Supfire M6 First Impressions Review
36 posts / 0 new
Just Jim
Just Jim's picture
Last seen: 3 years 3 months ago
I received the Supfire M6-T6X3 from the BLF Group Buy today, and thought I would post a first impression review for those who have not received their light yet.
The packaging was a simple box, with only a bubble wrap sleeve around the light and wrist lanyard. No other packing material or instructions were included.
On inspecting the light itself, finish is nice for this price range of light. The threads were pretty well done, with a small amount of lube. I believe they will be smoother feeling with a bit more lube, but I haven’t gotten to that yet.
The reflector configuration is very similar to the Sky Ray King, and the lens does not seem to be coated. The LEDs are pretty well centered, and the opening at the bottom of the reflectors is slightly smaller than in the King. Reflector depth looks slightly deeper than the SRK, but I have not actually taken the light apart to measure this.
Length is slightly greater than the SRY, and my sample measures 142mm. The Supfire has a mounting point on the side opposite the switch, and it will fit a standard tripod mount. I doubt that it was intended for a handle because of the placement.
The feel in the hand is surprisingly good, considering the weight with four batteries installed. Weight without batteries is 15.3 ounces, and with batteries is 22 ounces.
The user interface is relatively user friendly, with 5 modes (H, M, L, and two blinkies). There is no memory that I have found, and the light starts in high mode. When the light is on, presses on the button will cycle through all the modes, including blinky. After this full cycle the next press turns the light off. I was at first very unhappy to have to cycle all the modes to turn the light off, but I then discovered that the light can be turned off in any mode by simply pressing and holding the button for a couple of seconds. It still starts in high regardless of which mode it was previously in however.
I am including a beam shot comparing the Supfire with the Sky Ray King (at least my version of the SRK Wink ). The Supfire M6 seems a bit brighter than the SRK to me, with a more intense hotspot. The beam is also a bit whiter than the SRK, which I find more pleasing to my eye.
In this beam comparison photo the Sky Ray King is on the left, and the Supfire is on the right.
The Supfire M6 will take both short and long 18650 cells. I tried Panasonic 3100 non-protected, and Trustfire Flame protected, and both work fine. Here is a photo with two of each type of cells to give a better perspective of the length difference (disclaimer: don’t use different type batteries together in the same light).
Overall, I like this light so far. I will get into more depth as time allows, and maybe add a couple more photos.
Thanks,
Jim
Just Jim
Just Jim's picture
Here is a photo of the reflector of the Supfire M6 on the left, and the Sky Ray King on the right.
Here is a side by side comparison photo of the Supfire M6 on the left, and the Sky Ray King on the right.
jacktheclipper
jacktheclipper's picture
Last seen: 12 hours 57 min ago
Cool
ImA4Wheelr
Last seen: 2 days 9 hours ago
Nice job Just Jim. Thank you.
JonnyC
JonnyC's picture
Thanks Jim!
My Keeppower protected cells fit, but they are absolutely bottomed out on the springs where it starts to become tough to tighten the body all of the way.
I might actually use a lanyard for once, as I can easily see this thing slipping out of my hands as the anodizing is rather slippery.  Do you think it's HAII?  I haven't seen HAIII this shiny before.
I think the UI is horrible, but I'm hoping pyro's driver will install with ease Smile
Just Jim
Just Jim's picture
JonnyC wrote:
Thanks Jim!
I might actually use a lanyard for once, as I can easily see this thing slipping out of my hands as the anodizing is rather slippery.  Do you think it’s HAII?  I haven’t seen HAIII this shiny before.
I think the UI is horrible, but I’m hoping pyro’s driver will install with ease Smile
It will be interesting to find out how the recent group buy Panasonic 3400 protected cells will fit, but I didn’t have any of those on hand to try. I think they will work, as they can’t be too much longer than the Trustfires I hope :~ .
I am no expert on ano, but I would have guessed HAII as well. I already installed the lanyard :bigsmile: .
I didn’t hate UI, but it’s surely not great by any stretch. It is relatively simple, so easier to navigate for new users than multi-mode group, user programable lights that have all the bells and whistles. Flashaholics will find it less than satisfying.
Jim
fishmaniac
fishmaniac's picture
Last seen: 4 years 3 months ago
Good stuff!
I wanted to add that the included lanyard is weaksauce supreme. The part which attaches to the light is the same type found on $1.50 ebay specials. The hole for it is located on the tailcap. I am not about to use the 12lb test-type lanyards on my black beauty.
Also the bubble wrap didn’t have a SINGLE unpopped bubble left! Its basically a plastic bag now.
Pulsar
Pulsar's picture
Last seen: 7 months 3 days ago
is the batt+ contact on the driver raised? if so, how much?
Sirius9
Sirius9's picture
Last seen: 2 hours 52 min ago
Nice, nice indeed (except packaging) any plans in taking it apart further?
Just Jim
Just Jim's picture
Yes, it is raised. It is a bit hard to measure without my depth mic, which is in my shop, but with a caliper it is approximately .065”. I can get a precise measurement tomorrow if you would like.
