[PART 1] Official BLF GT Group Buy thread. Group buy officially closed! Lights shipping.
19107 posts / 0 new
DEL
DEL's picture
Last seen: 2 years 8 months ago
MRsDNF wrote:
koyotee wrote:
MRsDNF wrote:
koyotee wrote:
I’ve read the manual and it states that the flashlight will eventually turn off at low voltage. Can someone confirm at what voltage does that happen?
I have some info here.
http://budgetlightforum.com/comment/1163105#comment-1163105
Does this work also with unprotected cells? If it shuts off at ~3.5V then it is fine.
Yes low voltage warning works with unprotected cells.
This is a standard Narsil feature, but it should have been in the manual anyway. Just added this to the FAQ in the support thread:
  • The GT has low voltage warning and shut-off. At what battery voltages does this happen?
    • At 12.0 V (3.0 V per cell) the GT will blink the main LED and step down in power. It will do this repeatedly until the battery voltage recovers above 12 V.
    • At 11.2 V (2.8 V per cell) the GT will blink rapidly and shut down the main LED.
      Note that these voltages can be ~0.05 V per cell off in either direction, depending on the component tolerances and temperature. These voltages are monitored under load and cells will read higher when removed and measured outside the light.
These numbers are from the NarsilM 1.2 source code, but I did also confirm them using a power supply on a production light.
southland
southland's picture
Last seen: 4 weeks 9 hours ago
DB Custom wrote:
Took this shot with my phone within minutes of taking the GT out of the box, my Dad held it next to his Q8…
This is the light that hit the water tower at 1.9 miles. Don’t see how any of the slightly noticeable non-mirrorlike finish affects the beam.
Thanks for posting, hope the reflector complaining goes down after seeing this. Have to blow up this picture to see good.
nodoubt
Last seen: 10 months 9 hours ago
Tally-ho wrote:
DB Custom wrote:
The camera I used to shoot those beam shots just happens to be the best low light camera Canon makes, period. The lens I chose is also among the highest quality offered, so please don’t insult the photo’s by assuming a camera cannot detect the subtleties of hues, it’s really not plausible to get a better result at any price.
Saying that you set the white balance on Auto is not an insult but a fact as per the report of the EXIF of your pictures.
what exif viewer is that ?
ARsee
ARsee's picture
I use medical hemostats to remove button retention rings. If the ring needs more force, I use mini needle nose pliers.
JasonWW
JasonWW's picture
Last seen: 2 hours 32 min ago
Click here for full size picture.
http://imagizer.imageshack.us/a/img923/8012/Ini9qn.jpg
Turningbluechips
Turningbluechips's picture
Last seen: 1 month 1 week ago
I’ll complain. LOL. I don’t see any OP in my reflector. I do see turning marks, kind of, barely. Programming and equipment… which is fine for the application. I’ve been spoiled with nothing but Okuma lathes. The old LC20 (mid 1980s) could keep that profile or better. The newish LB3000 EXII with live tooling is amazing.
Does anyone know how the reflector is finished? Is it plated or electro polished? If it’s electro polishing the OP effect is the result of cooking it a little too long.
BrianK
Last seen: 2 months 6 days ago
thslw8jg wrote:
Nev wrote:
These soft lens caps that for the gt , they may not protect the glass if dropped lens first or bashed lens first against something , so I was thinking maybe a round disc cut from 3mm or 6mm plywood put inside the soft cap might be a good idea ( cut to the same width as the outside of bezel ) wadya think?
I plan to do the same thing but use a piece of plexiglass instead of wood
You could also get thicker neoprene foam insulation and glue it in. I’ve seen it up to 1” thick. What I saw was used for pipe insulation. I would think hard substances would just transmit any shock directly to the lens where something cushioning would prevent it from getting to the lens. Heck, a piece of the packing would do the job, but I don’t know if it could be glued in place. Loose would also work I should think.
FWIW, I don’t know if there were complaints. Maybe one, but I didn’t take it as a complaint (I didn’t see the above post). I know my comment regarding the small OP effect wasn’t a complaint; it was merely an observation.
TBC, you could sell your light if you’re unhappy with it and the price paid for it. There would be plenty of folks who missed the cutoff who would be happy to take it off of your hands. That would free you up to but the light of your choice made with the lathe of your choice.
JasonWW
JasonWW's picture
I assumed it was physical vapor deposition (PVD) as most modern reflectors are. Maybe one of the Team members knows for sure and can clarify it.
MRsDNF
MRsDNF's picture
Last seen: 21 hours 57 min ago
Thanks DEL.
Aslan
Last seen: 6 months 3 weeks ago
Is there any statistics how many people have already received their lights, I number 149 in the list of 555 and silence Tired
mickscott
Last seen: 1 year 6 months ago
Got my 2x BLF GT`s today,
Thank you very much !
teacher
teacher's picture
Joey Adams wrote:
Teacher check PM
Thumbs Up …… Done & reply sent. Wink .. I concur……
Tally-ho
Tally-ho's picture
Last seen: 17 min 4 sec ago
Exif viewer 3.6
For mozilla
Yokiamy
Yokiamy's picture
Last seen: 1 hour 30 min ago
JasonWW wrote:
I put Neals “paid/shipping lists” back on post one. I think they are only semi helpful due to not being complete and outdated, but if it helps anyone, it’s there.
