Curious what emitter currents you kill various LEDs at when using them in flashlights.. Wondering if some consistenly are able to push LEDs higher than others (assuming their reading is fairly correct.) And if there is a pattern between the driver that was used (current spikes) and if the LED was domed or dedomed.
For people who share their setup, im only interested in emitter amps. No guesswork based on tail cap readings and such.. And please, do not let these deaths put you off from killing your beloved LEDs pushing the limits...
XP-G2- RIP list
RaceR86, 5,2-5,3A. Dedomed. Driver: STL-V6/TR 3T6 driver with resistor mod. The one where you can change between two groups (3/5 modes). Copper mounted LED, secured with screws to copper "pill". Less than 1 hour of total use.
Gtaamazing, 5,2A. Used an SST90 driver. Reference
XM-L2 - RIP list
ImA4wheelr, 7A. dedomed. MF TR3T6.
RaceR86, 6,3-6,4. Dome. MF TR3T6 (artic silver 5, screwed down to ZY-T08 pill. Less than 15 minutes of total use. )
Other info:
I can mention I have never had issues with XP-E2 up towards 3A. MT-G2 at 10A, and Nichia at 2A. There is really no point in pushing those emitters further (or in some cases even that far). I dont see the point in pushing an XP-G2 above 5A either (based on graphs). But the XM-L2... It just keeps getting brighter until it dies. We need more info about that sweetspot, and if some drivers are better suited than others..
For the record, I have never fried an XP-G2 or XM-L2 with the FL-2 or similar driver at 5A.
Here are some of the crash testing by djozz. XM-L2 and XP-G2
Some pictures of my latest LED killer..
LED 1. I assumed it fried due to lack of pressure towards pill. So I put in another one..
Nicely secured...
Stopped working properly after some use.. When used on high it shuts off after 1-3 seconds (its the LEDs fault)
Slight sign of burnt wire?? Either way its damaged and only working at "low currents". I consider the LED broken/junk..
I suppose the best way to get to high amps with an XM-L2 is buck driver with cells in series.
