Manker E14 Mods
58 posts / 0 new
CRX
CRX's picture
Last seen: 1 hour 18 min ago
Manker E14 Mods
Manker E14 Quad XP-L HI V2 1A - FET 17 - 18350 - Fw Clicky Sw - 2500lm.Manker E14 Quad XP-L HI V2 1A - FET 17 - 18350 - Fw Clicky Sw - 2500lm.
Battery tube was too long at ends, leaving gaps, showing orings so I filed it down a little from 37mm to 36.5mm and blackened the copper head to see what it would look like.Manker E14 Quad XP-L HI V2 1A - FET 17 - 18350 - Fw Clicky Sw - 2500lm.
The head was glued, it was not strong stuff though, quite chewy.
Wrapped up head & body well with G-tape and ran the light in turbo mode until very hot.
Twisted off bezel, difficulty rating – 4.
All XP-G2 emitters present and accounted for.
Plastic screw washers – washering, screws – not made from cheese.
Soldering – not too bad.
Thermal paste coverage – Fail, MCPCB – Fail.
This damage obviously kept the board raised slightly on one side so I’ve lapped it flat but this is as good as this MCPCB will be.
Raised bumps around screw taps & sharp edges around central wire hole on driver side countersunk fixed.
Extra long 24 AWG silicone wires replaced with shorter thicker 20 AWG.
Preliminary readings - 7.42A Max.
Swapped single driver spring for 2.5mm copper stud
Installed four XP-L HI v2 1A LED’s and changed polarity of the MCPCB.
Eventually changed the driver to a 17mm MTN FET with GuppyDrv Rev1. 8.51A Max.
Installed battery tube anti-rattle film – this is just thin sticky back plastic film (I like carbon fibre effect)
Measure inside diameter of tube, multiply by 3.14 and this will give the length you need for a nice tube insert.
Reverse clicky changed to forward clicky with wire spring bypass, sanded down switch retaining ring from 3.1mm to 2.42mm and used a thinner brass washer.
Tritium vial installed in lanyard slot
18500 battery tube version.
Edited by: CRX on 10/27/2018 - 18:07
MRsDNF
MRsDNF's picture
Last seen: 1 hour 48 min ago
Very nice. I like your battery tube inner wrap. Your mod reminds me of mods gone by and rarely posted up today. Thanks for taking the time to post it up. Smile
I wonder how well the anodising would bake? Silly
M4D M4X
M4D M4X's picture
Last seen: 2 hours 22 min ago
thanks a lot for the nice pictures and sharing your great work
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
The Miller
The Miller's picture
Last seen: 4 months 6 days ago
If it is the same ano as the X5/x6 it won’t bake nice and shiny Sad
Nice work CRX!
Firelight2
Firelight2's picture
Last seen: 32 min 47 sec ago
Awesome job CRX! Cool
How did you blacken the copper head?
CRX
CRX's picture
Thanks guys Thumbs Up
I use cold bluing solutions for darkening metals.
Ouchyfoot
Ouchyfoot's picture
Last seen: 3 weeks 3 days ago
Yes, nice simple tweaking.
No real stress, just a bit of spare time filled with minor tasks that make a nice little difference when completed.
Blackening?…please tell.
Anti rattle film? …I am curious yellow.
pinkpanda3310
pinkpanda3310's picture
Last seen: 1 day 10 hours ago
Nice work. The black head looks cool but I kinda like the showy copper.
HorizontalHunter
HorizontalHunter's picture
Last seen: 1 month 1 week ago
Very nice.
Did you double up the rear spring by adding the front spring? I assume this is equivalent to a bypass.
I was lucky; no glue on mine.
Bob
Vegetarian: vejiˈte(ə)rēən/noun: old Indian word for lousy hunter.
Firelight2
Interesting! Can you provide a link to what you use? I can see a number of uses for this in my mods.
CRX
CRX's picture
How about a compromise Wink
Thread updated with new stuff about the head rebuilding and i think i’ve answered those who asked questions there.