It seems quite a few of the packages are being sent without tracking notices sent (from DHL). I’m not sure why. If you’ve paid for your light, but haven’t got a tracking notification from DHL, it’s quite easy to call them at 800-CALL-DHL or 800-225-5345. If your outside of the USA there might be a different phone number. Just go to their website and click the link for customer service. Call them up and ask for a representative. Then just give them your name and zip code (or whatever represents your country). I tried it just for giggles. It was quite easy and the operator was very nice.
I don’t know if registered mail can be checked. I’m sure it wouldn’t hurt to check with your local mail service.
Or you can just be surprised when it arrives. That’s pretty cool, too. Wink
Even though Neal couldn’t ship by the exact order of those that paid or of those that signed up, he is still doing his best to use the order that was paid. These recent international shipments seem to be for people on the early side of the paid list as evidenced below. (These are paid list numbers)
Bruno28 #12
cypher1024 #57
FMC #78
Sirius9 #79
Yokiamy #128
Hunter1 #129
Bo4ka #144
Bozlight29 #148
Flasky #149
Hardware #174
Yoflash #178
DooMMasteR #193
Jaza #202
piotrek966 #266
Specialk #292
Bking #515
Bobtb #637
Bobtb’s light shipping is a bit surprising. So maybe this last shipment was pretty big? 637-362=275
Did 275 lights ship or just 200 or so DHL lights? We will have to wait for more info.
Thanks for the update TA!
JasonWW
JasonWW's picture
There were 362 shipped from the first 2 shipnents. Those were both USA shipments.
There seems to be a lot of international lights shipping now. See post #1 for details.
I also just posted a list a names on post #15426 that shows the paid list numbers of these most recent shipments. You are #101 on that paid list and people all around you have gotten shipping notices so there is a good chance yours has shipped as well. I suggest calling DHL and asking if you have a package on the way.
drood
drood's picture
Last seen: 3 days 9 hours ago
JasonWW wrote:
Umcookies wrote:
Just adding a side by side, nothing more to really add to the discussion.
Left is the orange-peelish reflector, right is the ‘promo’ shot of the light.
Who’s light is that on the left? I can see it looks pretty rough.
The cutting tool is expensive. The flashlight is cheap. For this reason, the tool can not be changed frequently. A worn tool makes worse the surface. It’s a compromise. Just my opinion. I am also a metalworker.
JasonWW
JasonWW's picture
Bruno28 #12
cypher1024 #57
FMC #78
Sirius9 #79
Yokiamy #128
Hunter1 #129
Bo4ka #144
Bozlight29 #148
Flasky #149
Hardware #174
Yoflash #178
DooMMasteR #193
Jaza #202
piotrek966 #266
Specialk #292
Bking #515
Bobtb #637
That wasn’t Texas_Ace, it’s me.
Aslan
In our “village” dhl do not provide information without track numbers Facepalm
Thank you, I hope to get it soon, it’s painful not to wait, it’s painful not to know when it will come Wink
ammofox
I finally found all 3 on post 5 !
Thank you very much JasonWW and all the other guys with helpfull comments for your support !
What an amazing service all for FREE !!!
Now I can go to bed and sleep in peace ! ( 6am here now in Ireland ).
Thankfull Regards to all the nice guys that helped, from ammofox.
amf
warzi1975
Last seen: 8 hours 11 min ago
My first two GT`s arrived yesterday in Munich, Germany. No batteries with DHL.
Thanks to all.
Robert
Bo4ka
JasonWW wrote:
Bo4ka wrote:
@DB Custom and lawallac
thanks, but no result. Switch cover is definitely not opaque, I unscrewed it.
It must be lighted, at least after successfull factory reset.
Let me see if I can understand.
You never saw any green light from the switch, even though the main led works fine?
You were able to unscrew the switch cover, but it is or isn’t opaque?
Opaque meaning solid, so no light gets through.
It should look like this:
If light does NOT go through your switch cover then send a PM to Texas_Ace and he will see you get a new one.
Ps, do your green leds light up?
They are a lot weaker than on the Q8.
My switch cover looks exactly the same. Green leds do not light up.
I am not new to flashlights. So I could remove the driver and see if there are any issues. But it would void the warranty.
AllenT
AllenT's picture
Last seen: 1 year 13 hours ago
Can anyone tell me what the max beam intensity for it?
i didn’t follow the thread
MSU, Go Green, Go White
JasonWW
JasonWW's picture
I have some news on emitter swaps.