Jim
Pulsar
Pulsar's picture
no, its alright. just wondering if the pics were playing tricks. they arent
Just Jim
Just Jim's picture
At present I don’t plan to. Physical mods I can handle, as I have the equipment in my shop for that (lathe and small milling machine), but I haven’t gotten into electrical mods and precision soldering Sad .
I would love to up the output slightly, since this seems to be a worthy platform. Maybe I can find someone with electrical skills who wants to play with an M6 :bigsmile: .
Jim
Sirius9
Sirius9's picture
that lathe looks like in brand new conditions, I would love to have something like that Smile
please, put some more pics of your work Wink
Pulsar
Pulsar's picture
im hoping that a simple resistor mod could be done on it. hoping even more that texaspyro gets his SRK driver out soon, and that will be going in mineSealed
Sirius9
Sirius9's picture
did anyone checked how much amps it pulls, I would be interested to see how much it pulls from only one battery!
TrakTuned
TrakTuned's picture
Last seen: 4 years 8 months ago
Mehhhhhh…. Full cycle to shut the light off is a MAJOR buzz kill for me.. I always always always hate it. Dont even touch the costco light because of it.
Why would anybody want to have to click the button 5 times to get to off….Stupid |(
BLF members are hilarious:
“That’s like saying “My car has top-speed of 200k millimiles per hour”. Why not to just say 10 Ah?”
Pulsar
Pulsar's picture
press and hold for 3 seconds i think will shut it off
Streamer
Streamer's picture
Last seen: 2 hours 32 min ago
+1 EZ as pie.
TrakTuned
TrakTuned's picture
I read that but still. Cant stand it.
I feel I am going to recieve this light not use it more than a handful of times. Or wait for Texaspyros driver.
Just Jim
Just Jim's picture
Sirius9 wrote:
that lathe looks like in brand new conditions, I would love to have something like that Smile please, put some more pics of your work Wink
I didn’t want to get too far off topic here, so I started a thread in the OFF Topic Chatter forum titled A Few Machining Projects Smile . http://budgetlightforum.com/node/23705
Jim
RedForest UK
RedForest UK's picture
Are these proper seconds or just counting ‘one, two, three’ in your head?
It seems like 3 full timed seconds would be a long time, but I often read descriptions that say ‘hold for 2 or 3 seconds to turn on/off’ or switch to strobe or something, and in reality it’s more like 800ms or 1 second.
Pulsar
Pulsar's picture
I don't know... Haven't got mine yet
RedForest UK
Ok, hopefully both of ours will turn up soon with no smashed lenses! Smile
ChibiM
ChibiM's picture
Last seen: 8 hours 50 min ago
I think 3 seconds is right on..(just measured it with a kitchen timer (no milliseconds)
Streamer
Streamer's picture
Yep, 3 seconds is right on..
texaspyro
Last seen: 1 year 3 months ago
I ordered two. They came in today, un-announced. USPS still says they are in some California sort facility. The box looks like it was sat upon by a herd of overweight elephants pregnant with quadruplets. Lights survived the elephant attack intact.
Tossed one into the Sphere ‘o Many Mysteries:
High: 1900 lumens, 7.4 amps @ 4.0V, 6475K
Med: 1064 lumens, 3.9 amps
Low: 257 lumens, 0.8 amps
Strobe: 10 Hz
ALL modes, including high, show 615 Hz PWM.
Parasitic drain is minimal (< 3 microamps).
Here is a plot of a run:
After around 9 minutes the light was at 1800 lumens. It then stairstepped down in intensity over a couple of minutes to around 1300 lumens. It was at 52 degrees C. I don’t know if the rampdown was due to temperature, time, or voltage (I suspect that it was time).
At around 90 minutes the intensity started dropping as the battery voltage started dropping below the regulation point. The light was at 70 degrees C (toasty!).
After 2 hours the light level started dropping off the cliff. It stopped dropping at around 24 lumens. There was apparently no low-voltage cutoff. The cells were at 2.7 volts and only one LED was lit and it was flickering. The light stopped responding to button presses and would not shut off.
Pok
Pok's picture
Last seen: 13 hours 53 min ago
Thanks texaspyro!!!
What batteries did you tested ?
MRsDNF
MRsDNF's picture
Last seen: 21 min 19 sec ago
That is amazing testing texaspyro, again. Thanks.
texaspyro
Panasonic 2900 mAh cells…
texaspyro
I put one of my custom SRK drivers configured for 9 amps into it. Output went to 2200 lumens (from 1900 lumens). I put the M6 driver retaining ring into the light and mounted the driver onto the top of the ring (actually it is just sitting loose on it now). It needs to be tacked down with a small spot of weak adhesive.
The stock M6 is driving the LEDs at around 2.5A each, which isn’t too bad. Some U3 LEDs or high bin XML2’s might it get up to 2800 lumens or so.
On my SRK with XML2/T6/3C LEDs my low mode is around 50 lumens. The M6 with the same driver is around 10 lumens.
Boro
Last seen: 1 hour 53 min ago
Another BLF great contributer!
