Springs!!
113 posts / 0 new
Halo...
Halo...'s picture
Last seen: 3 years 6 months ago
Thanks for the great testing. Beer
Did you see Simon / Shenzhen Convoy Electronics carries Phosphor Bronze springs? $2.75 for 10. High 10mm, bottom diameter 7mm, diameter 0.8mm.
Orange coppery color from the picture, for whatever that is worth.
Tom E
Tom E's picture
Last seen: 5 min 37 sec ago
They sure seem identical (size and color) to the FT ones: fasttech.com - springs djozz listed in the OP and tested, just over twice the price.
gamezawy
gamezawy's picture
Last seen: 1 month 15 hours ago
Thanks djozz for your effort writing, thinking, testing, photographing, editing, uploading, copy, paste Silly Thank you any way
hank
hank's picture
Last seen: 13 hours 35 min ago
So what’s currently the best recommendation for springs, and for bypass wire — for ordinary lights, and for hotrods?
And does anyone make springs with bypass wire already connected (say with a spot-welder)? Because I find it hard to get bypass wire soldered to each end of a spring without overheating the whole spring.
cajampa
Last seen: 3 years 7 months ago
Try to put a little dab of flux on the surfaces (the wire end & spring) you want to mate with solder, and you will find that you don’t have to heat them so much to get them nicely joined Wink
djozz
djozz's picture
Last seen: 2 hours 52 min ago
For all lights that have to perform a little bit I would do a spring bypass, except if the light has to be particularly good-looking, i.e. if they are meant as a present, then I'd go for a copper-alloy spring without bypass, looks way better! (I have a djozz-spring without bypass in the tail of my BLF-X6, with a LD1 driver and a 80CRI 3500K XM-L2, now that is a chique light! Smile) But a serious single-li-ion hotrod needs a complete spring bypass, a copper spring is not good enough.
BTW, I could ask the manufacturer of the 'djozz-spring' to make another batch if there's interest enough, I still have some and really like them for the bigger lights. In case of another batch of 200 pieces they would be a dollar/spring again (plus some shipping, see my old spring-sales-thread). what I would do different is that I would have them made with 9mm base instead of 10. Probably the height would then be a mm less too.
Henk4U2
Henk4U2's picture
Last seen: 1 min 29 sec ago
It looks indeed to be the best of both worlds. (almost) the strenght of steel, combined with (almost) the conductivity of copper.
Having said this, I’ll hop over to your spring sales thread to order some.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
DB Custom
DB Custom's picture
Last seen: 4 hours 37 min ago
If you had another run done, I’d definitely be in for some. Maybe 25-50? Timing dependent, 100?
(it was a real bummer when I used the last of my djozz springs)
Edit: And for what it’s worth, I like to clamp my curved jaw hemostats on the coil of the spring just below the end I’m soldering the wire to, then do the soldering with the solder wire directly applied to the spring/22Ga wire to get the most of the resin core inside. The stats absorb heat to keep the entire spring from overheating.
Flip it and do the other end, then you already have solder on the spring when you solder it to the switch/driver pad, which makes that go much easier as well. Wink
The exception is when bypassing the pcb the switch is on, in which case I like to remove the switch, mount the spring, solder the wire to the top of the spring once passed through the board, then replace the switch and make the wire to switch connection simultaneously while attaching that side of the switch to the board. Again, clamping the stats to the part of the switch lead that comes out of the plastic housing keeps that connection from melting the plastic. This process keeps the switch pristine, so it’s not overheated internally and works smoothly.
Gosh, takes much more to say it than it does to simply do it.
USSR
Last seen: 3 years 10 months ago
good thread.. came accross this post from below thread
http://budgetlightforum.com/node/40895?page=3#new
in a similar power bank the voltage drop at .5A was 110mV from one end of the sprint to the other end on the pcb.
thijsco19
Last seen: 5 min 56 sec ago
Sorry for bringing a shovel to a flashlight forum, but I had to dig this thread up.
Never seen this test before so it’s really interesting to read all this information.
So in short. If you can, bypass the spring. It can only do good.