I talked to Richard at Mountain Electronics (RMM on these forums and a sponsor here) and told him there might be more than a few guys with GT’S interested in swapping to a cooler tint. He says that if you send in your stock mcpcb to him and buy one of his new XHP35-HI emitters, he will reflow it for free! He has 2 choices right now, 5,000k and 5700k tint. They are both the same D4 brightness bin as the stock GT 4000k emitter.
The cost of both are under $8, plus the shipping cost there and back. I’m in Texas and shipping a small package from him is usually $2 to $3. So I would estimate the entire cost at under $15.
From his store:
Quote:
BLF GT LED SWAP
​Don’t like the tint of your BLF GT XHP35 HI?  Send us your MCPCB and we’ll swap it for this one.
Please ship your BLF GT MCPCB to us and we will swap it, test it, clean it, and send it back to you.
Your entire order will not ship until we receive the LED and get it ready to ship.
Ship to:
Mountain Electronics LLC
8076 S. Box Canyon Rd.
West Jordan, UT 84081
Here is the link to the 5000k.
Here is the link to the 5700k.
If your outside of the USA, then I’m not sure what shipping would be or if he even does international shipping. You’d have to contact him for details.
Bo4ka
It’s from 1,1 to 1,3 mcd
JasonWW
JasonWW's picture
When Vestureofblood tested the prototype it was 1,290,000 cd.
Flashem
Flashem's picture
Texas_Ace wrote:
Once again if there is anything important I missed, point it out to me.
For the reflector quality questions, we are looking into it. I am waiting for a reply about it now.
It was only pointed out to me yesterday, so give it some time, it is being worked on.
So far most of the reflector pictures I have seen were no worse then the V1 prototype reflector, which we had approved as being ok and also what got the 1.29mcd throw reading from VOB. If the quality is at least up to that level, there is no need to worry about it. We had agreed that it was acceptable when we saw it and nothing has changed now.
Lumintop was nice enough to try to improve the quality, this was purely a bonus for us but it has caused big delays in the production.
Which is where this thread actually plays a role I am afraid.
Lumintop is watching this thread, they do not speak english very well but enough to get the general idea.
When every other post is someone complaining that their GT has not shipped it sends a message that they should focus on quantity over quality and get them shipped out the door.
Can’t really blame them, I would even have to consider such a move in their shoes if I was reading this thread.
The fact is you can’t have it both ways, they can ship out faster with the V1 quality reflectors or it will be done when it is done.
People need to send a clear message one way or the other. Either they want it done now and are willing to accept the faster machined reflectors that come with that or they want the highest quality possible regardless of how long it takes.
They are not getting a “pass” on bad quality. The agreed upon quality was the V1 reflector, anything else was a bonus.
Now I am looking into the pictures and reports of the reflectors to see if any are not up to even the V1 quality standards. So far I have not seen any that are noticeably worse but I once again have only known about it for one day.
If you have a suspect reflector, please PM me a picture of it.
Far as shipping me a bad reflector, I will not be doing that on a mass scale, just no point.
That said if someone wants to send a suspect reflector and is willing to pay return shipping, I can install it in my light and compare the lux readings to see what kind of difference it makes. My guess is it will be a negligible difference within the margin for error of the test setup but I could be wrong.
I mean I have seen tests before between SMO and full on OP reflectors that showed only minor difference in lux readings.
Well put Texas_ace..
I would prefer a better quality with a slower shipping time.
I just bought 8 new lights over this past month. With that said, I’m in no hurry to get chewed out by my wife for buying another flashlight..! Especially one that’s not gonna be easy to hide..
Just glad to be in on the group buy list and looking forward to making payment!
Take your time Lumintop, the better the quality the more you will sell down the road!
This a flagship of a light!
JasonWW
JasonWW's picture
Thanks to all.
Robert
I added you to our current list of international recipients.
Bruno28 #12
cypher1024 #57
FMC #78
Sirius9 #79
Yokiamy #128
Hunter1 #129
Bo4ka #144
Bozlight29 #148
Flasky #149
Hardware #174
Yoflash #178
Alux #180
Warzi1975 #181 and #483
DooMMasteR #193
Jaza #202
piotrek966 #266
Specialk #292
Nicolicous #380
Bking #515
Bobtb #637
AllenT
AllenT's picture
Thank you!
Jason
JasonWW
JasonWW's picture
I don’t think it would void the warranty.
It should be pretty easy to check for power on the led. Just set your DMM to DC volts and probe the rear of the switch pcb on the black and white wires. You should see 2.18v. The white wire is ground and the black wire is for the switch leds. (The red wire is for the e-switch and has 5v to it)
If you see no voltage, then it’s possible your black wire to the switch came loose or the firmware is not sending the signal out. Maybe yours is set to off by default? You could make sure the settings are turned ON. You can see on the bottom of page 6 in the GT manual that there are 3 options.
If you DO see voltage, the software is working fine and it might be your tiny resistor by the leds not making good contact.
Here are some pics.
If you don’t feel up to checking it, I would PM Texas_Ace about getting it fixed (assuming it bothers you).
mrheosuper
any news on registered package ?
Forgot my pen
Topic locked
