Emisar D1 / D1S review
576 posts / 0 new
DB Custom
DB Custom's picture
Last seen: 2 weeks 6 days ago
I’m bored with my D1, wonder if I can fit it with 4 20700’s and an XHP-35?
Agro
Agro's picture
Last seen: 3 hours 45 min ago
Sure you can. Just not all at the time. Actually you may have to split the batteries into smaller pieces.
bmengineer
bmengineer's picture
Last seen: 10 months 1 week ago
Your D1 might have to be bored too, if you want to run a 20700 cell in it. LOL
Building a battery pack for 4 of them would be possible, but it would look pretty silly and wouldn’t use the space efficiently.
Find all my reviews of flashlights and more gear at www.bmengineer.com
SKV89
Last seen: 1 week 4 days ago
Does anyone know why nichia 219c option is available only for D4 but not for the D1 or D1S? Seems the hotter 219C would be more fitting in the D1 and especially D1S with the much larger thermal mass.
MascaratumB
MascaratumB's picture
Last seen: 1 hour 18 sec ago
Being throwers, the XPL-HI makes a much better job “throwing” the light. Maybe with the Nichia it would enlarge the hotspot, but it would not reach so much in distance probably!
I guess the heat is not a problem on those 2 lights, but the function of “throw” would probably suffer some decrease with that LED. Even if the tint would improve!
SKV89
Ah I see. Makes sense.
Jerommel
Jerommel's picture
Last seen: 1 year 6 months ago
It will burn up with that DD ‘driver’.
With 4 in parallel they will survive better due to internal resistance of the battery and the consequential voltage sag.
ToyKeeper
ToyKeeper's picture
Last seen: 6 hours 21 min ago
Derisive quote marks not necessary, but yes, running a low-Vf emitter direct-drive from a high-amp cell will generally turn the LED into smoke.
Even without that though, the XP-L HI is better for throw purposes… and the reflector is optimized for a flat emitter so the focus would be off a little with a domed emitter.
ToyKeeper
ToyKeeper's picture
DB Custom wrote:
I’m bored
That’s a serious problem. We know what happens when you get bored. Big Smile
Northshore
Northshore's picture
Last seen: 3 years 1 month ago
D1S with shorty tube, I added a spacer, works fine.
-X3-
-X3-'s picture
Last seen: 2 days 3 hours ago
My D1 does not agree with you since I put an STT40 in it Party
Still much cooler than my 219C D4 but it gets hot fast now !
Next step is to put a dedomed XP-L in the D1S to get full throw !
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
DB Custom
DB Custom's picture
De-dome the SST-40 X3, or slice it (much better success rate slicing)
My D1 is bored for the 20700 cell and uses an XP-L2 at over 2000 lumens, my D1s is using a sliced and diced XM-L2 for better throw and it too is just over 2000 lumens. Betting I can make a 26650 tube for it though. Big Smile (26350?)
Omega_17
Last seen: 6 days 16 hours ago
The D1S is no longer available in blue or green? I didn’t bought a light since a long time but the video review by Advanced knife bro got me intrigued.
bigm
bigm's picture
Last seen: 8 months 3 hours ago
The D1S has only been offered in black or grey so far. Has anybody noticed voltage readout inaccuracy? Mine consistently reads .2v lower than actual voltage.
Nev
Last seen: 2 years 3 months ago
My D1s reads spot on, but my D1 & D4 both read .1 volt under.
Omega_17
On the picture the grey version is a little bluish (at-least on my monitor).
Will there be a green version in the future?
giorgoskok
giorgoskok's picture
DB Custom wrote:
…. my D1s is using a sliced and diced XM-L2 for better throw and it too is just over 2000 lumens. …
You mean sst-40 ?
Niko
Looking for user who can write Emisar D1 firmware, simple 3-4 modes, temperature controled
SKV89
I just got the green version of the D1. I can’t believe how beautiful it is. Makes me want to collect all the colors of the Emisars now.
beam0
beam0's picture
Last seen: 7 hours 56 min ago
Green is the color I had wanted for an Emisar but unfortunately I’ve been reading complaints the (new textured) green color coating is not durable and wears off easily. (is it even anodize?) So now I’m not sure I want it, that has delayed my decision to buy an Emisar altogether until I look into that first.
RT--
^ My green D1 is smooth. Ordered it mid-January.
I think the grainy finish is only on D4.
SKV89
My D1 is smooth green and finish looks perfect. I didnt know the D4 green had rough texture. I thought only D1s had rough textured surface
ToyKeeper
ToyKeeper's picture
That already exists. There are several different D1-compatible firmwares which could meet that criteria.
beam0
beam0's picture
So for the green color the D1 is smooth finish and the D1S and D4 both are texture finish?
Can someone please confirm if this it correct or not?
ToyKeeper
ToyKeeper's picture
You can get the latest status by going to Intl-Outdoor.com and checking whether it says “smooth finish” or “grainy finish” next to each color.
beam0
beam0's picture
D1 listing does not show that.
https://intl-outdoor.com/emisar-d1-mini-thrower-p-922.html
ToyKeeper
ToyKeeper's picture
D1 only comes in a smooth finish. If that changes, Intl-Outdoor’s page will change.
beam0
beam0's picture
beam0 wrote:
So for the green color the D1 is smooth finish and the D1S and D4 both are texture finish? Can someone please confirm if this it correct or not?-
OK thanks, got it now…
Green color (currently):
D1…..Smooth surface
D4…..Grainy surface
D1S…Not available in green
DB Custom
DB Custom's picture
Sorry Giorgo,
Typo, my D1s has an XP-L2 that has been freed of it’s silicone. Wink
giorgoskok
Beer