Really have to try that to some of my lights. luckily the (only real) hotrod with the fet driver I have has already both springs pypassed.
Andrew2007
Andrew2007's picture
Last seen: 3 years 1 month ago
Yes, an interesting test indeed!
thijsco19 wrote:
So in short. If you can, bypass the spring. It can only do good. Really have to try that to some of my lights. luckily the (only real) hotrod with the fet driver I have has already both springs pypassed.
I did my first bypass a couple of day’s ago, the smallest one shown in this test – 5mm tall spring from a Qlite/ Nanjg driver. So frustrating trying to keep it in place whilst soldering.
The spring is so small it needs to be stiff to avoid being compressed too much, if you drop the torch vertically on it’s head it does very little to absorb the energy of the heavy cell’s, I dropped mine the other day and the button on top of the Panasonic cell just collapsed, the driver was fortunately still intact.
I’m going to see if I can find a taller softer spring which I can then braid.
LightRider
LightRider's picture
I know #8 wasnt the top performer, but ive been looking for a source for that spring. i had two of them. I believe they were added to a driver order from mtn. The reason im looking is that they fit perfectly over the top of the nanjg spring to give a little compression before the battery presses on the stiffer nanjg spring. anyway, if anyone knows where to get them, please let me know.
shaipig2112
Last seen: 3 years 8 months ago
Thanks your details Thumbs Up
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 16 min 25 sec ago
Do you have any springs big enough so i can make a pogo stick lol? Imagine bypassing the spring on a pogo stick and then trying to jump!
The Miller
The Miller's picture
Last seen: 2 months 4 weeks ago
Ordered these, cheap and I though they can be usefull to add to biger on tail or over smaller at driver side
https://www.fasttech.com/p/1347100
Theodore41
Last seen: 1 week 2 days ago
djozz wrote:
For all lights that have to perform a little bit I would do a spring bypass, except if the light has to be particularly good-looking, i.e. if they are meant as a present, then I’d go for a copper-alloy spring without bypass, looks way better! (I have a djozz-spring without bypass in the tail of my BLF-X6, with a LD1 driver and a 80CRI 3500K XM-L2, now that is a chique light! Smile) But a serious single-li-ion hotrod needs a complete spring bypass, a copper spring is not good enough.
BTW, I could ask the manufacturer of the ‘djozz-spring’ to make another batch if there’s interest enough, I still have some and really like them for the bigger lights. In case of another batch of 200 pieces they would be a dollar/spring again (plus some shipping, see my old spring-sales-thread). what I would do different is that I would have them made with 9mm base instead of 10. Probably the height would then be a mm less too.
I have some lights,small and medium,ie BLF A6,Astrolux S41,
Olight M1X Striker,Nitecore P12GT,plus a MH27,EagletacS200C2, Olight SR52-UT,and Acebeam K70. Which of them would benefit more from a spring bypass?I mean I can see the difference with my own eyes,not my luxmeter only. Smile
jescereal
jescereal's picture
Last seen: 1 month 1 week ago
I have some lights,small and medium,ie BLF A6,Astrolux S41, Olight M1X Striker,Nitecore P12GT,plus a MH27,EagletacS200C2, Olight SR52-UT,and Acebeam K70. Which of them would benefit more from a spring bypass?I mean I can see the difference with my own eyes,not my luxmeter only. Smile
The BLF A6, and the Astrolux S41 (depending on which version you have) since they’re direct-drive. Maybe don’t expect a drastic change. I honestly couldn’t tell a difference. Maybe a slight one, but a bright light is bright. If you don’t have a stock version to compare it to directly, you might not notice a change.
MRsDNF
MRsDNF's picture
Last seen: 10 hours 14 min ago
I’m nearly out of the heavy ones you had built and sold. Nudge nudge wink wink. Smile
djozz
djozz's picture
I was going to have a new batch built (only difference: 9mm diameter base size instead of 10, to make it fit a standard switch board), but the contact I had at the spring factory is not working there anymore, and they lost the details of my previous order, so I had to figure it all out again, and then I ran out of hobby time temporalily, and then forgot about it.