Thanks for reading.
Ouchyfoot
Ouchyfoot's picture
Pimp master.
Firelight2
Wow CRX. the black in the heatsink slots looks great! Smile Beer
pinkpanda3310
Hmm.. after seeing the innards of yours I’m inclined to follow suit and do some tweaking. Nice looking head, too. Did you rub off the coating and will it patina now?
Thanks for posting this up Smile
djozz
djozz's picture
Last seen: 1 hour 29 min ago
Thanks for posting this very nice pictorial of the build and tweaks!
antiparanoico
Last seen: 6 days 5 hours ago
Is this copper?
Please, I need confirmation.
If anything can go wrong, it will.
Matter will be damaged in direct proportion to its value.
zelee
zelee's picture
my S41 is glued so i can’t open it without damaging the head Facepalm
Don’t mistake my kindness for weakness.
I am kind to everyone, but when someone is unkind to me, weak is not what you are going to remember about me.
Tom E
Tom E's picture
Last seen: 1 hour 53 min ago
antiparanoico wrote:
Is this copper? ... Please, I need confirmation.
It looks like we are looking at nickel. All Noctigons are very thin coated gold on the outside, nickel underneath to help the with the gold bonding, and then the solid copper under the nickel. Around the indentations, you can see all 3 layers.
The gold can be removed practically waving super fine grit sandpaper over it, while the nickel takes a little bit of rubbing. I've sanded down many a Noctigons over the years.
antiparanoico
Is this copper? … Please, I need confirmation.
The gold can be removed practically waving super fine grit sandpaper over it, while the nickel takes a little bit of rubbing. I’ve sanded down many a Noctigons over the years.
Thanks! It seemed aluminum.
HorizontalHunter
X2
Looks awesome.
Bob
Ouchyfoot
Ouchyfoot's picture
Q: is the bluing conductive, and can it be soldered to?
jack-bkk
Last seen: 1 year 9 months ago
great job
thanks for your time to document it and share with us
btw your collection looks great
Dirt
Last seen: 27 min 10 sec ago
Great thread crx! that looks stunning with the black stripes.
Martini
Martini's picture
Great job, it looks super.
scdaf wrote:
It’s important to have your restraints within walking distance, lest someone needs restraining. Wink
Turningbluechips
Turningbluechips's picture
Last seen: 2 weeks 1 day ago
CRX, what battery are you using? It must be 16340 or cr123? I just took about .005” off of each end of the battery tube to square it up and improve contact. I don’t think I can go any shorter and still take a 18350. Also mine is a S41 but I doubt there’s any difference.
M4D M4X
M4D M4X's picture
V2 looks georgous!
CRX
CRX's picture
Yes the coating came off mostly with acetone, should patina nicely now
Is this copper?
Yeah i think Toms explanation is right there
C’mon, give it a shot like i showed, you can do it Wink
It’s just a thin layer of oxidised copper so would imagine it’s only slighly less conductive and would need cleaned before soldering
jack-bkk wrote:
great job
Thanks Smile
Yeah i think it does look better now
That’s why i trimmed down the driver retaining ring and replaced the spring with a copper stud so as to leave plenty of space in the battery compartment.
Here’s mine with a flat top purple Efest 18350, still space for a button top
M4D M4X wrote:
V2 looks georgous!
V2, i like that
lionheart_2281
lionheart_2281's picture
Last seen: 4 hours 12 min ago
Amazing work!!! What’s your address, I want to send you mine Smile
(joking…kinda….not really)
FmC
FmC's picture
Last seen: 3 hours 19 min ago
Nice work sorting out the details – that’s where the devil is, & something we’ll probably never see coming off a production line in a budget light.
Edness
Edness's picture
Last seen: 6 hours 43 min ago
I’m thinking about changing mine to a forward clicky. Besides the switch, do i need any other parts? Just wanted to know before i tackle this.
thanks!
CRX
CRX's picture
It’s a fairly simple swap, i think i just cut the nub off the rubber boot and used a slightly thinner washer.
