Hello BLFers.
I received my sample SN6X-2X from MaxToch yesterday, and was very eager to unwrap this puppy! It came sufficiently boxed, with a nice zippered carrying case, extra clicky-switch/negative spring board, 2 extra red O-rings and a nice lobster claw lanyard. Quick pic:
I took several other pics that highlight the differences as well as give y’all a good look at this very high quality thrower. I also thought it would be helpful to have a compare/contrast with my older version MaxToch Limited Edition SN6X-2X (from last years GB), and this newer/improved SN6X-2X available through the Group Buy. .
I won’t get too much into the technical aspects as far as lumens, mAh etc…BLF member mudgripz is way more qualified than I, and has done some great legwork in shedding a little light (heheh) on this torch, as well as its mod-ability.
I’m not a great photographer by any means. I just hope this gives you a good idea of how well built this torch is:
Older 2013 version SN6X-2X on the LEFT, newer Group Buy 2014 SN6X-2X version on RIGHT.
Close-up of graphics on both old and new lights. Note the “Strobe” graphic.
One side.
The other side.
Logo close-up.
New version tailstands!!!
Close-up of tailswitch of old and new versions. Notice the old version light is actually longer, newer version is shorter and button is flush (smaller button diameter as well), which now allows tailstanding.
Inside of old tailcap (left) and new tailcap (right). Note addition of brass retainer ring.
Tailcap threads on old (left) and new (right). Very similar but small spacing difference on O-rings. Panasonic 3400s peeking over the top.
Positive driver/spring side on new light…also held in with brass retainer ring.
Another view.
As above…with body tube.
Old head versus new. Another improvement.
Another old vs. new.
Pics of old lens (left) and new (right). I hope you can see it, but the emitter hole at the base of the reflector is much more snug around the emitter on the newer model…much improved tolerance. You can also see some of the color reflecting off the new AR lens.
More AR lens goodness!
Emitter, on copper base, screwed down to pill.
Emitter unscrewed and pulled away from pill. Note thermal paste across the entire width.
Driver after spinning it around for view. I didn’t want to de-solder this…so this is the best view I could get.
Another view. Note marking, “MAXTOCH ET02”, on board.
One more view.
Wall shot 1. Older model on left, newer on right. I had to rotate the photos upside down to match previous photos…lol.
Wall shot 2. Older model on left, newer on right. You might not be able to tell, but newer model is brighter, warmer and has fewer ‘artifacts’ in the beam.
I’ll come up with some other shots, wall shots, etc.
Let me know if you have any questions!
Cheers,
krono