I will have another go at it in September (out camping with the family at the moment Smile )
MRsDNF
MRsDNF's picture
God on ya. For the camping with the family that is. Silly
LightRider
Keep us informed;)
Theodore41
Because I destroyed the led of my Astrolux S1,I sent it to a friend who changed the led and bypassed the springs.
As it had passed enough time because the led came from China,I had forgot that the led which is now in,is not the original,but a XP-L Hi,so when I measured the intensity with my luxmeter,I found 19584cd,while it was 11500cd with the original led.Really the S1 shines. Smile
Of course,after 10 seconds I feel intense heat from the light now,much more than before.
Lexel
Lexel's picture
Last seen: 37 min 44 sec ago
Bypass a spring dont need to look ugly, just a good soldering iron and used to solder SMD stuff
BlueSwordM
BlueSwordM's picture
Last seen: 18 hours 45 min ago
So, djozz, are you planning to make some springs again or not?
djozz
djozz's picture
No, lazy me postponed it for a few years and now led4power has made the exact spring that I was planning. Thanks L4P!
https://led4power.com/product/gold-plated-phosphor-bronze-high-current-s...
BlueSwordM
Thank you for the answer. The reason I asked for this is that I am currently in contact with some Chinese OEMs to make some customs very high current beryllium copper springs, or phosphor bronze springs.
Also, I had completely forgotten about led4power’s springs. But they can “only” handle 6-7A. So, I decided to take it into my ones hands so we can get the best springs available in the same size category.
I have asked them quotes for 200pcs to 1000pcs depending on the seller for these materials:
C54400 Phosphor Bronze B2 with 19% IACS
C17530 Beryllium Copper at 38% IACS
C17500 Beryllium Copper with 45% IACS
From what I have asked from a materials engineer friend(I am so lucky to be friends with him), it would be best to take 38% C17530 Beryllium Copper as it is much easier to machine and less susceptible to compression compared to C17500 45% IACS. What do you think?
djozz
djozz's picture
All I know about springs is in the OP, but your plan makes sense.
I’m not sure what your conclusion is from “they can only handle 6/7 A” ? It just is a way to explain that the resistance is lower than pure copper, I guess that it is the same as the phosforbronze spring that you are planning.
Are you going to sell the springs and are prepared for the hassle that comes with it?
hIKARInoob
hIKARInoob's picture
Last seen: 4 min 18 sec ago
Why are you interested in machinability?
BlueSwordM
@hlKARlnoob Cost. 45% IACS Beryllium Copper, or even just pure copper, is very hard to machine. And therefore, is at a big premium. This is what he told me anyway, and I do believe him on the research I have done.
The engineers at the Chinese companies said to me the same thing: 38% IACS beryllium copper is just a a tiny bit more expensive than phosphor, but 45% IACS is much more expensive to machine, in exchange to being more mechanically weak in terms of springiness.
This is why BeCu 45%IACS springs are so expensive on IntlOutdoor compared to bronze springs on Kaidomain, even for a smaller spring. It is just because it is more expensive to machine.
@djozz, I am planning to make a group buy, yes. Not all of the springs made are for the group buy of course. I’m going to keep some of them to replace all of the springs in my lights, so about 20 pcs if I only make 200 pcs of them. Then I am keeping about the same amount for prototyping a product that I am currently engineering, so about 20 pcs.
The rest 150pcs I am probably going to sell in a GB at cost depending on the price they quote me, just so the BLF members can try them out, and see how really good they are.
Before that of course, I am going to do a similar test to yours in 2014, just a bit update LOL
I have done group buys locally before, but not on a global scale like BLF. So it is going to be a trial on how good I am on the topic.
TLDR: Going to keep about 50 springs for myself and a project, then going to sell them in a group buy if they are good enough. Otherwise, it is going to be part of my hobby money spent on 200 springs.
hIKARInoob
I don’t get it. You don’t machine to produce springs; springs use a forming process to obtain their shape. At least, that’s what I thought.
