[PART 1] Official BLF GT Group Buy thread. Group buy officially closed! Lights shipping.
19107 posts / 0 new
BVH
BVH's picture
Last seen: 10 hours 25 min ago
Picked up a new toy…………..indispensable measuring tool today. I’ve been what I call a connoisseur of light for a decade or so now. My sweet spot is 5500K. I’ve just not been able to get into the neutral or warm Whites. There is only 1 incan bulb in my house. Everything else is LED 5000K or 5500K. Now I can precisely measure all of my home, car, searchlight and other lights’ color temps and the REAL CRI, not just the averaged number usually quoted for marketing purposes. I’ve learned quite a bit over the last week while researching my purchase. The typical CRI number we see is the calculated average of 8 colors chosen decades ago by a Body in France, the name escapes me now. It represents how close a light source comes to the spectrum emitted by Tungsten incandescent light. CRI of Tungsten light is 100 on the CRI Scale. Extended CRI adds another 7 colors to the mix and the Sekonic 7000 meter has the capability to measure and display the additional 7 additional colors. The more color samples that are taken, the more accurate your CRI is going to be. But even CRI is a bit outdated and there have been and are processes in-motion to use another standard or two. There’s a lot more to it but i won’t get that deep. Suffice to say that below, the first 2 pics are of readings of the Sun. The first shows the Color temp in Kelvin (Tcp on the meter) of the Sun at 3:15 PM. Don’t pay attention to any of the lux reading as I did not set up for a precise Lux measurement. The next pic shows the CRI RA average calculated on only the first 8 colors in the bar graph but it also shows specific individual CRI readings from all 15 samples. The higher the bar graph and number to the left, the higher the CRI of each of the sample colors and the closer to the Tungsten standard the measured light source is.
The 3rd and 4th pics are of the same type of measurements of the GT on HIGH, not Turbo. The 5th and 6th pics are of the GT on Turbo. Notice how the R9 Red is absent from the GT and is actually a minus number.
Sol at 3:15 PM Dec 12 Text Mode
Sol at 3:15 PM Dec 12 Bar Graph Mode
GT at Top of Ramp Text Mode
GT at Top of Ramp Bar Graph
GT at Turbo Text Mode
GT at Turbo Bar Graph Mode
WWII 60" Carbon Arc (Sold), 1.6KW NightSun, 1KW VSS-3A, .8KW TrakkaBeam, 600W M-134 Light, 500W X-500-14s, 500W Starburst, 500W A120b, 450 Watt AEG German Leopard 1 Tank Light, 300W Locators, Megaray, 150W Communicator, Maxabeam Gen3, Pichel 75W Mini-Novas
EggsnBacon
EggsnBacon's picture
Now that is one awesome tool. I hope you know you are now obligated to test and upload results for every light you own lol.
New addict  -Various Maglites; Olight S Mini, S1 Mini HCRI, S2R, M1X, X7; Emisar D1 5000K, D1S 4000K, D4 219C; Astrolux S41, S42 219C, and a Gigglestick thanks  to BLF!
DB Custom
DB Custom's picture
Last seen: 2 days 14 hours ago
Nice BVH, bet you’re having fun with that!
Far Thrower
Last seen: 1 week 2 days ago
Can’t we buy the new 5700k LED already mounted without sending our old LEDs back to Richard?
Pulsar
Pulsar's picture
Last seen: 4 months 5 days ago
Problem is, there is no LED boards in the size the GT takes available
Nev
You have to send him yours & he will reflow it , I think.
Flashem
Flashem's picture
Last seen: 1 week 5 days ago
teacher wrote:
NikolaS wrote:
Aluminum reflector this size and thickness,is made from single big peace of aluminium block. After CNC machining all leftovers are being recycled..
To me, NikolaS was simply saying they were using a big CHUNK of aluminum. I did not read it as a reference to shape. I read it as “block” = “chunk”…… nothing more.
If you search the net to purchase a “block of aluminum” google will show you nothing other than square, flat, or rectangular stock. Anyhow, I get the point…
Teacher, I would like to be on the same page here. This block or chunk of aluminium is round stock and I would assume it is being turned in a CNC lathe?
I’m curious to how this reflector is being machined. Do you or anyone know of the page this info can be found or if this information was revealed, possibly a separate thread?
Not everyone here realizes how much work and time is involved into producing such a (masterpiece) flashlight like this..!
As far as machining goes, I think we should shine some light on the subject. I think it may help ease the frustration of some of those who were unsatisfied or complaining about there reflectors finish.
Flashem
Flashem's picture
![url=https://imgur.com/xsuQt7p][img]http://i.imgur.com/xsuQt7p.jpg[/img][/url]!
