** BLF LT1M-Mini Project - The little Lantern! **
1260 posts / 0 new
agent80
Last seen: 16 hours 1 min ago
This is excellent news!!! Slim is good guys!! Thumbs Up Thumbs Up
raccoon city
raccoon city's picture
Last seen: 19 min 58 sec ago
Please sign me up for one additional BLF LT1M-Mini (for a total of three.)  :BEER:
Forever
Forever's picture
Last seen: 13 hours 29 min ago
I like the look of the 21700 tube version better. Looks a little lighter.
xevious
xevious's picture
Last seen: 5 min 34 sec ago
I had thought that 26650 cells on average had notably higher mAh than 21700 cells. But a recent sweep of batteries in the marketplace turns up something interesting — that while the highest 26650 cells are pushing 5300mAh, the highest 21700 cells have reached 5000mAh. That’s not a huge difference. Frankly, it doesn’t look to me like the 26650 has much of an advantage over the 21700.
Given this, I’d be more inclined to say that a 21700/18650 compatible tube would be preferable. Yeah, this means losing the 3xAAA battery carrier option (in a pinch), but frankly good planning on batteries would obviate the need.
d_t_a
Last seen: 1 hour 3 min ago
Based on my (not that professional) capacity test, charge battery to 4.20v, then discharge battery at 1Amp until 2.50v (I’m using SkyRC MC3000 analyzing charger), the highest capacity 5000mAh 21700 batteries (eg. Vapcell T50 or Vapcell G50), can barely get 5000mAh capacity (from 4.20v down to 2.50v at 1A discharge current).
Whereas something like the Vapcell/Shockli 5500mAh 26650 (and also the Keeppower 6000mAh 26650, which appear to be using the same internal battery) batteries, using the same discharge test (4.20v down to 2.50v at 1Amp discharge current, yields around 5800-5900mAh capacity on the SkyRC MC3000). So the highest capacity 26650s are still nearly 1000mAh (around 18% more capacity, assuming discharge down to 2.50v). Although it’s difficult to get these “5500mAh” 26650 batteries. Although based on energy density, I recall reading that 26650 is still not as energy dense as high-capacity 18650 or 21700 batteries…)
xevious
xevious's picture
Thank you, dta. This is enlightening. 18% is nothing to sneer at. And frankly, looking at the form factor differences on diameter, maybe it’s worth a slightly wider girth to have that extended 26650 cell capacity. I wonder if it would make sense to provide two different tube sizes as an option. Certainly it’s done commonly with 18650 & 18350.
lionheart_2281
lionheart_2281's picture
Last seen: 17 hours 23 min ago
I thought 26650 form factor was a great idea for both lantern stability as well as extra capacity
raccoon city
lionheart_2281 wrote:
I thought 26650 form factor was a great idea for ... extra capacity
Yeah, a 26650 is about 42% bigger than a 21700, and at most has 15% more capacity (in 2021.)
Not a good trade-off, in my opinion.
And the ability to use 3 AAA batteries?
You're not going to get much runtime compared to a nice 21700 cell.
I do admit that a fatter lantern is more stable, but the 21700 lantern could come with a plastic anti-tipover disc that fits on the bottom of the lantern.
agent80
I am excited to see the new build. Its going to be perfect. Big Smile
lionheart_2281
I thought 26650 form factor was a great idea for … extra capacity
You’re not going to get much runtime compared to a nice 21700 cell.
For me personally, it’s more about who wants a skinnier lantern that will tip over easier with less battery capacity?
Does it need to fit into a pocket? No.
Does it need high discharge that 21700 can deliver? No
It’s a lantern, runtime and stability is paramount (for me anyway)
It’s not important that it runs off 3 AAA’s but it’s a nice little bonus that you probably won’t need until you do.
Coscar
Coscar's picture
Last seen: 6 hours 22 min ago
It’s a lantern, runtime and stability is paramount (for me anyway) It’s not important that it runs off 3 AAA’s but it’s a nice little bonus that you probably won’t need until you do.
