I can't remember how long this light has taken to build but it has been an on again, off again ordeal for some time for one reason or another. I'm a little disappointed with the output off the light with the effort that went into building it. Its running a 5 amp IOS 3 mode driver which works fine, just the led I feel could be driven a lot harder with the setup in this light. The light itself was sent to me by a member on this forum.
As usual I'll let the pictures do the talking so you don't have to listen to my waffle.
Firstly the copper pill where the led is soldered directly to the pill with the star sandwiched under it. The thread diameter is 30mm to give you an idea how big it is. This is the first time I have made a pill like this. The pedestal for the led was machined on my lathe. I drilled a hole in the star and carefully filed out where the led normally sits.
The 5 amp driver 3 mode from IOS has as someone has described it elsewhere been iced. The wires to the led are considerably larger than the standard wires.
The heat sink on the largest fin is 60mm in diameter. It has a forward switch which works very well.
The plastic switch holder is the reject one from the OL comp build light. The ends are recessed for the round contacts to sit into and not move around. They came from IOS. The spring is the heavy one also sold by IOS. I have used a few of these lately and feel so far that there is no need to add braid to them. With a spring either end of four 26650 batteries, they are held very firmly. The switch came from, Also from memory FF with the contact plate removed. These have a very firm spring in them and also used in the C3 XM-L2 build.
The tailcap was made from copper mainly for a good contact for the earth.
The battery tube is one piece this time. It took awhile to machine out as I only have a small boring bar which was right on its limits machining in from both ends. If the tube was five mm longer I would not of been able to machine it. Its standing next to a TR3T6 for a comparison size wise.
This is the heatsink with the pill and switch assembled into it. The screw at the back holds the switch assembly into place to stop it moving around. The rubber switch boot came from FT.
This was meant to be all the components in the build but due to some prescription medicines doing their thing some items were accidently left out.
The finished light. About time one sez. The second picture is the TR-3T6 with a C8 sitting on top of it.
And finally a group hug shot. Left to right. Back to front. 3C XM-L2, 3C MT-G2, Rebuilt HD2010 2 x 26650 (I cant believe the light output after rebuilding), standard HD2010, and last but not least a C8.
The night shots will follow when I'm able to do them. Thanks for looking and reading.