Shocked THAT THING LOOKS AWESOME!!
JasonWW
JasonWW's picture
Last seen: 6 hours 13 min ago
Correct, the GT has a massive 45mm diameter mcpcb. Richard carries them up to about 27mm. Keep in mind that the Convoy L6 with its xhp70 and 9,000 lumen potential (for the 70.2 and fet driver) only uses a 20mm mcpcb.
The reason the GT needs the massive size, even though it’s only putting out 2,500 lumen, is because of the massive reflector. The base of the reflector and centering ring are quite huge by normal flashlight standards.
See the base diameter of the reflector below. Courtesy of MRsDNF (Next to C8, S2+ and P60 reflectors)
Bonus pics.
Next to a Q8.
Currently there is a 32mm maxtoch mcpcb for an xml. These can be converted to 12 volt by some cutting and soldering, but I’m still not sure it would fit.
If anyone happens to find a big 12 volt xhp35 mcpcb for sale, please post about it here.
Thanks
Jerommel
Jerommel's picture
Last seen: 3 weeks 4 days ago
I doubt that.
I assume they get rough casts in reflector shape and then machine it.
Otherwise it would be a huge waste of aluminium, time, energy and tools.
Sure they recycle the machined off aluminium, but recycling those bits with machine oil and surface oxidation into the same quality alloy is costly too.
JasonWW
JasonWW's picture
I doubt that.
I think you would be surprised how quickly the modern CNC machine can carve up a big chunk of aluminum. I’m almost positive it’s quicker and cheaper to do it this way as opposed to using a forge and melting down aluminum then making castings which are going to end up not perfectly round for the lathe to grab ahold of.
Recycling the massive left overs is quite easy. It just gets shipped off. The place doing the machining doesn’t have to deal with it.
Jerommel
Jerommel's picture
JasonWW wrote:
I doubt that.
You’ll start with drilling a hole probably, and go from there.
It’s still a huge loss in material (like 95%), which has to be sold as waste and shipped.
Imagine the weight of the huge solid rods (poles rather) needed to machine 1000 GT reflectors.
Fact is, we don’t know.
People making one offs for a project will have to use solid chunks, but we’re talking Chinese mass production here.
NikolaS
NikolaS's picture
Last seen: 2 months 2 days ago
First I though they are made from circle plate shaped 3-5mm aluminum simply and fast with spinning over the shaped cast. Even Alloy wheels body is made that way…
But then I realized that we are talking about small CNC traces all over this thread, so they must be made from solid round chunk of aluminium bars at least 13cm in diameter.
That is just my conclusion, I’m not metallurgy expert, if someone knows better explanation I would like to know.
CCl3NO2
Last seen: 2 years 2 months ago
BLF GT has just arrived. All perfect! What a light: I could use it to illuminate a tennis court! Thanks a lot!
teacher
teacher's picture
End of BVH post
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Wow BVH!!! . Thumbs Up
This is beyond neat… thanks for sharing!
Seems we have the same tint preference. Mine is about 5000K – 5700K.
But while I have to go with the advertised ‘data’…. you can actually measure it!
I am impressed!! (and maybe even a slight bit envious… Big Smile )
Thank you again for sharing!!
Smile
Jerommel
Jerommel's picture
A rough (or not so rough) cast has to be machined too, so either way, you’ll see the traces.
Was looking for a youtube video of flashlight reflector production, but haven’t found one yet.
There are various metal spinning videos though, but that’s not how these are made.
It would be cool if Lumintop came with a video of the production process, including the reflector.
Jerommel
Jerommel's picture
teacher wrote:
A $2K toy…
Very nice though.
teacher
teacher's picture
Bonus pics.
Next to a Q8.
Thanks
End JasonWW post.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Good info & pictures Jason……. . Thumbs Up
Sirius9
Sirius9's picture
Last seen: 6 days 1 hour ago
Guys, I think there is something wrong with my GT!
I have it now in momentary mode (press&hold for turbo) and each time I press the button
I can feel slight recoil!. This only happens if I go from off to turbo, all normal if it turns ON
in mode that is not turbo.
Crazy
drood
drood's picture
A large reflector might also be produced differently. A large reflector might also be produced differently.. Production reflectors part 1… And without waste. Thumbs Up Thumbs Up
thijsco19
Last seen: 4 days 17 hours ago
in mode that is not turbo. Crazy
Pretty sure it’s normal. Do you have it loaded with 4 or 8 cells? 8 cells gives more mass which reduces the recoil.
Imagine all the trillion photons shooting away in just a couple of miliseconds after pressing the button.
