18350s provide lots more oomf than 16340s, so if anything, bore the tube for 18350s.
16340s/CR123s probably don’t even need a sleeve to keep them from rattling.
A long enough spring should also accommodate the 2mm difference in length.
In for 1pc Nichia. Only if you could ship to the UK though
Hi CookieDave,
We will offer XP-L and 219C for option.
This one is actually a 18350 flashlight, with TYPE C charging port battery included. Light is screw tight, so it is easy for you to open with proper tool.
It is 18350 battery with TYPE C charging port.
This one you can get from zero to the highest output.
Is there an 18650 extension tube?
That could be another option.
@Jetbeamlight how is this Groupbuy working?
I’m in for 2pcs Nichia 219C, with 18650 extension if possible
Exactly. Bore it for 18350 and allow an extension tube for 18650 and it will be the best of all worlds, and still be able to use it with 16430/RCR123/CR123 cells. You’re correct, I can use 16430 cells in my 18350 lights and they basically don’t need sleeves to prevent rattle.
That would probably need to be a must have option for a lot of people especially with the huge difference in runtime/battery capacity between a 18350 and 18650 cell. Almost double/triple/quadruple in mAh for certain brands
Not to mention higher sustained brightness and low temperature capabilities
In for 2 Nichia (519A would be preferable to 219C)
18650 extension tube would also be a must or I’d pass if it’s ONLY 18350.
Why do the specs list moonlight at 1 lumen then?
Please,which driver will be used?thanks a lot
JETBEAM® RRT01 RAPTOR Tactical Flashlight, LED Torch Flash Light, USB Groupbuy Code: BLF GROUPBUY
Asking this too ![]()
It is stepless, just rotate the ring in the neck to get the output in between 0 and 950
No need to bore it for 18350. The RRT01 is an 18350 light. The 2021 version sold with an 18350 with micro usb port.
Checking 1Lumen’s review it was sold with or without extension tube segments for 18500 and 18650.
Found this so far…