Using 3 AAA’s just doesnt make sense to me. If you are going to go to the trouble of taking 3 AAA’s ‘in case of emergency’ why not just go ahead and take spare 18650/21700s Question
Im not a Pessimist …. just an Optimist with a lot of experience
A little John Prine
SIGShooter
SIGShooter's picture
Last seen: 1 hour 1 min ago
I think it makes sense from the standpoint of buyers other than those knowledgeable about flashlights. Don’t forget that Sofin wants to sell the mini to the mass market, many whom may think it’s a great feature to have or are afraid of li-ion batteries (I’m just speculating here and could be totally off base Silly ). Also in case of a true emergency (earthquake, floods, etc) the more option one has the better off one is. AAA’s are going to be much easier to scrounge than 18650/21700 batteries.
Naturally those using it for camping, etc will just bring extra batteries.
xevious
xevious's picture
3xAAA flashlights are quite common. So lets say your Lithium Ion cell failed, you were unable to charge it for whatever reason, and you lost your spare. If someone in your group has a spare 3xAAA set, or you head into town and a cheap 3xAAA light is on the shelf — you’ve got a substitute.
Perception
Last seen: 2 days 15 hours ago
The entire concept for this light originally was a small, backpacking oriented version of the LT1. If size isn’t a concern, use the LT1. The LT1 already has all the things you are looking for when size isn’t a factor. Heck, with a little ingenuity you could probably shoehorn a 3 AAA carrier into a LT1 if you wanted to. Where size is a factor though (the whole purpose of a mini version!?) the 26650 is unwelcome.
roostre
Last seen: 24 min 20 sec ago
A "half a millimeter" (about 20 thousandths of an inch) larger in diameter 21700 battery tube could accept AAA battery cages:
https://budgetlightforum.com/comment/1810292#comment-1810292
How many flashlights does a "real man" need?
None, real men are not afraid of the dark.
lionheart_2281
I wouldn’t take AAA’s as an emergency, I would buy them anywhere, unlike lithium ion cells (of course I’d have several other lights with me as a backup too Big Smile )
Coscar
Coscar's picture
Hmmmmm ………….. Dont forget the backups for the backups Beer Beer Beer
A little John Prine
thslw8jg
Last seen: 14 hours 21 min ago
Interested for 2
DBSAR
DBSAR's picture
Last seen: 1 day 8 hours ago
This LT1M was intended to be more compact, (thinner) to better fill the need for campers, backers, canoeists, Kayakers, etc. The 26650 is an older format, & loosing popularity in favor of the newer 21700 thinner format. A base cap will likely be available for better stability.
rost333
rost333's picture
Last seen: 1 day 5 hours ago
Barry0892 wrote:
21700/18650 seems better option
whitecitadel
Last seen: 2 days 16 hours ago
It would have been good to PM the waiting list about the poll?
Been waiting for LT1 mini for so long I don’t check the thread much and missed out on the poll, luckily for me the smaller option was selected because as dbsar says a few posts above I thought the intention was smaller and lighter for use where weight is a consideration.
As many have already said, if weight is not a consideration just take the LT1.
AA compatibility of no concern for me a in a light like this.
DBSAR
DBSAR's picture
exactly!
SIGShooter
Additions to the interest list since post number 1220
Post# / Added / User Name
1225 / 10/10/2021 / Lixivium
1226 / 10/10/2021 / leo l.
1228 / 10/10/2021 / tra192
1229 / 10/10/2021 / SebaZ74
1230 / 10/10/2021 / r3dfox
1232 / 10/11/2021 / raccoon city
1249 / 10/15/2021 / thslw8jg
DBSAR
DBSAR's picture
Not sure if i am on the list myself. Silly if not, add me for 5.
SIGShooter
You’re already down for 6, added back in Feb 5, 2020 Big Smile
DBSAR
DBSAR's picture
ok awesome. i must be loosing my memory & mind LOL Facepalm
sleasys14
Last seen: 7 hours 21 min ago
Please put me down for 2.
SIGShooter
Additions to the interest list since post number 1249
1258 / 10/17/2021 / sleasys14
echs
Last seen: 11 hours 12 min ago
Please add me to the list for 2