Bo4ka
Last seen: 1 month 1 week ago
How to unscrew the head? I tried, but no chance.
st33lboy
Last seen: 2 years 1 week ago
Neal does not get a list of Lumintop to whom has the lamp been shipped? I wrote a message to Neal but did not answer.
Sonofspectrum
Sonofspectrum's picture
Last seen: 1 week 11 hours ago
Wouldn’t hydroforming be a better and more cost effective way to produce a reflector of this size?
It's moments of madness that keep us sane.
teacher
teacher's picture
This is for anyone who does not know how to acess the MCPCB/LED easily on the BLF GT.
First & foremost… DO NOT REMOVE THE BEZEL. Smile
So….. here is the process….
  • Remove battery tube
  • Place the ‘flats’ of the *‘engine’ in PADDED vice jaws. DO NOT tighten hard. Tighten just enough to hold it firmly & keep it from turning.
  • Grab the head with both hands and twist it off the *‘engine’ that is being held in vice jaws. If you can’t get it with both hands use a strap wrench placed around head just BELOW the bezel.
  • The top part of the head should come off in one unit containg bezel, lens, & reflector as one piece.
  • Cover hole in reflector to keep dust or any crap from entering the reflector. Then secure this complete unit in a safe, clean, & dry manner/area.
  • You will now see the easily accessible MCPCB & LED.
  • Un-solder Red & Black wires on MCPCB, being careful NOT to damage LED (if you are going to keep it for use again anyway)
  • Remove both Phillips head screws from MCPCB
  • Remove MCPCB
Note: .. *‘Engine’ = Part that houses driver, side switch & MCPCB w/LED
That is it…. Smile
Installation will be the reverse of these steps with the EXCEPTION that new Thermal Pasted will be used under the MCPCB. This is AFTER you have removed and cleaned the old thermal paste from the MCPCB mounting shelf of the GT.
Also…. IF you ever do need to take a bezel off, get a piece of rubber bigger than the bezel (piece of tire inner tube is one example).
Place it on a sturdy flat smooth hard surface, then put the bezel face down on it.
As you push with downward pressure twist the head of the light to loosen and remove the bezel.
The GT bezel can be difficult to remove.
gastonpatagonico
Last seen: 1 week 6 days ago
Hello, sorry for uploading a flashlight production video, which is not LT, but you can have an idea of the process, partially, greetings.
https://www.youtube.com/watch?v=WfQDxs-dvwc
DB Custom
DB Custom's picture
Teacher makes it sound EASY to remove the head from the pill, and of course it is… if you have the right tools. Without a large enough vise (with soft jaws) and strong enough reinforced strap wrenches of sufficient length, well, good luck!
I have the set of tires removed from my diesel VW before the big scam/buyback stacked in the garage, I found it relatively easy to remove the bezel by pressing it into one of these Continental Extreme Contact DWS mounted tires and twisting. Access to the emitter is fairly easy due to the sheer size of the now open space (reflector removed).
Do take steps to keep the reflector clean, of course. I simply place it upside down in the bezel, atop the lens, and that suffices for the amount of time it takes to swap the emitter. Ambient conditions and presence of children are key factors involved in what measures one must go to. Pelican cases used to warranty their product against virtually anything, excepting Acts of God, Grizzly Attack, or Small Children… take heed! LOL
Bozlight29
Bozlight29's picture
Nice Olight video, you get the picture here how they produce flashlights. I guess this is one of the best facilities. Not every production facility looks like this in Guangdong region. This video shows that the reflectors are milled out of a cylinder of aluminium. No pictures of the coating process. Thanks for sharing.
Texas_Ace
Texas_Ace's picture
Last seen: 13 hours 2 min ago
Thats a great tool you have there! All sorts of fun you can have with that.
I am also glad to see proof that what I have been saying for years is correct, that the sun is around 5000k.
Also good to see proof that the tint does get cooler as the power increases. I think some of those saying it is too warm are looking at it in low modes, where it is quite warm indeed. At full power it really looks much better.
Texas_Ace
Texas_Ace's picture
Jerommel wrote:
I doubt that. I assume they get rough casts in reflector shape and then machine it. Otherwise it would be a huge waste of aluminium, time, energy and tools. Sure they recycle the machined off aluminium, but recycling those bits with machine oil and surface oxidation into the same quality alloy is costly too.
They are using a billet to machine the reflectors almost assuredly. The cost to make a mold and cast them would be way more then it is worth for a production run this small. Plus the surface finish would not be as good with a cast material.
From the outside you can see the material quality is much too high for casting.
Topic locked
