Led4power.com : LD-4 CC linear drivers, ILC-0/1 illuminated tailcaps, optics, MOSX, copper DTP MCPCBs...
1199 posts / 0 new
contactcr
Last seen: 3 hours 31 min ago
I built an X6 quad with LED4Power’s new spacer:
http://budgetlightforum.com/comment/1461027#comment-1461027
Inkidu
Last seen: 3 days 22 hours ago
Thanks for all the parts Led4power. Everything arrived in good order. At first, I wasn’t completely onboard with lighted tailcaps, but they are pretty cool. They might even help me if the power goes out. One build done and more to go. Waiting on some parts.
Is the LD-B4HV going to back in stock soon? Or do you have something else planned? Also, I’m highly anticipating the release of the Subzero.
If I have something selected as being in my wishlist, will I automatically get an email once it is back in stock?
Thanks for any help.
led4power
led4power's picture
Last seen: 13 hours 39 min ago
 I don't plan to stock LD-B4HV anymore. I'm not sure about automatic mail sending, so it's better to check site and and this thread occasionally.
MascaratumB
MascaratumB's picture
Last seen: 24 min 38 sec ago
Thanks Neven! All good as ever! Thumbs Up
[REVIEWS] AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// ACEBEAM: H20 / TK16 /// BLITZWOLF: BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 / E10 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// KLARUS: XT1C /// LUMINTOP: Tool AA V2.0 + Tool 25 /// LIVARNOLUX: 314791 /// SKILHUNT: M150
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2 /// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
GIVEAWAY: 1
Enderman
Enderman's picture
Last seen: 3 hours 32 min ago
Any news on the CULPM1.TG yet?
I really want some of that boost hx Smile
DarkShot
DarkShot's picture
Last seen: 7 hours 19 min ago
Any suggestions on what to use for a thermal path with an LD-A4 and a S2+ host?
Reading through the thread again I realized I ordered a 12A LD-A4 with the intention or using it for a triple, misunderstanding the use of a MOSFET on this style of driver and don’t have anything to use as a heatsink. It’ll be going in a kiriba-ru triple copper pill, would some of those silicon thermal cubes suffice?
Barkuti
Barkuti's picture
Last seen: 3 hours 59 min ago
DarkShot, this aluminum spacer is probably meant for such duties. You could also craft it from copper if able, or something similar. The dimensions can be easily figured out, height is the only measurement which can leave a bit of doubt but this is easily solved making the part a tiny bit taller so you can sand down reduce it if needed later.
DarkShot
DarkShot's picture
Cheers, the issue at hand is those thermal kits are out of stock, and if they were in stock they still wouldn’t work, as I’ll need a single hole for the triple pill I intend on using. If I had some machining tools at my availability this’d be done in short order but I don’t unfortunately.
Thanks for the suggestion though!
The_Driver
The_Driver's picture
Last seen: 8 hours 1 min ago
led4power wrote:
Due to larger number of orders and some other projects that I must finish, those stuff is unfortunately postponed.
Still waiting for the FET switches and den 30A drivers :).
DarkShot
DarkShot's picture
My order arrived yesterday! Had everything arrive extremely well packaged, and everything went together almost without a hitch!
Unfortunately it looks like the RGB LEDs don’t like heat or I otherwise ham handed something, ‘cause one of them the red channel no longer works and I managed to kill another one. This was 100% my fault, it arrived perfectly functioning. Time to source some new RGB LEDs!
Additionally, where could I add a bleed resistor to an LD-x4 that I didn’t select as an option to use an illuminated tail cap?
led4power
led4power's picture
LD-x4 doesn't use resistor for bleeder but small jfet transistor 2SK3796 (you will see 3-pin empty space for it on driver - if you ordered one without bleeder option), parasitic current consumption during driver ON time is significantly lower compared to resistor (1mA vs 6-20mA).
But adding ~300Ohm resistor  between driver spring pad and gnd ring would work too.
contactcr
Any new products coming soon?
led4power
led4power's picture
When they become ready, you'll see them in store.
