Edit 28.2.2016: The head can be removed from the battery tube. I just forgot to remove that sentence out of the review. 18350 battery tube can be used as I state at the end of the test.
Disclaimer: Jaxman E2 was supplied for review by HKEquipment.net at half price.
93 CRI 18650 flashlight for 25 bucks? Yes, please. The Jaxman E2 is not a lumen monster, but it has the highest CRI I’ve measured from a flashlight to date. 5400 Kelvins of pure white gloriousness.
Manufacturer specifications
- Battery type: 18650
- LED: Nichia 219B, Neutral or Warm white
- Color temperature: 5700/4000 K
- Body material: Aluminum
- Reflector: Orange peel texture
- Lens: Glass
- Waterproof: Yes, IPX-6
- Impact resistance: 2 m
- Switch type: Tail reverse clicky
- Battery protection: Battery polarity, low voltage warning
- Temperature regulation: Yes
- Pocket clip: No
- Tail stand: Yes
- Tripod threads: No
- USB rechargeable: No
- Length: 118 mm
- Width: 24,3 mm
- Weight: 75 g
- Price: $24.95 (http://www.hkequipment.net/product-p/je2.htm)
- Output levels: 3
- Mode memory: No
- Button lock: Not necessary, mechanical switch
- Direct access from off: Always starts on Low
Special modes:
- Strobe (7,5 Hz)
- SOS
Included in the box
- Jaxman E2 flashlight
- Lanyard
- Chinese specs/instructions
The body is the usual Chinese 18650 affair familiar to most flashlight enthusiast. Similar construction can be found from the BLF A6/Astrolux S1 and Convoy S2. On the Jaxman the head is stuck to the battery cylinder and cannot be removed, at least without force. (edit: it was just really tight, no problems)
The anodized aluminum body has a bluish grey tone to it. The finish and machining is good, save for one dent on the tailcap on my sample. The head has some shallow grooves for better heat dissipation, at least in theory. I would have liked a pocket clip too, but a 3rd party one can be found easily for a dollar.
Since the Jaxman and Convoy S2+ have compatible threads in both the head and the tail, the Jaxman’s Nichia head is easy to fit to a Convoy shorty tube or just use the nice metallic tailcap switch of a colored S2+.
The UI is simple. Full press on the rubber tail clicky turns the light on and off, half press cycles through modes (Low, Medium, High, Strobe, SOS). There’s no mode memory, and the light always starts at low. Moonlight mode is missing, and the low mode is quite bright at 14 lumens. Medium and high spacing is good though.
The Nichia 219B emitter was perfectly centered on my sample.
Spring in the head and tail, so button and flat tops are compatible. There’s no low voltage cutoff, but the flashlight will blink when the battery voltage is low. Resting voltage after depleting the Eagtac 3500 mAh battery was 3,10 V.
Jaxman E2, Convoy S2+, Eagletac D25LC2, BLF X6, DQG Tiny 18650 4.
Measurements
Please note: lumen measurements are only rough estimates
My diy 30 cm integrating styrofoam sphere has been calibrated using a Fenix E05 on high with manufacturer’s claim of 85 lumens. Verified with an Olight S10 that has been measured with a Labsphere FS2 integrating sphere by valostore.fi. Results may be more inaccurate with especially throwy or floody lights.
For spectral information and CRI calculations I have an X-rite i1Pro spectrophotometer with HCFR for the plot and ArgyllCMS spotread.exe for the data. For runtime tests I use spotread.exe with a custom script and a i1Display Pro because it doesn’t require calibration every 30 minutes like the i1Pro.
Explanation of abbreviations
CCT = correlated color temperature, higher temperature means cooler (bluish)
CRI (Ra) = color rendering index consisting of 8 different colors (R1-R8), max value 100
CRI (R9) = color rendering index with deep red, usually difficult for led based light sources, max value 100
TLCI = television lighting consistency index, max value 100
CQS (Qa) = Proposed replacement for CRI, RMS average of 15 color samples
CRI2012 (Ra,2012) = Another proposed replacement for CRI, consists of 17 color samples
MCRI = Color rendering index based on the memory of colors or 9 familiar objects
x,y = coordinates on a CIE 1931 chart
Spectral distribution (High)
Color rendering (High)
Read more about color rendering indices here:
Jaxman E2 beats the second highest CRI light I have measured with a good margin. Especially the output on the 470 nm region is significantly flatter.
For comparison:
Beam and tint
Beam has a hotspot angle of 15° and spill of 67°.
Tint and color temperature shift is relatively small in different areas of the beam. Corona around the hotspot is a bit warmer and the outer spill is cooler.
Tint in different output modes is very small.
PWM
PWM/pulsing is used on low and medium. Even though the output never drops to zero and the cycling frequency is rather high at 3900 hertz, it is still possible to see when looking directly at the light and moving either eyes or the light very rapidly. In use, only the quiet whine might be noticeable in total silence when listened closely.
Low
Medium
High
Strobe (7,5 Hz)
Runtime and temperature (High)
The output is regulated and stays constant until the 1 hour 54 minute mark. After this there’s a steady decline to 55 % until the low voltage warning blink starts at 2 h 9 min. There’s no difference in output with different cells. So no use getting high current batteries for the E2.
Cooling affects the output, so there is some sort of regulation. The head gets to 65°C at 17 minutes and this is as hot as it gets. At this point the handle is at 59°C. Without cooling, the battery tube reaches 50°C at about 10 minutes. I consider this too hot to hold comfortably with bare hands. As the light cools, the output rises, but the difference is very small and not noticeable with the naked eye.
Temperature at 5 minutes. Heat transfer is good, with only a 7 degree difference between the head and the handle.
Temperature after the head has stabilized at 65°C at 17 minutes. Head/Handle DeltaT 7°C.
Good/Bad
+ Extremely high color fidelity
- Compatible threads with the popular Convoy S2+ (18350 possible)
- Cheap
- Nice pure white tint
- Does not overheat
- Good output regulation
─ No moonlight mode
─ Special modes not hidden, always cycled
─ No mode memory or direct access
─ PWM/Pulsing is used on low and medium
─ Slight whine on medium
─ No pocket clip included
