Luminus SST-40, a N4 BA bin tested
363 posts / 0 new
EasyB
Barkuti wrote:
EasyB wrote:
… I’m measuring the lux above the LED which gives me a number proportional to the total lumen output of the LED.
I guess you measure the lux at exactly 1 meter of distance right front in mule mode, then multiply that by some constant assuming lambertian emitter and whatever whatevers LoL. Could you elaborate a bit more? Thanks.
Yes, that’s pretty much it. More info here. http://budgetlightforum.com/comment/1023472#comment-1023472
scr79423
Last seen: 1 month 4 days ago
Tom E wrote:
clientequator wrote:
Is there a high cri version of sst-40, like the 95 cri sst20?
Not to be known available. There’s NW tints vaguely referenced here on BLF, but if you go to their website here: https://www.luminus.com/products/white, there’s only 6500K and above listed, and CRI is listed as 70 typical.
But here at Mouser they list 5000K and 5700K: https://www.mouser.com/Search/Refine?Keyword=sst-40. The weird thing is the “WDS” in the part # is not referenced in the datasheet, so these new 5000K and 5700K aren’t really covered in a datasheet from Luminus. It takes qty 500 min and 5 weeks delivery to get NW but looks like CRI is still 70.
To clarify the #‘s, the SST-40 N5 BC VH bin referenced above is, I assume, is the BC bin, which according to the data sheet is 6500K?
it says 6500K but it’s noticably warmer then my N4 BA bin (I got both the N4 BA and the N5 BC) the N4 BA looks brighter to my eyes due to the cooler tint
clientequator
clientequator's picture
Last seen: 1 week 6 days ago
Does anyone know if there is high cri version of the sst40 led?
Tom E
Tom E's picture
Last seen: 14 hours 32 min ago
Spec sheet here: https://www.mouser.com/datasheet/2/245/Luminus_SST-40-W_Datasheet-1499204.pdf
says one 70 CRI on page 7 - "WCS", where S is for standard 70 CRI. Least this is today of what we know. The SST-20's fill the high CRI niche for now.
Basically high CRI means lower output - that's how it seems to be working now. What's new in the last couple years is we can get NW tints in high output bins, but the high CRI kills the output.
contactcr
Last seen: 4 hours 7 min ago
Going to re-post this to this thread as a reference since I took the time to do it. This is two unverified bin SST40’s in two different lights (D80 and Enogear EC21, basically Nightwatch NS22). Both were sold to me as 6500K which I suspect is accurate.
I did this to clarify to myself and others what to expect with a slice vs dome on LED and to predict what an SST40 5000K might do with dome on/off, assuming it behaves similarly.
Here are measurements from two different reflector lights and LED sources taken at the hot spot:
And the wider spill:
In my opinion the 6500K+ with dome on makes my eyes go Sick if I look at the spill. It’s awful and basically unusable. The hotspot is generally very intense and far away so it matters slightly less and is probably passable if you need the output.
After slicing, the shift is still noticeable but much better in the spill. The spill becomes more faint so the shift is less bothersome and the hotspot is so intense its hard to notice much difference there.
TL;DR de-dome these at high output or use another LED. The 5000K will probably be better but still have huge shifts. Probably no need to worry about it going too “warm” after dedome. Seems unlikely at any decent current.
Lexel
Lexel's picture
Last seen: 2 min 21 sec ago
I wonder where did Astrolux get the NW sst-40
they do not look like real SST-40s
bond wire pads are different
also the dots are not in square pattern
Die seems to be a tiny bit smaller
Phosphor edge is different, also phosphor itself looks different
djozz
djozz's picture
Last seen: 1 hour 43 min ago
That looks at least interesting, if it is not a real SST-40 then at least the forger did its best to make it look like one, if it is a real one then Luminus made a new die for it.
Lexel
Lexel's picture
as it seems Astrolux can not source any more 5000K LEDs my thought is it may a very old die, different from any now sold ones
KevinZA1988
KevinZA1988's picture
Last seen: 1 sec ago
So I tried a N5 BC (Voltage: VH) in my M21A. My LD-A4 driver in the light was ordered with 8-12 Amp range so I set it to the bare minimum. Tail current was measured at 7.94A and voltage across the LED at 3.446V. It’s obviously bright AF, quite close to the sliced dome 3V XHP50.2 that it replaced.
The XHP50.2 measured 3.226V across the LED and the MOSFET probably took a hammering and caused the driver to overheat the whole time.
I will have to replace the LD-A4 with a LD-B4 driver and the corresponding PCB to combat the hot MOSFET. But I need some advice…….
Will it be OK to run the SST-40 at 8A? Or should I dial it down to 7A? The light is being used as a tactical light with high to low modes, no mode memory. So it always starts in turbo.
BLF Q8, BLF A6, BLF FW3A, BLF FW3C, Convoy L2, Convoy L6, Convoy C8+ , Convoy S3, Convoy M21A, Convoy S11, Emisar D4, Fireflies E07, Jaxman E2L, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65, Olight H1R Nova.
BlueSwordM
BlueSwordM's picture
Last seen: 4 hours 39 min ago
8A is about perfect.
I’d also put a copper shim on the MOSFET to help it with overheating.