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 7 hours 46 min ago
Hello Neven, is it possible that you will offer XHP50.2 in 3V variant?
Such as from cutter in around 5000K?
led4power
led4power's picture
 I'm not planning to stock Cree LEDs.
The_Driver
I just built a light using the LD-B4 driver and one of your quad pcbs. I couldn’t find a diagram showing the connections of the socket on the pcb. I had to carefully study the pictures of your example build. Is there no diagram anywhere?
g_damian
g_damian's picture
Last seen: 6 hours 28 min ago
https://led4power.com/download/4621/
The_Driver
I’m talking about the LED PCB. There is no diagram for it.
contactcr
Edit: see LED4Power answer below
Ryzbor
Ryzbor's picture
Last seen: 1 day 10 hours ago
Question: mode advance in the LD-4 drivers is done by a half click, that’s pretty obvious. But is movement in the other direction possible? Eg. by a double click. I can’t find anything about this in the instruction
virence.com rosy 3500K R9080 Wizard Pro
contactcr
Double click can be assigned a special function. It’s in the instructions. No reverse
led4power
led4power's picture
The_Driver wrote:
I just built a light using the LD-B4 driver and one of your quad pcbs. I couldn't find a diagram showing the connections of the socket on the pcb. I had to carefully study the pictures of your example build. Is there no diagram anywhere?
There is no diagram at the moment, for 3x and 4x 32mm mosX boards connections are:
Pin1 - GATE (Pin1 is 1st from the left if you look from pcb center)
Pin2 - TEMP/NTC
Pin3 - MOONLIGHT
For 6x 34mm mosX boards connections are:
Pin2 - MOONLIGHT
Pin3 - TEMP/NTC
If customer buys one of these MCPCBs with all options included, I put connector with wires in package, so customer doesn't need to worry about this, he only needs to solder those wires correctly to driver (red-gate,white-temp, blue or yellow-moonlight).
The_Driver
Thanks. I bought the parts used and did actually manage to switch moonlight and temp which means that the overtemp protection doesn’t work correctly. It was easy to fix though.
The_Driver
Here's a German thread on my build.
led4power
led4power's picture
Clearance sale on some of ALU MCPCBs:
https://led4power.com/?s=clearance+sale&post_type=product
Perfect for ultra-budget builds with LEDs from Arrow that are on clearance sale too:
http://budgetlightforum.com/comment/1493829#comment-1493829
alberto7
Last seen: 15 hours 41 min ago
I build 2x Convoy S2+ few days ago (post in mod thread) but today have time to take more pictures.
Both with l4p mpcb and drivers and with custom retaining ring from kiriba-ru.
The leds are Luxeon V and Nichia 219-b-v1 sw45k 9080. I read that the nichia led become more pink at current higher than 2Amps (1,5Amps now) So, probably change the driver to LD-4 3Amp in the future Wink
DavidEF
DavidEF's picture
Last seen: 1 week 23 hours ago
Thanks for the clearance boards! I just bought a few yesterday. I wish I could have bought more but I’ve been spending a lot on other things already this year. I also bought another Q8 4040/5050 board, and it made me wonder if you ever sold enough to break even on those. You had said before that a lot of people who showed interest never bought any of them, and you were stuck with a lot of unsold boards. I know that was before I had bought any, and I’ve bought a couple of them since then. So, I’m hoping others have stepped up too, and you don’t lose money.
- The YKK Philosophy
contactcr
I think the 3V XHP50.2 may have spurred some sales. 15K lumen Q8’s
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 hour 49 min ago
Or more… 17000lm
Possibly even more “IF” you buy a bunch of 50.2 3v and cherry pick’em….over 5000lm with out lens.
4800lm with a UCL lens from flashlightlens.com
Wish I had 3 more of these…. Crying
KB1428 “Live Life WOT
will34
will34's picture
Last seen: 1 hour 56 min ago
Is the LD A4 enough for the 3V XHP50.2 or should I go with the B4?
