Quad Nichia 219C 5000K emitters
Copper DTP MCPCB
Carclo 10622 TIR optic
Green GITD glow disc
Stock driver, D4v2 Firmware
Lighted carbon fibre electronic side switch
Built in micro USB charging circuit
Red/ Green charging indicators
6mm x 1.5mm tritium vial
Magnetic Tail
Length - 65mm
Width - 28mm/ 26mm
Weight - 80g (With 18350 cell)
Max - 3300lm
I used a piece of 14mm x 12mm carbon fibre tube, 12mm x 10mm clear acrylic tube, 0.5mm clear silicone sheet and 0.5mm black kydex for a green lighted glow circle around the switch button and DIY glow disc under the optic.
Emisar D4 Runtime graph:
After some measurements I decided it was workable although I had to destroy the PCB in the process as it is glued in place but that doesn't matter now ;)
I did try heating the tail cap and pulling on the spring but that snapped off at the solder joint so I chose to drill some holes in it until it yielded. I could have applied more heat but didn't want to risk altering the colour.
One good thing about installing the copper plate is that I was able to adjust where the tail cap lettering aligns, if that sort of thing bothers you :D
This also allows me to know at a glance whether the light is locked out or not.
Some measurements:
Spring compressed & PCB combined - 2.2mm
PCB alone - 1.07mm
Internal tail diameter - 22.24mm
External tail threads - 23.2mm
End cap thickness - 2.54mm
I had originally hoped to just fit a 22mm magnet in there with a thin copper plate but a 22mm x 2mm magnet is too thick, all I had, so used instead an N52 18mm Neodymium magnet with a pressed copper disc and some 1mm copper wire as I did not want to shorten the tubes either.
A 22mm x 1mm N52 magnet might do but seem very hard to find.
Micro USB Rechargeable Version.
I made a charging module and changed the magnetic tail.
The charger is made from copper sheet, tiny ME4056 board and brass contacts. Space was lacking so I drilled holes for the new 6mm x 2mm neo magnets and made a new copper contact plate.
The internal top of the battery tube was stripped of anodising using drain cleaner for electrical contact with a slot cut in to just above the o-ring for the USB port.
Feel free to post your own D4 mods here too ![]()
