#GB44 ASTROLUX MF01 18xCREE XP-G3/ NICHIA 219C (12klm) Flashlight Group Buy //// ACTIVE!
2671 posts / 0 new
freeme
freeme's picture
Last seen: 2 hours 36 min ago
MF01 is out of stock right now. Chinese New Year is closing, not sure if there will be any more coming before 16th Feb.
Jacsi
Last seen: 1 year 2 weeks ago
MF01 is in stock. Please send me a code for a MF01. Thanks.
JIGHEADWORM
Mf01 nichia with TA driver and vtc5a’s should be 17000 lumens on startup.
SKV89
Last seen: 4 hours 15 min ago
I just bought one with the Nichia 219c. Thanks for setting up the GB!
Light Years
Light Years's picture
Last seen: 8 hours 43 min ago
Can you send me the code please?
MichielSanders
MichielSanders's picture
Last seen: 1 day 2 hours ago
picked mine up at the post office this morning, going to play with it tonight Big Smile thanks freeme Thumbs Up
Olight: M3XS-UT, S Mini CU, R50 CU, R50 Pro LE, M2R, I3T Cu, S30R III, Marauder X6, X7R, X9R - BLF: Q8, A6, GT, GT mini - Emisar: D1s, D4Ti - Reylight: Tripple Dawn, Ti Lan
Nitecore: TM26GT, SRT9, EC11, T5s, P05Pink, LA10, HC33, HC70 - Fenix: TK75Vn FiatLux, TK76, CL05, CL09 -  Lumintop: Tool Ti, IYP365Ti - Astrolux: MF01 Lexel driver - FourSevens: Maelstrom MMU-X3
Caseit741
Last seen: 4 min ago
Is it possible to purchase the head only? I already have a MF02 and wanted a dual head light.
JasonWW
JasonWW's picture
Last seen: 25 min 57 sec ago
I’ve only seen the MT35/MF02 head sold seperately. I haven’t seen it the other way around.
patmurris
patmurris's picture
Last seen: 1 month 6 days ago
Mine tops at 13-14k with 30Qs.
Honestly it is more then enough and probably way too much considering the heat and lack of deep fins on the head.
SKV89
Bangood is now selling it for $77.95 without coupon. I bought mine yesterday with the coupon though.
freeme
freeme's picture
+1
SKV89
hiKARInoob, did you measure those values? So V2 is dimmer than V1? I just received my MF01 219c today so I’m assuming it is V2. It’s smaller than I expected and the tint is slightly less yellow the the 219c on my S42.
hIKARInoob wrote:
I’m afraid that’s not the case. Output does reduce with reducing voltage of the cells.
MF01 V2 (boost driver)
4.2V => 9100 lumen
3.6V => 7200 lumen
Output is maintained better though compared to V1 (older version).
MF01 V1
4.2V => 10000 lumen
3.6V => 5400 lumen
(my measurements)
hIKARInoob
hIKARInoob's picture
Last seen: 10 hours 2 min ago
4.2V => 9100 lumen
3.6V => 7200 lumen
MF01 V1
4.2V => 10000 lumen
3.6V => 5400 lumen
(my measurements)
Ceiling bounce using the Meteor M43 as a reference. The beam profiles of M43 and MF01 are close to identical, so I believe absolute lumens are sufficiently accurate. Max output is also in concurrence with measurements of other members I’ve read.
Since V1 and V2 have identical beam, relative output is correct. So in my case V2 is slighty less bright than V1 with full cells, but V2 maintains higher output with depleting cells. Both are 219C.
SKV89
I was just playing around with my new MF01 and after awhile, when I enable Turbo mode, it just turns off randomly and goes into lockout mode. I would have to hold the button 2 sec to unlock it. It happened several times. The batteries are VTC6. It’s not fully charged but the light indicator is red so that means there’s still charge in it.
Does MF01 have any protection mechanism that turns off and enters lockout mode under turbo mode when it overheats or battery voltage not enough?
hIKARInoob
Never read about it. There is thermal step down, so the light should not switch off or something. The indicator should turn red at 3.4V IIRC. And if I’m not mistaken this means at 3.7V resting voltage, if you go to turbo form there, you will have sag until 3.4V so red light turns on. This also means if you then go to a low output, voltage will rise again above 3.4V and light turns green again.
It sounds like a defect to me, but maybe freeme or anyone else knows more about this?
SKV89
Actually I think it is because of the low battery. I put in full charged batteries and it does not automatically turn off anymore. Also I think it is more than 8000 lumens when running with fully charged VTC6. I get ceiling bounce of 1,220 lux whereas my Emisar D4 XP-L HI v2 4000k reaches 420 lux for 1st second and drops to 370-380 lux in 2-3 seconds. The D4 should be about 4000 lumens at max output. However, its strange my 1,600 lumens BLF A6 XPL V6 with fully charged VTC6 reaches 200 lux and Astrolux S42 219c 5000k gets 209 lux at startup. The BLF A6 is supposed to be 1440 lumens without sprint bypass mod.
I will do a few more ceiling bounce test to compare with other lights I have coming in when I get them, which includes the Manker MK34, Haikelite MT09R XHP70.2, and Noctigon M43, just to name a few. Yea flashlights are addictive…
ssschen
ssschen's picture
Last seen: 1 month 1 week ago
Understand it is Spring Festival / CNY now so shipping most likely won’t happen for at least another week or two, but keen on this light if GB price is still available. Thanks.
NEU
NEU's picture
Yes. I am asking for more comparisons, I am also just waiting for shipment Manker MK34 to compare with Astrolux MF01 Nichia 219c V1
stfc69
Last seen: 7 months 6 days ago
I’d like a group buy code if it’s still available please.
Thanks very much.
Lexel
Lexel's picture
Last seen: 14 hours 51 min ago
I have here a MF01 that was sent to me for mod, but I cant get the bezel off
I tried heat it to 150°C without success
hIKARInoob
Please try counter clock wise this time.
(j/k Silly )
Lexel
Lexel's picture
(j/k Silly )
are you serious?
hIKARInoob
Lexel wrote:
(j/k Silly )
are you serious?
j/k = just kidding. I know you da man. Thumbs Up
JasonWW
JasonWW's picture
How are you turning it, with rubber strap wrenches?
Lexel
Lexel's picture
Great job Banggood gluing the bezel with red locktite
Took me almost 2 straight hours to get it open having to drive to my parents home on top to use a big vise to clamp it
And now the optics and lens is all over with that stuff
NEU
NEU's picture
Good old Hermetic red glue Evil . He keeps bombs Evil , no temperature or chemistry does not move it. Only a strength solution.
FlashIight
FlashIight's picture
How easy is it to remove the little plastic discs so that flat top cells can be used? And is there any disadvantage to doing this?
Lexel
Lexel's picture
I am back at my home, after I had to drive to my parents house to get hands on that stationary vise
JasonWW
JasonWW's picture
I’ve heard it’s easy to remove them.
They are there to provide polarity protection. As long as you always put your batteries in the right way you will be fine.
Only if you put a battery in wrong by accident will you fry the driver.
Lexel
Lexel's picture
The driver will be fine with reverse polority, but if you short 2 parallel batteries you will melt the springs
