Emisar D1 / D1S review
576 posts / 0 new
adnj
What is the lanyard ring that’s used on the D4 in this pic from the review?
DB Custom
DB Custom's picture
Last seen: 4 days 23 hours ago
That’s a Solarforce pocket clip, the clip is on the other side.
DB Custom
DB Custom's picture
Fine tuned the battery crusher, 1438.65 lumens on the XP-L W2 2B sliced.
ToyKeeper
ToyKeeper's picture
Last seen: 11 hours 25 min ago
The H2-C boost driver is probably way too thick. The driver cavity on a D4 is pretty shallow, with virtually no extra room beyond the clearance needed by the attiny85.
About the lanyard ring, it’s part of a SolarForce L2 clip. It’s the best clip solution I’ve found so far, but it doesn’t work without modifications. The inner diameter needs to be expanded, and the tailcap needs a washer to fill the gap created by the clip ring.
These technically can work on the D1 or D1S, but it’s awkward due to the head being wider. The D1S in particular has a pretty small gap for fabric to fit into. But it works reasonably well on a D4:
adnj
ToyKeeper wrote:
The H2-C boost driver is probably way too thick. The driver cavity on a D4 is pretty shallow, with virtually no extra room beyond the clearance needed by the attiny85. About the lanyard ring, it's part of a SolarForce L2 clip. It's the best clip solution I've found so far, but it doesn't work without modifications. The inner diameter needs to be expanded, and the tailcap needs a washer to fill the gap created by the clip ring. These technically can work on the D1 or D1S, but it's awkward due to the head being wider. The D1S in particular has a pretty small gap for fabric to fit into. But it works reasonably well on a D4:
Thanks for the reply. What I'll do is use a Solarforce L2 lanyard ring (no clip).
DB Custom
DB Custom's picture
Is it just me or is that grey D1S calling out “Daaaaaaaale! Daaaaaaaaaaaaale!”
Big Smile
ven
ven's picture
Last seen: 11 months 1 week ago
D1vn with sst40, really impressed with this light and dare i say, actually prefer it to the xpl HI 5000k. My preference will usually always be 5000k over say 6000-6500k. Certainly for flood bias lights. However in thrower bias, its not a must for me. The beam is pretty much white, have to really inpsect for any rings. In use, its a very nice beam, huge hot spot(at a guess its about 2/3rds larger over the xpl HI. Spill is brighter, in fact its that bright it makes it even more useful for me.
The sst40 is great in the D1, would also be nice for some additional 4000k and 5000k flavours Thumbs Up
ven
ven's picture
Big Smile
I can hear it from over this side of the pond!!!! quick quieten the voices(i have enough of those myself)
DB Custom
DB Custom's picture
Lol, I put Intl-Outdoor in my main header for bookmarks so I can check it regular. Addict, yes I am!
DB Custom
DB Custom's picture
My Solarforce Skyline I has a crazy deep reflector, I’m actually considering pulling the reflector and building a head for the D1 to hold it. I gotta have it really bad, need help. . . .
Seriously, it’s crazy! 38.3 opening at the top, 56.1mm deep!
ven
ven's picture
Your normal, you are always aspiring to improve and better……………….nothing wrong with that and having the skills to do it. Imagine a few years back, someone suggesting a bit of plastic, some type of screen and talking /sharing pics around the world with other people via something called the web!……………that is crazy! Crazy today, the norm tomorrow Smile
fischju
Last seen: 9 months 3 weeks ago
https://i.imgur.com/R8OnUPAl.jpg
https://i.imgur.com/Qz7f6nSl.jpg
https://i.imgur.com/4PvGnSjl.jpg
How does the heat compare to stock? Should be more efficient here.
