sk68 clone: longitudinal section
80 posts / 0 new
lionheart_2281
lionheart_2281's picture
Last seen: 14 hours 40 min ago
Explicit wrote:
This is the most informative review I’ve read on flashlights. Congrats and thanks. Now, I’d love to see a more high end flashlight reviewed in the same way, but that would be too much to ask. Smile
I’ve got a Deft X (not really), gee cutting it in half sounds like a great idea!
CRX
CRX's picture
Last seen: 2 hours 35 min ago
Big Smile
ToyKeeper
ToyKeeper's picture
Last seen: 4 min 27 sec ago
I think they got more than their money’s worth for this review! Smile
djozz
djozz's picture
Last seen: 20 min 11 sec ago
CRX wrote:
!{width:99%}[IMG]http://i.imgur.com/Mot3zuG.png[/IMG]! :D
Thanks CRX, these specs suit the picture very well Smile
Fritz t. Cat
Fritz t. Cat's picture
Last seen: 1 year 8 months ago
djozz wrote:
Thanks Explicit, I may split a high end light some day but perhaps cheapy’s are the more fun because the design flaws are obvious.
Welcome to BLF! Smile
Perhaps the design flaws of the more expensive lights run more to unnecessary difficulty of production, but I still argue that if you are going to sell a few hundred thousand lights, or even ten thousand at $10 each, it is worth putting a lot of effort into the design. A simple example is the shape of the fins. Tapered fins are more common in cheaper lights and obviously cool better, as well as being easier to make, at least in large numbers. One of the things that makes flashlights interesting to me is that even complicated shapes are cheap to make with numerical control tools, at least as long as they are axially symmetrical. I expect it will be just as easy to spot flaws in expensive lights if we get one cut in half. The lack of an effective patent system must work both ways. One makes less money from a good design, but on the other hand to get a good design a Chinese designer apparently has only to correct the flaws in an existing design and adapt it to his needs, like free software. I wonder if the designers would sell their cut in half flashlights after they are done with them.
Flashlight designers should look at lighthouses and pottery.
这些谁设计的手电筒应该看灯塔,以及在陶器。
texaspyro
Last seen: 1 year 1 month ago
Djozz’s reviews are a cut above your typical review…
Explicit
Last seen: 7 months 6 days ago
This is precisely why I’d love to see a “naked in-depth review” Smile
If there is enough interest I will open another thread, or someone else can, I don’t mind.
I am pretty sure that we can raise funds to motivate a reputable reviewer to “see into it”.
I’ll stick to my promise and contribute 0.05 BTC (Bitcoin), or 5 LTC (Litecoin), if this is acceptable for the reviewer.
Fritz t. Cat
On this thread: http://budgetlightforum.com/node/31315#comment-652700 I describe filling the gap between the pill and the thick battery tube with metal, with minimal tooling and material. It would be nice if someone with more stuff would make some rings of copper or soft aluminum and sell them.
The discussion ended up on that thread, because the ring is incompatible with using a 17 mm. driver, so building a good 15 mm. driver was by far the hardest part of the mod. There seems to be little difference between an SK-58 and an SK-68 around the bottom of the pill. I consider 1.8 A too low current to require cooling fins.
NightSpy
NightSpy's picture
Last seen: 3 years 4 months ago
From 8-24 to 9/29 – that is how long my DX delivery of my gray Sipik Sk68 took!
But is arrived safely and works great.
Looks like things to the US are routed through Zurich, Switzerland now.
WarHawk-AVG
WarHawk-AVG's picture
naked in depth is only on skinemax or pay-per-view or you get blurr lines Big Smile
Fritz t. Cat
I am working on an XM-L2 Noctigon UltraOK SK-68. It is working but not finished. I have a rough heat transfer ring in place and am working on a better one. The Qlite/BLF SK-68 driver is also in preliminary form. The clone I had the XM-L2 in before, with a 17 mm. driver has a hollow pill, so I took an UltraOK for the XM-L2 and put the works from it into the other clone.
The new ring is 18 mm. diameter, 2.5 mm. wide and 15 mm. ID to fit over the driver and stacked 7135s. The driver board sticks out of its groove slightly below the pill. There is plenty of spare clearance between the ring and the IMR cell. Its 1.5 mm. thickness is more than that of the flashlight body at this point.
sb56637
sb56637's picture
Last seen: 1 day 4 hours ago
WarHawk-AVG wrote:
Wicked cool!
and of course MORE lights need to be sectionalized Smile
One sec, let me go pull out my Sunwayman D40M and prep the saw. Silly :bigsmile:
In all seriousness, thanks very much djozz! Fascinating.
Fritz t. Cat
I used some solid core 60/40 solder that I don’t use much. If cost were no object, I would have used 99% tin solder, but that is over priced.
The light now has 8 7135s and draws about 2.5 A. Perhaps contact between the 7135s and the ring would increase the current.
The body does now feel slightly hotter than the head, which seems to be a change, as they were about equal when I tested earlier.
hank
hank's picture
Last seen: 14 min 40 sec ago
It’s time to bump this one up as a reminder of how to cut through all the verbiage and give us a completely revealing review of a modern flashlight.
Why don’t we see this done more often?
djozz
djozz's picture
because I ruined a good sawing band on it?
Firelight2
Firelight2's picture
Last seen: 15 min 29 sec ago
Come on Djozz! Now that you have experience I’m sure you won’t ruin a sawing band on your next try. Silly
For your next cross-section, how about sawing in half a Fenix TK75?
MRsDNF
MRsDNF's picture
Last seen: 23 hours 21 min ago
djozz was banned by his better half doing this ever again because of the metal filings she had to clean up when he was finished. Silly
Fritz t. Cat
It should be made a sticky, as an example and for its own sake.
ToyKeeper
ToyKeeper's picture
Careful, djozz might take that literally and cover the half-light in syrup. Or maybe even tar and feather it. ;P
