Emisar D1 / D1S review
576 posts / 0 new
giorgoskok
giorgoskok's picture
Last seen: 1 month 5 days ago
Beer
Flying Luminosity
Flying Luminosity's picture
Last seen: 2 years 3 weeks ago
Just received my grey D1s today, and can’t wait for darkness so I can see the beautiful 5D tint in action!
There’s one issue I’ve got though – the switch is a lot stiffer than the ones on my D1 and D4, and requires far more pressure for it to click. Is there any way to (easily) change that?
ToyKeeper
ToyKeeper's picture
Last seen: 7 hours 22 min ago
Location: (469219) 2016 HO3 // I get way more privmsgs than I can respond to, so please ask in a public thread if possible, for a faster answer.
Weird, first I’ve heard of the switch being any different. Has anyone else noticed that?
Flying Luminosity
It takes about twice as much pressure to press than the switches of the other two Emisar lights. Not a huge problem, but if there’s an easy solution to make the switch more responsive I’d like to try it.
Agro
Agro's picture
Last seen: 35 sec ago
Maybe they changed the switches and we’ll see the stiffer one used across the line?
Maybe it’s meant as a workaround for the problems with accidental activation?
Just guessing…
Flying Luminosity
Just guessing…
It did actually occur to me that it makes it less likely for the light to turn on in my pocket (which has happened twice with the D1). Maybe I’ll leave it and see how I get on with with a harder press.
DB Custom
DB Custom's picture
Last seen: 3 weeks 2 days ago
I know some people have griped about how the Emisar lights feel in – hand, so I thought I’d show this…
I was using some blue Sugru for another project (un-cured silicone) and had quite a bit left over, so I rolled it into the handle (battery tube) of my D1s. Worked out pretty neat, especially seeing as how the nice blue color ano wasn’t offered in this light.
I rolled my ball of Sugru and wrapped it around the middle of the tube, then rolled it out on the counter like a pastry roller til it filled the major part of the tube, using a little water on the counter top to make it smooth. Wink So now my D1s has a silicone insulated grip panel. Big Smile
atbglenn
atbglenn's picture
Last seen: 2 years 6 months ago
My D1S switch feels about the same as my D1 and D4
Boycott Nike
ToyKeeper
ToyKeeper's picture
Sugru is not a thing I’d expect as a tube wrap. That must have required a lot more care than a common shrink wrap. It looks like it fills in the grooves nicely though, as if they weren’t even there.
beam0
beam0's picture
Last seen: 4 hours 27 sec ago
For quite a while I’ve been looking at different compact size thrower lights ($30-$60) to find the best combination of distance and pocket-ability.
The D1S is still the most compact sized production thrower currently available for under $60 in it’s range class (700-800 meters)
Here’s the ones I’m considering:
………………………………………………………………Length mm…..Head mm…….Distance (mfg. spec.)
  • Emisar D1S………..18650………..XPL-HI………….127……………50………………..720m
  • Maeerxu M8………..26650……….XPL-HI…………..142……………54………………..800m
  • Utorch UT02……….26650……….XHP-35 HI………148……………59………………..700m
  • Catapault V6……….26650……….XHP-35 HI………132……………58………………..750m
It has about the same range as the others but it’s the smallest size. And even more compact having the thinner 18650 tube.
So it comes out on top if compact size for pocket carry is your main concern. I’m leaning more and more towards this one.
I’ve started a discussion thread on the subject: http://budgetlightforum.com/node/59699
beam0
beam0's picture
Thanks for posting, interesting stuff, didn’t know about it.
Is this it? https://www.homedepot.com/p/Sugru-0-88-oz-Multicolored-Mouldable-Glue-5-...
Is it removable after it’s cured?
beam0
beam0's picture
Pity there’s no knurling on these, has anyone found any tube that lego’s with the D1S?
beam0
beam0's picture
If I get a D1S I’ll put some of these silicone “Vape Bands” on the tube.
They make a real nice grip for a smooth tube. They’re mostly perfect size for 18650 tubes.
Fasttech has hundreds of them. https://www.fasttech.com/category/0/-/-/p/1?sort=r&keywords=vape+band
DB Custom
DB Custom's picture
That’s the stuff, sure didn’t know Home Depot carried it! Nice find!
Flying Luminosity
I tried to remove the switch covers on both my D1 and D1s to see what’s going on underneath. The difference is definitely very noticeable, and you wouldn’t be able to miss it.
Unfortunately, I ripped the rubber switch cover of the D1, thinking it would be a good idea to try and pull it out with a pair of needle nose pliers. What do I need to look for when I order a new one? I assume they’re pretty standard – are there any UK suppliers?
DB Custom
DB Custom's picture
You may try writing directly to Hank at Intl-Outdoor, keep it OEM.
Flying Luminosity
Sounds like a plan – I’ve already had three lights from there, and I’m sure I’ll be coming back for more! Smile
ToyKeeper
ToyKeeper's picture
It’s necessary to remove the switch cover retaining ring first, by carefully prying it up with an X-Acto blade or similar, rotating it around the edge to gently pop it up.
Geuzzz
Geuzzz's picture
Last seen: 2 weeks 1 day ago
D1 and D1s are on sale on intl outdoor for $35, could not resist, ordered a grey D1s 5D.
beam0
beam0's picture
Thanks for posting, I wonder if you got the last remaining grey one, only Matte Black showing now.
I would have maybe jumped on a grey one, not sure I like the look of that Matte Black, kind of looks like a dirty chalkboard!
Geuzzz
Geuzzz's picture
I am curious how I will like the chalky ano. Maybe they are selling the stock and switching to the smooth ano, than the joke is on me.
deleted-200707
Last seen: 1 year 6 months ago
bring back the smooth green!
FlashIight
FlashIight's picture
I didn’t like it at first, but after a bit of use it becomes a lot smoother. It feels more like stone than metal, and it’s actually quite nice.
Geuzzz
Geuzzz's picture
+1 love the smooth green on my D4.
Geuzzz
Geuzzz's picture
Thanks. It will not be an edc light living in my pocket, so I think I will be ok with it also.
beam0
beam0's picture
Well at least you got a grey one.
beam0
beam0's picture
After months of deciding I finally wanted to get a D4, but I’m only interested in the green color, and just my luck now it looks like the green is no longer available, it’s not showing as a color option anymore for the D4 anywhere. Angry
Nev
Last seen: 2 years 5 months ago
I prefer the look of the smooth black , but I like the feel of the Matt black ,
I’m struggling to see why people call it chalky Question
DB Custom
DB Custom's picture
I’m with you Nev, even my 84 yr old Mom didn’t find it chalky at all, she liked the feel of it.
Bob_McBob
Last seen: 20 min 44 sec ago
It’s described as chalky because it objectively feels chalky. My D1S has the roughest finish by far of any light I own. Whether or not you like a chalky finish is a separate issue.