AlexGT
AlexGT's picture
Last seen: 12 hours 36 min ago
When will the D1S be available to order? Any special discount code in the works? Interested!
ven
ven's picture
Will have to check fischju, I did not notice much different ,but I was not paying attention tbh. When I was using it last night, my uses were all pretty short and it never got hot, just warm. I would expect up to a couple of mins (depending on ambient temp) at max output. After a few uses at 100%, I dialed it down quite a bit and was more than sufficient with no heat issues. TK made a great point (might have been the D4 thread). Where as with the D4 or other floody lights, you don’t need to ramp these up anywhere near to see more due to the reflector over optics. So where other lights I need it ramped up(D4 or other optic types), this for most of my uses is set lower if makes sense. But damn that double click to 100%, that is very addictive! Smile
totobel
Last seen: 3 years 1 month ago
Thrunite has that for years, I wonder why all vendors don’t do it, it’s so logical.
ToyKeeper
ToyKeeper's picture
I don’t know when the D1S will be available or exactly what the price will be, but I’ve heard rumors that it could be this week (because Neal already has some, I think) and that the price may be either the same as the D1 or slightly higher. I haven’t heard anything official though. It’s just speculation, as far as I can tell.
ven
ven's picture
Yes, I am use to double click for turbo, many of my lights have it. However for me, the size and how the switch just sits at my thumb waiting to be pressed……makes it easier than normal for me! The UI is a master piece …………simple to operate yet rich in features…..genius Smile Guess I am trying to say, the D1 and D4 make it almost impossible to use without at least one double click Big Smile
contactcr
Last seen: 22 hours 8 min ago
I see there’s a 3rd emitter option for the D1 now for fans of the warmer tints: XP-L HI V2 5D, 4000K
freeme
freeme's picture
Last seen: 1 hour 56 min ago
D1s ordered!! cool
1thedeals.comyoutubeAstroluxNealsgadgetsolight
RollerBoySE
RollerBoySE's picture
Last seen: 2 weeks 8 hours ago
freeme wrote:
D1s ordered!! cool
Where?
freeme
freeme's picture
From their China site. I believe Hank will list them on their site by this week. Price is the same as D4 and D1!!! Available in grey and black colors, and 3 tint options like what other members have mentioned.
RollerBoySE wrote:
freeme wrote:
D1s ordered!! cool
Where?
Myers
RollerBoySE wrote:
freeme wrote:
D1s ordered!! cool
Where?
Crying Something else colors in the future? Cyan, green, sand, gold? Could you ask them? E.g. I’d pay for them + money for those.
Ragsy
Ragsy's picture
Last seen: 2 hours 52 min ago
Interesting to see whether or not the D1S out throws something like the UT02 or the NC P30?
We should get sushi Carol
G'day mate, ow ya garn?
Yeah, nah good mate
totobel
Indeed. That’s THE question
contactcr
Considering TK says her throw number could be low it’s a safe bet it beats the P30. Against the UT02 will probably want to compare beamshots and everything since it’s a different emitter and battery so not really a 1:1 comparison.
stephenk
stephenk's picture
Last seen: 3 hours 29 min ago
RollerBoySE wrote:
freeme wrote:
D1s ordered!! cool
Where?
From which retailers are these lights available from?
ToyKeeper
ToyKeeper's picture
contactcr wrote:
Considering TK says her throw number could be low …
My lux measurements always seem a bit low compared to everyone else’s. Also, my D1S has a slightly off-center emitter that I haven’t fixed yet, and it might cause a small drop in lux. I think the official spec is 130 kcd.
rubatone
rubatone's picture
Last seen: 2 years 2 months ago
stephenk wrote:
RollerBoySE wrote:
freeme wrote:
D1s ordered!! cool
Where?
Link?
ToyKeeper
ToyKeeper's picture
rubatone wrote:
Link?
Yes, Zelda?
hIKARInoob
hIKARInoob's picture
Last seen: 22 hours 59 min ago
ToyKeeper wrote:
rubatone wrote:
Link?
Yes, Zelda?
I thought you were Zelda, hehe. Silly
