SFN55.2, SFQ55, SFN60, SFQ60, SFS80 and LED info
48 posts / 0 new
Sirstinky
Last seen: 1 hour 36 min ago
Haukkeli wrote:
Kaidomains Custom P35 SFS80 4000K version can’t take the 8 amps that they tell it should. I fried one, reflowed the second one with more care and it also fried at 8A.
Bummer. Maybe you got a bad bin or something. Warm white emitters can’t take the same current as CW ones anyway.
dthrckt
dthrckt's picture
Last seen: 7 hours 44 min ago
Received my nightwatch valkyrie. Great flashlight. The sfn55.2 has a great beam shape in this (op reflector) light. I’m impressed. I would definitely prefer 5000k, but I’m impressed by the emitter. I might buy the same light with sbt90 just to compare, I do think I’d prefer the beam shape of the sfn55.2 based on beamshots from the web and using this light. The spill is very bright, sort of reminds me of a TIR.
dave1010
dave1010's picture
Last seen: 8 hours 36 min ago
Astrolux have just listed a light with the SFS80 LED:
Astrolux® A03 SFS80 LED 800LM Powerful 14500/AA
https://banggood.app.link/XhKLTbzjVjb
ArtieT59
ArtieT59's picture
Last seen: 3 hours 15 min ago
 I ordered a P35 3v 4000k emitter and a P70 6v 6500k emitter today from Kaidoman with my other leds. Looking forward to both! they both look domeless, hoping the P35 competes with the sft40 but in 4000k!
[FLF] Five Light Friday https://budgetlightforum.com/node/78749
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
My Sft40 beamshots / comparison thread: https://budgetlightforum.com/node/78100
Tom E
Tom E's picture
Last seen: 3 hours 33 min ago
dthrckt wrote:
Received my nightwatch valkyrie. Great flashlight. The sfn55.2 has a great beam shape in this (op reflector) light. I'm impressed. I would definitely prefer 5000k, but I'm impressed by the emitter. I might buy the same light with sbt90 just to compare, I do think I'd prefer the beam shape of the sfn55.2 based on beamshots from the web and using this light. The spill is very bright, sort of reminds me of a TIR.
Thinking of ordering one w/SFN55.2. I'll ask Neal for his best deal, and if it's in stock.
Do you still like/recommend it?
Sirstinky
Definitely. It’s one of the more well-rounded lights in my collection. It’s only missing a buck+FET to make it spectacular. I mean a sub 60 mm reflector that throws over 700 m with a huge 7070 LED and 7000 lumens? Oh yah. Nothing else with a single LED and battery comes close. Plus PD charging and power bank sweetens the deal.
ArtieT59
ArtieT59's picture
Just ordered the Astrolux ft03 mini with sfs80 claimed 1650lm & 720m throw! Sounds like a brighter CULPM1 to me!
Tom E
Tom E's picture
My green OSRAM version of the FT03 mini does 910 meters, though at 900 lumens. Does the 720m compare well with a Boost HX? The Boost HX is still expensive as well.
Haukkeli
Last seen: 9 hours 33 min ago
My 4000K versions of SFS80 couldn’t sustain 8A. Two burned immediately and on a third one phosphor first bubbled and then fall off during routine reflow.
ArtieT59
ArtieT59's picture
unfortunately I never put the HX in the FTO three mini, but you're right I think it would be more like 900 m going off of what the numbers are for a c8. I also have a p35 coming from kaidomam.com, Going to see how that does this too but I think that might be the same or better better
ArtieT59
ArtieT59's picture
Not entirely sure these belong in this thread - But i just received the "P70" 6500k (6volt i believe), and the "P35" 4000k 80CRI (3volt !) from kaidoman.com LOL here are a couple quick pics, still figuring out which lights i want to throw these in. Bth of them are domeless HI versions.
Thinking a Emisar D1 for the p35 4000k (i have a couple D1 now and have been looking for a led to put in one). and thinking the Convoy M21e for the P70. Any thoughts?
*EDIT: its "too bad" (my own fault) I just sold my acebeam e70 xhp70 version, would've liked to seen this P70 in that little guy!
dave1010
dave1010's picture
ArtieT59 wrote:
Not entirely sure these belong in this thread – But i just received the “P70” 6500k (6volt i believe), and the “P35” 4000k 80CRI (3volt !) from kaidoman.com LOL
The listing for the P35 says
Quote:
Custom P35 HI White 6500K LED (SFS80) /
Custom P35 HI Neutral White 4000K CIRI80 LED (SFS80)
So they appear to be from the same manufacturer.
http://kaidomain.com/Custom-P35-HI-3V-8000mA-1800-Lumens-LED
The P70 doesn’t give much information but I assume it’s one of the others.
Interested to see how they perform.
Haukkeli
P35 4000K’s seem to be quite fragile. I have one in Convoy S2+ with 5A driver and it works fine. I tried to build Convoy thrower with 8A driver and I burned two of them. During reflow the phosphor has started to bubble few times and then it peels off. Now I know that you have to be extra careful with them.
Sidney Stratton
Sidney Stratton's picture
Last seen: 7 hours 56 min ago
It’s best to test with a power supply the threshold of any LED. Had a surprise with CULPM1.TG from Yinding. Angry blue at 8 Amps, toned it down to about 6 ½ A.
Haukkeli
Yeah, I thought I didn’t even push it hard with 8A. That is what Kaidomain’s specs said it should withstand. Seems like at least the 4000K version doesn’t.
Sidney Stratton
Bummer to burn out a led. But this adds to the mystery of why some of my Yindings work at 8 A while others are screaming in pain. Poor QC?
ArtieT59
ArtieT59's picture
thanks for info guys. i will be careful reflowing. i had major issues with (2) xpl-hi 2850k while reflowing recently, that one seems fragile, more so than any other xpl-hi I've reflowed, unless it was a bad batch (bought a couple months ago from Hank).
-> major issues where the top layer delaminating from the base. never saw that before, i didn't heat up hotplate anymore than normal. It sucked. The white base seemed weak and chipped too.
I wouldnt try putting 8amps through a 3535 led anyway, unless i knew it was capable, but since i know nothing about the P35 i will keep it around 6a, thanks for that info!
Think im gong to try it in a m21c, 6amp driver
Apologies Dave1010, didn't even notice it said (sfs80) in the P35 description...
