Noob here. I am planning to buy this courui d01 light for modding. Would it be possible to use blf fet driver with this light because it uses electronic switch? Or would it be smarter just to add r100 resistor on original board. With spring bypasses ofc. And if its possible to use blf fet driver, how to connect it with the switch? How much amps would the original led survive? Sorry for the question flood…
If you scroll down to the bottom of the first post of this thread, there's a ton of links to people's build threads.
Regardless if you mod the stock driver, or put in a Fet driver, you'll need to put in a Direct Thermal Path board for the LED.
If you go the Fet driver, the switch is wired to GND & pin4/OTC pad, depending on the revision of the driver board & firmware used.
Thanks for the reply. I have been reading all of the courui threads for few evenings… but some things were not clear to me.
Hi everyone
Do you know where to buy (and what is the correct size) o-ring to replace the one under the glass.
I’d like to have glow in the dark model.
If I’m not mistaken its diameter is around 72mm
TIA
strango hard to find that size in gitd BUT : FS: Custom GITD O-rings & Kryton Groove Strips! | Laser Pointer Forums - Discuss Laser Pointers | High Power Lasers
This new Courui mod thread added to the OP’s consolidated mod threads:
So I got an LX1330B luxmeter, but haven’t checked my Courui or any other lights yet (been working on my I.S.). Did get this check out in the sun though (both meters on x100 setting):
Seems to explain my low readings.
-Garry
I know my LS1330B meter has been working very reliably. Seems like every time I suspect something is wrong, it’s something else, or my own dang fault. Watch out for readings goin up when the battery starts dying. Other PIA is leaving it on and draining the battery - do this wayyy too often. I recall manxbuggy1 had this meter and a higher end one he spent like $150 for, and said the readings were the same, but the pricier unit of course had a bunch more features he wanted.
Thanks for the feedback Tom. Continuing off-topic duscussion, would you think the HS1010 & HS1010A perform ok for sphere use where even though it’s readings may be wrong, the calculations are based on calibrating to a known light (or a few known lights)?
-Garry
Well, all depends how it’s off: offset or scaling. If it’s an offset problem, then yes, good for a sphere. If it’s a scaling problem, that gets tricky, because the higher the source, the more it’s off. It could be a combo of both calibrations, or could be an inconsistency issue, varying excessively by temperature or battery level for example.
I wouldn’t risk it, but of course money is money…
For my LX1330B, I don’t apply any cal factor - for throw, I use the reading directly. I’m making a big assumption it’s calibrated close enough.
I’m also interested in this OT discussion RE: whether the HS1010 has an offset or poor scaling. I picked up an HS1010A a while ago and never played with it much.
GearBest has a flash sale on the grey Courui D01. The discount is exaggerated but I couldn’t pass it by for $24.99. Would have purchased two if I had the excess funds available. The listing is here
Great price - I scooped a couple more myself.
The last grey one I received had an almost purple tint to the finish - much lighter than previous grey one’s. Looks pretty cool.
Battery tube threads actually felt nice. Reflector seems slightly different, & coating is not as smooth as the earlier one’s.
The tail PCB is also different, so not quite as easy to hook up a switch like the previous layout.
i’m glad i bought another one ,now out off stock both versions
btw anyone planning to mod this with XHP35 HI ?
Wish I had funds for another gray before they all sold. Oh well, more funds for my contest entry.
from gearbest:
This item is out of stock,
we are very sorry to inform you that this item cannot be sold anymore on our website due to supplier’s issues.
Too much works required to convert it into 3 cells in series. :person_facepalming:
