Buck drivers with adjustable input and output voltages and current up to 8A
selected parts for best efficiency
The base price for the driver is 16€
46/47.5mm cost 1€ more
20 and 22mm got pretty expensive Coilcraft XAL7070 inductor +3€
2€ shipping worldwide from Germany with priority air mail
optional tracking with 25€ insurance adds 4€
for very big orders I can add for 2€ per additional 100€ insurance
The drivers use Anduril or older NarsilM
Each driver gets calibrated for output current, LVP and temperature
XHP35 LED max. 2.5A same as the GT
XHP50/70 2S → 6 / 4S → 12V up to 8A
2S → 3V up to 7A white flat for example
4S -> 6V depends on size as the shottky diode produces a lot of heat
I also made 4S carrier boards for people who dont want to mod the OEM boards
2$ for a pair of boards one tray
3$ pair cut out and sanded to size
add 3$ to with Berylliumbronze springs and gold plated button soldered
XHP35, 50 and 70(.2) will work well
for XHP50 and 70 a MCPCB with the thermal pad not connecting the 2 LED pads over the thermal pad is mandatory if the body is electrically connected to the MCPCBs base
so for 12V reroute over a separate trace would be needed, usually a wire can do it on a modded 6V MCPCB
Wiring
G common Ground
L Switch LED MCU controlled
LS permanent LED connected to battery
S Switch for UI ramping settings
LED+ is marked with a + (close to inductor)
LED- with a - (usually next to the main input capacitors)
new 20, 21 and 22mm
23mm for Klarus XT11/12GT running 2 18350s for Oslon BF or other 3V LED
24mm
new 30mm for L6 or similar lights
42mm TN40S, TN42 XHP35 8A 12V
42mm Niwalker BK-FA30S
added 3 pads for the auxillary switches,
one providing 5V for the Turbo switch
one sets multiples the current by 10 or goes to Turbo
the other divides the current by 10
46mm HaikeLite MT07S MT09S
46mm BLF GT Oslon Black flat (needs 2S carrier mod or 2 cell dummies)
Acebeam K65 the latest gen with programming port
Acebeam X45 the latest gen with programming port
MF01 3S LED mod to 4S carrier
MF02S XHP70.2 12V added some more thermal conduction as well as programming port
The battery carrier needs to be modified to 4S its pretty easy
2 trace cut on both ends and add one bridge
MF01 v2 MCPCB-mod for Buck driver
Not really ever used
BLF Q8 XHP35