KevinZA1988
Where can I buy a copper spacer? I have silicone cubes and sheets that I can use to space it. Otherwise I’ll have to make my own… The MOSFET is definitely running cooler with higher Vf of SST-40, but more cooling will definitely help. It’s a pity my 7-9 Amp LD-B4 failed for some unknown reason.
BlueSwordM
Oh, you just take a copper sheet, and cut a rectangle the size of the MOSFET over it.
KevinZA1988
Wow… Do I just tape it to the MOSFET?? Sounds risky. I thought about using 1mm silicone sheets on the driver side of a thick circular copper disk and insert silicone cubes on the shelf side to add some pressure as the driver is pressed down by the retaining ring.
BlueSwordM
Well, don’t you have some thermal adhesive on hand?
That’s how to do it.
Otherwise, you can risk a short.
KevinZA1988
Yeah I have some… I will then fill the cavity between the shelf and driver with silicone cubes to add pressure and that little bit extra heat conductivity.
Thanks for the advice.
Lexel
Lexel's picture
if you really mod on it switch to a better MOSFET, those mosfets are designed to get heat lost to the PCB side, adding copper on the top wont help
with SIR404 or Infineon with 1.2-2.5mOhm there is at 8A no considerable heat present, those can go up easily to 25-30A
2mOhm*8*8A—>0.128W heat
look into the Emisar D18 for example where the FET is quite stressed
1.25mOhm*35*35A—>1.53W
with a considerably good PCB design preferrred 2OZ copper and thermal viases 1-2W heat are OK
led4power
led4power's picture
Last seen: 4 min 32 sec ago
Mosfet resistance is irrelevant in case when linear driver operates in linear mode, in that case power dissipation in mosfet is (V_batt - V_led)*I_led.
So switching to other mosfet won't change a thing. Improving thermal path between mosfet top side and pill does help a lot, but it's not easy to make very good thermal path for deep pills/driver cavities. Example how to do it is S2+ thermal kit:
https://led4power.com/product/ld-a4-thermal-enhancement-kit-convoy-s2/
But again, this is not simple for many flashlights and cost is high, if LD-B4 can be used, it's the best method.
Your calculations are valid only when mosfet is in saturation mode - direct drive, where I^2*R loss it the only cause of heat generation.
SKV89
Last seen: 3 hours 16 min ago
Interesting results. I always thought dedoming this shifts the DUV higher which is the opposite of what you got. I wonder why the dedomed SST-40 NW in the Nightwatch NI40 is so horribly green +0.02x.
contactcr
I might slice my FT03 SST-40 NW since there are now replacement LEDs available. I’ve never attempted a complete de-dome though and dont really want to get into doing that myself.
gamezawy
gamezawy's picture
Last seen: 5 days 3 hours ago
Have any one successfully dedomed SST40, Not slicing, i want to dedome it because i got a very cool white sst40 and i want it to shift color plus the throw
DavidEF
DavidEF's picture
Last seen: 1 day 5 hours ago
I just got 10 more SST-40 from KaiDomain. Do you want me to try one for you? What methods of de-dome do you have at your disposal? I would want to do what you could replicate, or it wouldn’t be much use to you. Innocent
EDIT: Actually, just realized, I have some dead ones I burnt up. I’ll try those first! Big Smile
- The YKK Philosophy
contactcr
AFAIK Maxtoch seems to be the only one reliably chemically dedoming these. Seems it wasn’t easy when others tried?
DavidEF
DavidEF's picture
Do you have any idea what chemical they might have used?
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 4 hours 19 min ago
Nope dedoming these is tricky i think heat might work best. I killed 2 in petrol trying to dedome them. One worked with heat then got killed by a reflector sliding.
I just had one dedome its self now lol the silicone burnt up months after a sliced it. I don’t think its the LED fault it was out of the light for ages i just put the sliced SST40 back in my FT03 last night. Could of had dirt on it from storage as i had no issues with it till now and i used it sliced for over a few weeks. I had a XHP50.2 in my FT03 for the past few months.
Luckily i noticed the smoke and turned the light of i cleaned the dome with some alcohol and it seems to work still.
KevinZA1988
So I got my 5000K SST-40 LED’s recently… DD bin from Kaidomain and DA bin from Convoy. At low current the DD is a lot greener than the DA from Convoy. At medium current the DD is yellow and DA more white. At high currents the DD is white, where the DA almost has this slight magenta tint to it… I then went ahead and put a DA in my S2R Baton II with a beaded optic. And I can live with it, seriously. I will actually use this light now. And I have recently used my FW3A 219B SW40…. Obviously the color rendering is not good. But it’s an acceptable tint compared to any other SST-40 or XM-L2 in any of my Olights. I’m gonna order some more!
DavidEF
DavidEF's picture
edsg – How did you kill them in petrol trying to de-dome them?
contactcr
No idea. I think people only came to that conclusion cause of the macro photos of the LED make it clear it wasn’t sliced and diced like some of the Kaidomain ones or otherwise.
The Silicone stays on and takes the bonding wires with it. No matter how long you leave it.
I have 3 more that i sliced the performance difference isn’t to much between the two.
Lightbringer
Lightbringer's picture
Last seen: 2 hours 24 min ago
Gasoline has that nasty stank to it. Anyone ever try MEK or xylene?
DavidEF
DavidEF's picture
I think some have. There have been discussions on BLF before about de-doming, and those two were brought up. I can’t remember what the results were. But I think I vaguely recall at least MEK was praised in those discussions.
