flaw in the block side is there because this piece of stck was a door at one time and there was a screw in there. No idea why, I don’t recall any reason for a screw there.Perhaps I used this piece for something else inbetween it being a door and me pulling it out of the scrap box today. The block is longer and taller than it needs to be. Also the flat copper strip is longer than it needs to be. It’s easier to cut off excess than to try and stretch something that is too short.
It is evident that the flat copper strip is 1mm narrower than the heatsink piece if one looks carefully. That will be hidden inside the light so is of no real concern.
There will now be a pause, an intermission, while I attend to some of life’s chores. .
thefreeman
thefreeman's picture
Last seen: 37 min 34 sec ago
You can also check for continuity with your DMM to verify the pinout on the t85 to be sure about the hex compatibility. The pin to test on the 7135s is the one on the ”51” side on the pic just above.
MtnDon
MtnDon's picture
Thumbs Up
MtnDon
MtnDon's picture
I decided that since the saw was still set to the 19.9something mm width I would cut another piece of pine in case I made an error and had to redo the inside block.
I also picked where the switch will be mounted and drilled a pilot hole in the copper heatsink at that spot. No picture of that drilling, but here is the result in the copper heatsink. Plus the new wood block with one corner rounded and notched as in the first trial piece.
I used the pilot hole in the copper heatsink to mark the switch position in the wood blocks.
Then the hole in the heatsink was bored larger to fit the silicone boot that will be used.
I de-burred the underside using a countersink bit.
Note that the position of the switch necessitated soldering a small piece of copper sheet adjacent to the angle piece that was used to join the heatsink to the flat copper strip. This was done to even out a large enough area for the switch boot to mount securely.
The finned side came out a little messy. I thought that would happen. However, I believe attempting to drill into the finned side would have been more damaging.
I clamped the block in the vice and secured the heatsink assembly to that with a clamp. Then I cleaned up the fins with a small file.
This is the momentary switch I am using. It is from mountainelectronics.com. Also pictured is the switch boot I will use. The assembly needs a spacer, a “nub” inserted under the boot and over the switch activator button. I cut a tiny piece of pine for the task.
I drilled a 2mm deep recess in the top surface of the block to hold the switch ans boot. The switch and boot are held in place when the copper heatsink assembly is placed on top. The switch wires snake out through a side hole I drilled.
When depressed the switch could be heard clicking but I thought I would verify operation. One image showing an open circuit and then with the button depressed the circuit is completed.
More in the next post….
MtnDon
MtnDon's picture
Next, it was time to determine where the driver mount would go. My final choice needed some filing to the copper cap that was soldered to the ring mount.
This is where that will be mounted.
I could solder the cap in place but I figured that carried a certain risk. The heat for that soldering could cause all the other soldered joints to fall apart. So holes were drilled. The holes in the ring mount cap were tapped 2-56.
The screwed in place driver mount with the assembly positioned against the wood block for a trial fit….
Marked for cutting out…
Test fitted to the notched front…
And with that I stopped work for the day. Next work session I will duplicate these steps in the “real” wood block.
Thanks for looking in.
MtnDon
MtnDon's picture
Or maybe not. I see a possible change to be made.
